Here is my Mini, which I purchased from Wales on Friday 9th November 2012. Which I have decided to name it JO, due to the number place XD
IMG255.jpg 39.34K
14 downloads
IMG256.jpg 32.25K
8 downloads
IMG261.jpg 53.61K
6 downloads
Mini 1.jpg 33.3K
2 downloads
Mini 2.jpg 40.29K
5 downloads
Mini 3.jpg 33.93K
4 downloads
General Info (Exterior):
Its a 1990 Studio 2 Mini, it has a standard 998cc engine, it has had some stage one kit stuff fitted, which includes (I think);
* Mini Sport Superflow side exit exhaust system,
* Mini Sport LCB exhaust manifold,
* Mini Sport alloy water heated alloy inlet manifold,
* Exhaust manifold gasket.
Not sure if it has anything else as I didn't fit it.
The car has been recently re-sprayed (again not by me). and before the paint had properly settled and dried and all that, there was petrol spilled over it, as some1 managed to miss the hole.
Has 12" wheels on, with mini light alloys.
Plastic boot handle and boot light.
Bullet mirrors, the really rubbish ones, as I cant even see out the n/s one, and the o/s I have to lean back to use it properly.
the rubber on the rear windows haven't been fitted properly or have worn as there is a big hope. so they will need replacing soon.
IMG250.jpg 50.87K
9 downloads
IMG253.jpg 97.99K
3 downloads
IMG254.jpg 72.17K
5 downloads
IMG252.jpg 42.84K
5 downloads
General Info (Interior):
The orginal seats have been replace, there is now a set of sort of blue coloured ones currently fitted, with the same colour door cards, there rear seats are also the same colour.
It has no dash board, this may stay the same, but i am not sure, I am opened minded weather i should put one n or keep it how it is.
The gauges are currently the standard two.
Standard pedal covers.
A rubbish hand break, and gear knob (will need changing).
Two 6 by 9s (just behind the front seats) and Two 6.5" speakers (on the back).
Mini 5.jpg 32.09K
13 downloads
Mini 4.jpg 31.73K
4 downloads
My Future Plans...
I have two clocks but my plans are to put a centre clock in with either 2 or 4 gauges around it (undecided on how many at the moment) and a bonus is that when i bough the car it came it a centre clock, and conversion loom XD.Plans for the speakers is to have the 6 by 9s moved to the back and the 6.5" speakers moved to the sides of the car where the rear pockets are. I will also add an amplifier.Will change the rear boot light for chrome a one
Changing the current mini light alloys to revolutions that I am buying from a friend
I am going to fit 4x head lights to the front of the car.
The door handles ware going to be replaced by a set of alloy or polished metal ones, as the passage side has broken, and while i will be doing that, I will get new exterior door handles, as they are starting to stop working, and its making the car harder to get into (which cant be a bad thing for security reason I guess
Currently running on the old stuff so I am going to replace them with Hi-los and at the same time replace the alloy trumpets.
A new wheel, Mounty Sport Steering Wheel is the one I have my eye on at the moment, as I still have the standard one in place.
The minis interior is going to become black and white union jack themed.
My biggest plan is to get a 1275cc engine and swap it for the current 998cc engine that I have in there at the moment. but that is a little way away as my 998cc is still running well.
What has already happened....
When driving it back from wales, i noticed a grinding sound from the n/s, drove it round for a little when I got back, and me and my friends, had discovered that it was a wheel bearing, and so the next day I took it to the garage, and this is what we found....
Smaller_vid.mpg 822K
22 downloads
22 downloads
and so I needed to replace the wheel bearing, and along side that, I had to replace the hud as it was knackered. so we also put on some new ball joints as we were there, here is it all fixed on...
IMG257.jpg 29.45K
13 downloads
But after that, it has been running fine, with no problems (except my empty wallet). so on to the list of future plans...
Edited by BrAd2012, 03 October 2013 - 02:05 PM.
