Water leak in back seat
Posted 29 March 2006 - 08:34 PM
The back near the speakers is damp but mostly its wet near the backrests of the seats and it pools under the seat cushion. Any thought on what might be leaking? I've checked the rear window and roof and both seem fine. Could it be the wheel arches, and the water at the top is condensation??
Thanks.
Posted 29 March 2006 - 09:04 PM
It's more than likely the window seals. get some kitchen roll (or similar) and tape it to the inside of the window around the seal, then pour some water onto the seals from the outside. If it leaks, it'll seep through and soak the paper, then you can find out where it's leaking exactly.
Posted 29 March 2006 - 09:16 PM
i was having the same problem and was told it was the seals on the windows!!
Posted 29 March 2006 - 09:18 PM
More than likely rear window seals though as has been said already
Posted 29 March 2006 - 10:07 PM
mark
Posted 30 March 2006 - 02:37 PM
LOL!if you stop driving fast, your passengers may not get so "nervous"
Posted 30 March 2006 - 03:26 PM
Althought, spray-mount does make a mess of the window if it goes everywhere
Posted 30 March 2006 - 04:07 PM
Posted 01 April 2006 - 10:54 AM
I think it's coming in at the very top of the windows into the middle of the car seat and sometimes the speakers, then it sloshes around everywhere! Still seems strange it doesn't soak the back seat but it collects underneath it instead. I think I'll tape around the wheel arches too.
Posted 01 April 2006 - 12:03 PM
Posted 03 April 2006 - 05:21 PM
Have a poke around and sling your head under the arches to check it out.
Nate
