No carbon burning off so the oil stayed golden coloured for ages (i once left it to see what would happen and eventually decided i would change it after 2 yrs and it was still like new?)
Mine came through the converter (that often iced up) and into the air intake to burn as normal.
the electronics pack fitted fooled the ecu into thinking everything was ok but made the injectors shut down after hitting 1500RPM so it just switched over to gas once started on petrol.
Found out what was wrong with the converter and the iceing up just before i got rid (was an air lock in the water pipes that seemed to force the air in the system into the convertor where it got trapped and things got too cold to work)
other problems i found were things like the petrol was left unused in the tank so long i had to mix it with fresh stuff and run it on petrol now and again as it just wasnt getting used lol
prices when i was running LPG were about 35p a ltr and hit 50p before i stopped.
still a lot cheaper today than a ltr of petrol.
think you will still need a certificate to say its fitted correctly to run it not just on safety issues but for the insurance.
i was told it would be a little slower but def wasnt it was like a dog out of the trap (rapid)
you could put a small tank in the boot but you would lose your boot and there perfectly safe as i remember the tank in mine had to be thicker than a normal gas tank due to it being in a car (for crash safety)
also if the tank was ruptured in a crash it wouldnt explode as it doesnt react like that.
tests show that the gas very quickly travels upwards away from the car and if an ingition did occur it would be a flash rather than a big bang and be above rather than in the car.
sorry to waffle on a bit but i did enjoy running gas and only wish i stilll had the system.
got rid of the car after 5 yrs LPG running with hardly any problems and only got rid when an artic run down the side of it flattening it while it was parked up
