Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#1411 Petrol
Petrol
  • 967 posts
Posted 15 February 2018 - 10:58 PM
I have taken a lot of advice from people who have raced mini's over the years and I don't thing that polishing the rods is worth it. Yes I looked at brand new I beam and S rods modified for a 998 but everyone says the same thing. Stock 998 rods will take it despite their looks. It's interesting how things are turning out on this build. I bought a set of 1.3 roller rockers but won't be fitting them. I looked at S forged rockers but again it's not the best so this is what I'm going for.
Tig welded pressed steel rockers, tried and tested and bulletproof. They also have the correct lift ratio. It can get a bit of a minefield with the different ratios of lift that different rockers give but after a lot of research, I'm happy with this.
I don't think I will be gold plating parts. It won't be a showpiece like my other cars. I want to drive it!
#1412 Petrol
Petrol
  • 967 posts
Posted 17 February 2018 - 10:03 PM
Put the car outside for water testing
Then got the hose pipe out
It's coming in through the door seals on both sides. Oh joy :ohno: I need to find out whats going on but water is coming over the top of the U channel on the seal where it pushes onto the shell.
This is how to grind a crank. Proper job from Rob Walker!
#1413 1330RG
1330RG
  • 224 posts
Posted 18 February 2018 - 09:48 PM
Crank work looks great! Im keen to see how the 998 perfoms. I had a tuned 998 i belive bill richards tunned) in my first mini no idea what had been done to it but by god it revved and the car flew! I was only young and nieve though and ended up blowing it up! 😬
#1414 Petrol
Petrol
  • 967 posts
Posted 08 March 2018 - 11:31 AM
I'm hoping this one revs it's nuts off.
Not the best of weather for water testing. I'm having problems with the door seals.
#1415 Steve220
Steve220
  • 5,142 posts
  • Local Club: BMC
Posted 08 March 2018 - 12:09 PM
Pete,
I used talc and rubbed it onto the seals. Did the water test and it showed me if a) the door was touching the seal and b) if it was touching, which part was letting the water in. I then persuaded the door in that direction.
#1416 Petrol
Petrol
  • 967 posts
Posted 09 March 2018 - 10:27 PM
Pete,
Thanks for the top tip. The door seals are tight against the doors. From what I can see there's a bit more to these door seals than meets the eye. I'm still working on it and it's a right pita. The problem appears to be where the window frame attaches to the door. It's stepped and despite the seal being tight, water is getting in.
They knew about this problem at the factory and cut slots in the door seal to let the water out but it's a bodge. I'm trying to figure out a proper solution.
#1417 Richie83
Richie83
  • 1,495 posts
Posted 10 March 2018 - 11:07 AM
Pete,
they still do this exact bodge on new VAG cars. Its a well documented problem on Skodas holding water in the door seals. Thankfully none of it usually gets in on the modern cars as theres a lip.
#1418 johnR
johnR
  • 2,322 posts
Posted 10 March 2018 - 02:39 PM
I suppose you could make a small incision in the seal above the problem area and put in a piece of tubing to effectively match the step profile of the door by reinforcing the seal where it needs to be wider - not sure if my explanation describes it properly
#1419 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 10 March 2018 - 02:55 PM
It does explain it. Edd China carried out a similar fix on an Aston they repaired on Wheeler Dealers.
#1420 gadget555
gadget555
  • 152 posts
Posted 10 March 2018 - 07:02 PM
Well if it's good enough for "Wheeler dealers" then it must be worth doing ;-) I have a similar problem in that the bottom of the drivers door touches the seal but the top front corner of the frame there's about 1/4"  gap for about half the length of the top of the frame. I have "adjusted" the frame so it now touches the seal (cracked the paint where the door skin meets the frame on the front edge while adjusting it :-( ) but this then added another problem when I now wind the already stiff window up the glass now wants to go to the outside of the frame missing the channel altogether! This door has been re-skinned by a body shop mate, but I think it now has a twist in the door causing the fitting problems. I re-skinned the passenger myself adjusting the fit and lining it up on the car and it fits ok!
#1421 Petrol
Petrol
  • 967 posts
Posted 11 March 2018 - 11:10 PM
It's taken some time but I've sorted it. There are 2 issues. The shape of the door where it meets the top frame has a tight curve. It's too much for the door seal to cope with. The other issue is water runs behind the door at the A and B pillar and  runs down to the door step. It then backs up. Capillary action / tracking / volume of water then forces its way behind the door seal where it pushes onto the shell.
These are the slots they cut in the seal to let the water out. A bodge if the truth be known
To properly seal the door seal to the shell I used this. It's a butyl sealant
Bead run around the aperture
At the bottom, I used a PU sealant to join the two halves together with a tube inside the seal
To work around the problem of the door seal not fitting tight where the glass frame is, I fitted this P profile seal around the whole door
It's sorted now. My water test was 20 minutes of this
#1422 Jase
Jase
  • 1,166 posts
Posted 12 March 2018 - 07:07 AM
It doesn't get any better. This thread should be the bible of how build a Mini. I know I will be giving my build a lot more detail based on the work you have done. Thanks
#1423 Steve220
Steve220
  • 5,142 posts
  • Local Club: BMC
Posted 12 March 2018 - 09:31 AM
God damn it, Pete, you've stolen my door deal idea! lol. Glad its sorted though!
#1424 Steve8274
Steve8274
  • 580 posts
Posted 12 March 2018 - 04:08 PM
Great solution. Could you put a photo of whole door? What size p seal did you use?
#1425 Petrol
Petrol
  • 967 posts
Posted 12 March 2018 - 11:27 PM
Thanks guys and sorry Steve.
Car is back in the garage and it's not easy to take a pic of the whole seal. Hope this is ok but it runs around the whole door
Dimensions of seal
Ebay linky
https://www.ebay.co....m-/151599925099
Pete
