Van/pickup Grille On Saloon
39 replies to this topic
#16 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 17 November 2012 - 07:15 PM
And Panelbeaterpeter's on here.
#17 tiger99
tiger99
  • 8,584 posts
Posted 17 November 2012 - 07:58 PM
I must admit that instead of looking cheap, as the vans were supposed to look, that last one in particular does look superb.
#18 Minidarren83
Minidarren83
  • 1,207 posts
Posted 18 November 2012 - 01:06 PM
thats the way i will be going fully welded and smothed into the front panel rather than put on like a normal grill
#19 craigr91
craigr91
  • 429 posts
  • Local Club: nwminiclub
Posted 20 September 2013 - 07:11 PM
Before anyone says anything I know it's an old thread :) just saves adding another thread of the same into the forum ;)
Eventually I'm going for the bolted on van grille but which bonnet will I need? I'm going for a sorry FG one
http://absmotorsport...il#.Ujydio29LCQ
http://absmotorsport...il#.UjydqI29LCQ
Cheers , Craig
#20 alex-95
alex-95
  • 6,025 posts
Posted 20 September 2013 - 07:14 PM
Cheers , Craig
The one with no lip
#21 craigr91
craigr91
  • 429 posts
Posted 20 September 2013 - 07:18 PM
Blimey that wer quick haha :D
Cheers :)
#22 tiger99
tiger99
  • 8,584 posts
Posted 20 September 2013 - 08:32 PM
Why not just use a steel bonnet? The fg ones are more or less ok, as the bonnet is non-structural, but they flex, which may make the paint crack, and look and feel cheap. Also, in many cases there is a lot of work to do, finding a way to fit the hinges etc.
#23 craigr91
craigr91
  • 429 posts
Posted 20 September 2013 - 08:58 PM
I just think the 's' bonnet is different to be honest but I never knew they flexed and the ones linked gave places for hinges etc
#24 itsSamMiddleton
itsSamMiddleton
    Just On Tickover
  • 5 posts
Posted 16 January 2014 - 04:24 PM
Thanks to everyone for this fourm, I've removed the lip off my bonnet today that was easy enough with a chisel and drill! All I've got to do is now work out a way to fit the grille but then be able to remove it for mechanical work. Has anyone got any ideas of how to do this? My thoughts was to fabricate a bracket onto the mini itself and then weld a couple of bolts onto the rear side of the grille
#25 tiger99
tiger99
  • 8,584 posts
Posted 16 January 2014 - 04:37 PM
You could do it that way, with something like wing nuts on the inside. You may find that the filled-in area at each end of the grille is an appropraite place to weld the bolts. and they may line up nicely with the remnants of the original metalwork, or you can weld in a couple of angles or channels from top to bottom of the front panel.
The original Paddy Hopkirk quick release buttons, as you probably know, used a single 1/4" UNF bolt each side, and so similar bolts, used on the inside, should be equally satisfactory.
Edited by tiger99, 16 January 2014 - 04:37 PM.
#26 pickuptruck1994
pickuptruck1994
  • 366 posts
  • Local Club: Weston Mini Muckers
Posted 16 January 2014 - 07:00 PM
any one fited a mrk1 surround with the grill panel before...
regards Jordan
#27 alex-95
alex-95
  • 6,025 posts
Posted 16 January 2014 - 07:02 PM
regards Jordan
Ryans again.
531080_10151203112564722_1569314321_n.jp
#28 pickuptruck1994
pickuptruck1994
  • 366 posts
Posted 16 January 2014 - 07:18 PM
mmmmmm unsure on that one I think....
#29 tiger99
tiger99
  • 8,584 posts
Posted 16 January 2014 - 10:23 PM
Never seen that combination before, but if you like it, and like to be different, why not? Personally, I think the plain, unadorned van grille looks better, but there are other factors such as the paint scheme which influence that.
#30 bpirie1000
bpirie1000
  • Area Managers
  • 2,345 posts
  • Local Club: Amoc
Posted 17 January 2014 - 09:02 AM
I have a 61 van and only thing I would say is remember that you WILL have to fettle with the distributor at some stage and with the grill being welded in doesn't make it the easiest job... Ended up buying a foot long flat head screw driver for the points.... Stubby doesn't quite work.....
Looks ace though...
