Removing Drive Shafts
Posted 23 November 2012 - 10:17 PM
Is it necessary to remove the drive shaft from the pot joint first, then remove the point joint from the differential? Or can I remove the pot joint and drive shaft at the same time and separate them after they are out of the car? I will also replace the drive shaft seals at this time as well. Is it necessary to drain the oil? Or can the seals be changed with minimal oil loss?
Thanks!
Posted 23 November 2012 - 11:45 PM
The pot joints should be regreased and reassembled with new gaiters if needed, off the car, and fitted back into the diff first, giving them a good hard thump to ensure that the locking clip engages. The drive shafts can then be refitted easily, with the overhauled outer CV in place on the shaft.
Posted 23 November 2012 - 11:48 PM
You need to drain the oil first if you are going to replace the seals and the pot joint. The pot joint is too big to fit through the hole in the subframe. Its going to be messy anyway. If you are lucky, you might be able to get the pot joint off the drive shaft by giving it some sharp blows against a lip of the inner part of the joint to make it slide along the drive shaft. If you are unlucky (like me) you might be better off cutting the gaiter off and pulling the inner part of the joint out together with the drive shaft and all will fit throught the subframe hole. It will be very messy at this point. To remove the joint from the drive shaft you can do what I did:
http://www.theminifo...-stuck-to-axle/
To get the pot joint off, do not pry between the joint and the gearbox. Use a couple of large flat screwdrivers or chisels and drive them in between the gearbox an the joint. The factory tool is basically a "horseshoe shaped" wedge that you drive it with a hammer between the gearbox and the joint.
As far as the seals go I can not help you, I have not been fortunate enough to have to replace them. I had to replace the whole gearbox!
Edited by xrocketengineer, 23 November 2012 - 11:50 PM.
Posted 24 November 2012 - 12:07 AM
You MUST NOT use any kind of wedge, or you will ruin the diff side cover, and possibly the diff casing, which is matched to the main transmission case, so you could end up needing a new tansmission case and a full strip and rebuild, just because you used a wedge.
If you do not have 18G 1240 or similar, you can use a heavy tyre lever. You fit a 1/2" AF socket to the bottom bolt as a spacer. put the flat end of the tyre lever between pot joint and casing (NOT wedged), pivot it agianst the socket, and whack the end hard. It is not so good as the proper tool, as it applies force only at one point, rather than two opposite points like the official tool, but it usually works and never does any damage.
The lower casing bolt is the ONLY place where force can safely be applied.
Posted 24 November 2012 - 12:33 AM
http://www.reizendem...fronsusp/13.htm
Edited by xrocketengineer, 24 November 2012 - 12:45 AM.
Posted 24 November 2012 - 09:22 AM
I was going to order the 18G 1243 tool anyway, along with the new pot joints.
Regarding the oil seals, I noticed that the bolts holding the differential side covers were loose when I removed the gear shift linkage. I'm wondering it that is the source of the oil leak and not the seals? Especially because after I removed those bolts, the oil drip is more steady!
Posted 24 November 2012 - 09:26 AM
Once pulled the only remedy is a helicoil.
Posted 24 November 2012 - 09:59 AM
Posted 24 November 2012 - 10:10 AM
Posted 24 November 2012 - 12:55 PM
I might go ahead and try to pop the inner pot joint free of the differential, taking care not to press against the diff covers, as discussed above. If it works, it will save me money on the tool that I will only use twice (once on each side).
Also, how do you know if the ball joints are good or bad? Now would be a good time to change them if I need to...
Edited by Woreign, 24 November 2012 - 12:56 PM.
Posted 24 November 2012 - 01:19 PM
Posted 24 November 2012 - 09:52 PM
Posted 25 November 2012 - 12:05 AM
