Van/pickup Grille On Saloon
39 replies to this topic
#1 dasupersprint
dasupersprint
  • 848 posts
Posted 14 November 2012 - 07:23 PM
Just came across this:
http://www.minispare...c/van.aspx|Back to search
Do you have pictures of saloon Minis with that kind of front panel?
And would it be still possible to bolt a normal chrome grille over it?
I'd like my Mini to have different style options like different grilles and wheels.
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 14 November 2012 - 07:25 PM
Like this
#3 alex-95
alex-95
  • 6,025 posts
Posted 14 November 2012 - 07:26 PM
#4 craigr91
craigr91
  • 429 posts
  • Local Club: nwminiclub
Posted 14 November 2012 - 07:32 PM
Oooo that white one is fine :D mmmmm
#5 dasupersprint
dasupersprint
  • 848 posts
Posted 14 November 2012 - 08:34 PM
Just, wow!
Looks that I would need the Mk1 bonnet though
Can I still bolt a Mk3+ grill over it?
#6 Minidarren83
Minidarren83
  • 1,207 posts
Posted 14 November 2012 - 08:55 PM
The bonnets are the same it's just a mk3 has a lip spot welded to the front to hold the chrome trim. Drill or grind the spot welds take off the lip clean up the area and paint and that's it mk3 to mk1 bonnet done
#7 craigr91
craigr91
  • 429 posts
Posted 14 November 2012 - 09:11 PM
the more i look at the second pic the more i want.... think..im..falling..in..love.. might have to get my self mk1 bonnet sorted and front panel :)
#8 dasupersprint
dasupersprint
  • 848 posts
Posted 15 November 2012 - 12:34 AM
The grey one looks like the grille is just bolted on a normal front panel, you can see the two nuts holding it.
I'm definatly going for that look!
Keep posting pics if you have some!
#9 craigr91
craigr91
  • 429 posts
Posted 15 November 2012 - 07:15 AM
yeah, i noticed that, so its removable, easier acces for oil, dizzy etc.... look mint, i might join you in going for that look until i need new front end :) then have the proper front panel :)
#10 SAL 821X
SAL 821X
  • 1,890 posts
Posted 15 November 2012 - 02:14 PM
Correct just use some bonnet pins or such like.
There are two ways to go about it. The easier way is the panel you have posted the link too attached to your front panel with pins. The other is buying the pressed van panel which is around £160+ and welding it onto your car. I know this as I have to get one for my van project :( damn expensive!
#11 dasupersprint
dasupersprint
  • 848 posts
Posted 15 November 2012 - 02:22 PM
Why can't you weld the grille panel on a normal front panel? That's what I want to do.
#12 SAL 821X
SAL 821X
  • 1,890 posts
Posted 15 November 2012 - 03:08 PM
Well of course you can but I thought you liked to have the option?
#13 dasupersprint
dasupersprint
  • 848 posts
Posted 15 November 2012 - 03:22 PM
Good point. Maybe I can screw a normal grille over it?
Not easy to figure out when you're at the office, without the parts in front of you
#14 tiger99
tiger99
  • 8,584 posts
Posted 17 November 2012 - 06:51 PM
And to think that people used to fit saloon grilles to vans in the 1970s! How fashions change....
#15 alex-95
alex-95
  • 6,025 posts
Posted 17 November 2012 - 07:14 PM
A Couple more:
Ryan22_igm's
