Oil Leak
Posted 23 November 2012 - 11:37 PM
I'm not sure how I can get a bolt in there, am I going to have to remove the whole block just to get one single bolt in?
I shall get some pictures up tomorrow if that'll help.
Thanks in advance
Jack.
Posted 23 November 2012 - 11:54 PM
When oil leaks from the flywheel housing it often comes out of the hole with the jiggle pin in right underneath the housing. If it's coming from there then it's the famous primary gear oil seal, known also as the 'red seal' which has gone. You have to remove the clutch cover and flywheel to gain access to remove and re-fit the red seal.
Posted 24 November 2012 - 12:04 AM
Posted 24 November 2012 - 12:07 AM
Posted 24 November 2012 - 12:10 AM
someone has probably replaced the clutch with the engine in and not put one of the bolts back... i don't blame them... many swear words have been shed on the infamous "awkward bolt"
Thanks dude
Posted 24 November 2012 - 12:13 AM
The only bolt which is inaccessible is one of the lower bolts on the clutch cover, and with patience, and jacking the engine with the mount unbolted, it can be fitted, even with my big hands, although many people leave it out without ill effect as there are 7 other bolts. But if you have oil at that particular bolt hole, you have a very big problem with oil leakage, although still quite easy to fix, and would have massive clutch slip and other symptoms.
Posted 24 November 2012 - 12:25 AM
I'm not sure if the leak is coming from a different location and just running down.
Jiggle pin and missing bolt or dowel hole maybe?
Sorry for being such a noob but thanks for the input guys, really appreciate it :)
Edited by jackx998, 24 November 2012 - 12:27 AM.
Posted 24 November 2012 - 08:48 AM
Also I notice that that the forward gearbox steady is not fitted, check to see if your front subframe has the bracket and if so, I'd suggest fitting one, stops a lot of rock in the engine.
Posted 24 November 2012 - 10:25 AM
Some people lighten their front subframe by drilling fairly large holes in the side members. If done properly, combined with seam welding all the joints to add strength, it is structurally ok and has the potentially useful side effect of providing a crumple zone in the event of a front impact, which may save your feet, as otherwise the toeboard and floor tend to be pushed back, or the subframe may come through the floor. There will be pictures on the rebuild threads somewhere of a lightened subframe. Why I mention it here is that, with careful positioning of the lightening holes, you could have an access hole for the awkward bolt.
Your transfer case gasket looks fairly new, so I assume it has been off relatively recently, possibly for transfer gear maintenance? If it was not refitted using the correct procedure, and/or a new "red" seal was not fitted, it would explain the leak from the jiggle pin hole. The correct procedure is nothing exotic, you just either use the special tool, a tapered sleeve, over the primary gear splines and shoulder, or wrap them with a layer of smooth tape, to protect the seal lips from sharp edges while fitting.
Posted 24 November 2012 - 12:09 PM
Posted 24 November 2012 - 12:43 PM
The guy who I bought it from did all the work himself, so your probably right tiger99, I'm going have to invest in the right tools for this job.
Could anyone point me in the right direction on where I can find the correct red seal?
Posted 24 November 2012 - 12:57 PM
http://www.somerford...age=page&id=144
Posted 24 November 2012 - 03:03 PM
The safe way to do the job is to remove the 'red' seal, then re-fit the reansfer case without the new rad seal fitted. Bolt up the transfer case to the correct torque and make sure that there is still a bit of end float on the transfer gear. You can just see and feel it. Then finally fit the red seal using the correct tool.
Posted 24 November 2012 - 03:07 PM
