Clutch Problem :s
Posted 19 November 2012 - 06:32 PM
Posted 28 November 2012 - 08:08 AM
Posted 28 November 2012 - 08:12 AM
Posted 28 November 2012 - 08:29 AM
Posted 28 November 2012 - 09:24 AM
Have you set the adjustment screw correctly, by removing the return spring, bring the arm out so that the clutch release bearing is in contact with the clutch, unscrew the adjustment screw so that it meets the arm, and then turn back one half turn ?
Posted 28 November 2012 - 09:31 AM
Posted 28 November 2012 - 01:35 PM
Are all the clutch parts matching, it's not a pre verto clutch arm on a verto clutch?
Primary gear isn't seized on the crank?
Crank endfloat not excessive?
Posted 28 November 2012 - 02:17 PM
Posted 28 November 2012 - 03:45 PM
CLUTCH DRAG
Clutch drag or failure to disengage is not an uncommon problem with the Mini.
There are several possible causes as follows:
A. HYDRAULIC SYSTEM
1. Wear in the pedal spindle or failure of the pedal to master cylinder clevis pin.
2. Failure of seals in the clutch master cylinder.
3. ‘Ballooning’ of flexible hose due to internal hose degradation or damage
4. Air in system due to inadequate bleeding
5. Failure of slave cylinder seals
B. MECHANICAL SYSTEM – WITHDRAWAL MECHANISM
1. Wear in top clevis pin
2. Wear in lower clevis pin
3. Bent arm
4. Worn or broken ball at lower end of arm where it engages into plunger.
5. Wear in plunger ball seat.
6. Incorrect setting of overthrow stop nuts
7. Incorrect setting of adjusting screw (pre-Verto)
8. Corrosion between plunger and clutch cover due to lack of lubrication.
9. Thrust bearing failure – accompanied by a lot of noise.
C. THE CLUTCH ASSEMBLY
1. Failure of clutch diaphragm spring due to fatigue or distortion
2. Centre plate hub not sliding on primary gear splines.
3. Clutch plate surface de-laminating or breaking up
4. Distorted clutch plate.
5. If fitted, clutch plate shock springs broken and causing a ‘jam’.
6. Primary gear not rotating freely on crankshaft due to either: i) Insufficient primary gear end float,
ii) Primary gear bushes seizing on crankshaft, or, iii) Primary gear bushes breaking up
Posted 28 November 2012 - 05:31 PM
Posted 28 November 2012 - 05:35 PM
Posted 28 November 2012 - 05:41 PM
Posted 28 November 2012 - 05:44 PM
