Road Holding/handling.
Posted 15 November 2012 - 05:30 PM
And to save me another post, what would be the best camber, caster and toe in for the front with 13x8 wheels?
Posted 15 November 2012 - 05:35 PM
Edited by mk1coopers, 15 November 2012 - 05:35 PM.
Posted 15 November 2012 - 06:02 PM
Camber is best kept quite small on big wheels, probably around 0.5 degree on the rear and no more than 1 degree on the front.
Big wheels will offer good grip, but because of the offset of these wide wheels on minis, they can lead to tramlining and a bit of twitchyness and a harsh ride rough roads.
I have 13x7 wheels on mine and think it drives fine, only notice any tramlining on badly rutted roads, but i'll admit the ride is quite harsh.
Posted 15 November 2012 - 06:05 PM
While the people with 12's watch and laugh;
On a serious note, generally speaking with a 13" wheel you'll get alot more grip, because there is more tyre unless your using Nankang tyres in Which case you may aswell use Ice blocks for wheels.
Honestly you don't really need camber for normal day to day driving, for the track I'd say around 1 Degree on the front and the same on the rear, standard mini's hold the road and handle incredibly well and you don't always need to go through the same stuff as a modern car, such as anti-roll bars, strut braces and coilovers.
Posted 15 November 2012 - 06:12 PM
road holding is quantifiable, you can get a meaaure by driving it round a big circle and seeing how fast you can go before it goes looses traction and goes off line , it can also be mesured in how much g it can gold before it slides.
Posted 15 November 2012 - 06:35 PM
Classic advert from the 1970's.
Edited by mab01uk, 15 November 2012 - 06:38 PM.
Posted 15 November 2012 - 06:58 PM
Here comes the barage of people who run 10's and then the people who run 13's and they have a big argument.
No, us '10 inchers' will happily carry on knowing the car was designed to have them :-p
Posted 15 November 2012 - 07:02 PM
So you reckon .5 camber on the front? With what toe, and should I be running .5 camber and between 1/8 and 3/16 toe on the rear?
Edited by alsy, 15 November 2012 - 07:10 PM.
Posted 15 November 2012 - 09:33 PM
Handling is the way the car responds to the dynamic inputs of steering, throttle and brakes on different surfaces and different road conditions.
Both are effected by suspension settings, road surface and tyres, but it is possible for a car with excdellent road-holding to have poor handling - I've driven quite a few like that.
With your very wide wheels with low profile tyres your road-holding should be excellent in the dry on very smooth roads but relatively poor in the wet or on bumpy roads. It's driver choice, of course and for Winter driving a set of 12" wheels with 145/70 x 12 tyres would certainly improve both driving & handling.
With regard to settings, front could be good at 3.5 degs caster, 0.5 to 1 deg neg camber. Rear would be good at 0 to -0.5 neg camber and 1 mm to 2 mm toe in. 3/16" toe in on the rear is too much.
I hope this helps.
Posted 15 November 2012 - 09:47 PM
Posted 15 November 2012 - 09:48 PM
So true
Handling = Feel
Road Holding = Measurable
Edited by Mini_Magic, 15 November 2012 - 09:50 PM.
Posted 15 November 2012 - 10:18 PM
Road-holding is the actual measure of the centripetal force which the car can generate through a specific corner. It is, in effect, a number or numbers relating to the G-force. It can be measured by driving the car in a constant circle and measuring the G-force generated.
I hope this helps.
Thank you for the help, ill go with that setup, thanks again.
Posted 15 November 2012 - 10:27 PM
I hope this helps.
Let us all know how it goes and feels after you set it all up.
