Mk 1 Switch Panel Into Mk 4 Hole !
22 replies to this topic
#1 vermillion850
vermillion850
  • 137 posts
Posted 11 November 2012 - 06:30 PM
hi all
will a mk1 old style switch panel fit into a mk 4 1977 hole ?
i fancy the older style look and put a fag lighter into the ignition hole....
any peeps know ?
cheers
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 11 November 2012 - 06:32 PM
I don't believe the hole changed size, just not used when the padded dash rail was added
#3 MBarnes
MBarnes
  • 250 posts
  • Local Club: None
Posted 11 November 2012 - 06:44 PM
Mine has been modified by the previous owner to fit what I believe is a MK1 switch panel. I may be wrong but the hole has been made smaller with a piece of fibreglass. I'll try and get a picture in the next few days so someone might be able to clarify.
Matt
#4 charie t
charie t
  • 3,153 posts
What he said ^
The panel screws into the steel rail
#5 vermillion850
vermillion850
  • 137 posts
Posted 11 November 2012 - 06:56 PM
oo thats good not got any padded rails in anyway , are the old temp and choke cables the same length as newer ones ? bet they are
#6 vermillion850
vermillion850
  • 137 posts
Posted 12 November 2012 - 06:46 PM
got whole unit plus cables and switches off ebay just waiting to recieve :proud:
#7 mini_surfari
mini_surfari
  • 326 posts
Posted 12 November 2012 - 06:51 PM
The mk1 lower dash rail hole is much smaller than a mk3 onwards!
#8 vermillion850
vermillion850
  • 137 posts
Posted 12 November 2012 - 07:03 PM
oo some conflicting advice here ! who knows the truth !
#9 vermillion850
vermillion850
  • 137 posts
Posted 12 November 2012 - 07:04 PM
i have bought it now so it WILL go in ! whats best way if hole is too big ????anyone
#10 vermillion850
vermillion850
  • 137 posts
Posted 12 November 2012 - 07:13 PM
this is what i got...
#11 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 12 November 2012 - 07:18 PM
the hole IS smaller on earlier models. FACT
#12 vermillion850
vermillion850
  • 137 posts
Posted 12 November 2012 - 07:33 PM
ok the dodger seems confident ....so how do i fit it now ? :wacko:
#13 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 12 November 2012 - 07:38 PM
You will have to let a piece of metal into the hole that has the external pattern of a mk3 on dash rail hole, and the inner pattern of the mk1 dash rail hole, smooth the welds down and it should fit!
#14 vermillion850
vermillion850
  • 137 posts
Posted 12 November 2012 - 07:48 PM
is welding the only option i suppose ?
#15 vermillion850
vermillion850
  • 137 posts
Posted 12 November 2012 - 07:52 PM
anyone done this before ?
