Loose Wheel Nuts?
Posted 17 November 2012 - 06:18 PM
Thing is they are a tight as they will go and it's only the end of the nuts which wobble slightly, doesn't feel like the nut itself ie the but in contact with the rim. Is this the design or is something very wrong? Help!
Posted 17 November 2012 - 06:25 PM
Sorry to say I'v just done the same and this isn't the case with mine:/Hi everyone. I'm very confused as recently put Rover Cooper wheels on my Mayfair, and noticed today that on every wheel there is one nut which seems a bit wobbly. It's not the caps on the locking ones as they're fine, it's the ends if the normal ones.
Posted 17 November 2012 - 06:28 PM
or the PCD wrong ? should be 4 inch - not 100mm which was on some late (k series) metro's ?
if they are torqued up correctly , and you can wobble them by hand - then there is something really wrong
don't drive it
Edited by sledgehammer, 17 November 2012 - 06:31 PM.
Posted 17 November 2012 - 06:29 PM
Posted 17 November 2012 - 06:32 PM
I reiterate i can't undo the nut by hand, just the end moves a tiny bit if i wiggle it. And this is only 4 out of the 12 standard nuts.
Posted 17 November 2012 - 06:33 PM
If so - the shiny chrome part is only a cover and can move a little. Underneath is the proper nut and that should be fine.
Edited by L400RAS, 17 November 2012 - 06:33 PM.
Posted 17 November 2012 - 06:41 PM
Posted 17 November 2012 - 06:43 PM
Edited by lewBlew, 17 November 2012 - 06:44 PM.
Posted 17 November 2012 - 06:46 PM
Posted 17 November 2012 - 06:49 PM
i HATE these nuts! having worked on tons of minis with these nuts on, you always end up using about 4 different sized sockets to succesfully get the nuts off! 2 imperial and 2 metric.
the cover alows the socket to slip if your not carfeull, then the cover is stuck in the end of the socket, then the remaining head of the nut underneath ends up being 16mm (i think, cant be sure off the top of my head now) and so on it goes. total pain in the arse. if you ever had a puncture at the side of the road you could end up coming unstuck!
Edited by cradley-heathen, 17 November 2012 - 06:50 PM.
Posted 17 November 2012 - 06:52 PM
using these may not look so good, but the head does fit your socket properly and saves the faff!
Posted 17 November 2012 - 06:54 PM
Posted 17 November 2012 - 07:06 PM
Posted 17 November 2012 - 07:17 PM
Had another look at the car, they are indeed caps. In fact i can make them all wobble if i try! Cannot get any of them off for love nor money so obviously they are just meant to stay on.
Still looks like my wheels aren't falling off after all. Thanks for your help everyone :)
Posted 17 November 2012 - 08:06 PM
so just thin chrome plated covers were loose then
thought you had wrong PCD & it was bending the stud over & the nuts were grounding on the wheel hole off set
glad it's something simple
Edited by sledgehammer, 17 November 2012 - 08:08 PM.
