Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#1381 Petrol
Petrol
  • 967 posts
Posted 08 January 2018 - 10:11 PM
They look like refurbished parts?
The plunger is an original part. The clutch arm was brand new from Minisport. It's in the bin now
excellent work, The paint finish is great.
Where did you get the windscreen fillet strip finisher from? As I got 2 from minispares which say they're Stainless steel on the title but are actually chrome. I had to remove them 2 weeks after fitting to seal the screen and they were already starting to rust :mmkay: I ended up making them from some st/st shim.
I got them from P&L Minis. I still have the originals so if there is a problem, I will fit those.
It's so sad that people are having problems with parts
I've been considering going over to LED headlight globes as well. I too have the Cibie headlights, so they should be quite effective. Do those globes fit without any hassles? Or will you need to modify the bowls?
They fit in no problem but I had to use the original rubber seals at the back of the headlight rather than the ones supplied with the Cibie's
I think those are the same as my bulbs, whered you manage to get them from?
I bought a pair from the UK but I have ordered another pair from here for the spots
https://www.ebay.co....872.m2749.l2649
Pete
#1382 gadget555
gadget555
  • 152 posts
Posted 09 January 2018 - 09:51 AM
There the same spec as the ones I've fitted to my car, the difference between the led's and normal halogen's is like night and day, they fit in quiet easy in the plastic bowls you just have to tuck the wires out of the way. I just had a look through my photos and couldn't find any of the head lights but found some with the led sidelight's,
   23865504737_1909cd426c_c.jpgIMG_3462 by Keith Thornburn, on Flickr
You can see how bright theses are and the headlight bulbs are even brighter :-)
#1383 Artstu
Artstu
  • 837 posts
Posted 09 January 2018 - 03:44 PM
LED headlight bulbs. I will use the same in the spot lights
Pete
Blimey those LED bulbs are a complex subject. Now i can't tell from this photo if the bulb is two sided or three sided like the ones in your later eBay link? It seems that the two sided ones are the best judging from this.
https://youtu.be/Sonh4lHu4XE?t=1245
Edited by Artstu, 09 January 2018 - 03:45 PM.
#1384 Petrol
Petrol
  • 967 posts
Posted 12 January 2018 - 11:37 PM
LED's can put a lot of lumens out. A lot more than a typical headlight bulb but with less power consumption and much less heat.
Couple more pics of the bulbs
Stainless runners fitted the the door glass
These are the old ones
Butyl tape around the window winder aperture. This will prevent rattles and provide some water tightness
Masking tape to prevent scratching the top of the door whilst fitting the glass..... It's tight to get the glass is
Window winder greased with Silkolene Pro RG2
Glass in position held with tape
Winder mechanism lowered in like this
Thanks for looking
Pete
#1385 jamesquintin
jamesquintin
  • 1,025 posts
Posted 13 January 2018 - 08:59 AM
Where did you get the stainless runner from, and what is the advantage of the red grease over normal grease?
#1386 Jase
Jase
  • 1,167 posts
Posted 13 January 2018 - 04:23 PM
Thanks for looking
Pete
Nice touch with the stainless runners, where did you get these from? Also did you refurb your existing door mechansisms or buy new? Thanks Pete, I have fantastic reference points for my car now.
#1387 Will
Will
  • 1,223 posts
Posted 13 January 2018 - 10:40 PM
Hi there,
Ive just read through your build start to finish. What can I say!? Your attention detail is absolutely incredible and your patience is second to none. Thanks for sharing all the photos, tips, tricks and advice! Ill be keeping a close eye on your thread. Keep up the awesome work!
Will
Edited by Will, 13 January 2018 - 10:41 PM.
#1388 Petrol
Petrol
  • 967 posts
Posted 13 January 2018 - 10:56 PM
I bought the stainless door runners from jonspeed a few years ago. EEK! it's scary how long this build is taking. I've been sourcing parts for years to build this car.
Silkolene RG2 grease is red, no idea why but it's synthetic and gives maximum water penetration protection.
The window winder mechanisms, door catches and latches are all refurbed but the door handles including the boot handle are brand new genuine Rover. Apparently they were "found" at Longbridge when it shut down. I got wise to poor quality aftermarket products and paid a premium for them. Probably money well spent since chrome plating is hard to do now due to legislation. They can't use the chemicals anymore to get that perfect finish.
Paper gaskets are used behind the door handles but it's doubtful if they will do the job. Decided to use butyl tape which will provide a good seal.
Fitted. I tightened the bolts slowly and warmed the butyl sealer up. Excess will be cleared with white spirit
Door catch refurbed and sprayed silver. Fitted new stainless countersunk bolts
Sorry the thread is all over the place. Lots going on with the engine at the moment but I will post everything up together to try to make it a bit easier to read.
Pete
#1389 Petrol
Petrol
  • 967 posts
Posted 13 January 2018 - 11:00 PM
Hi there,
Will
Thanks for your kind words. Can't wait till it's finished and I can enjoy it!
#1390 Cooper1980
Cooper1980
  • 22 posts
Posted 14 January 2018 - 10:34 PM
Read from the start this weekend, amazing work, can't wait for more updates
#1391 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 15 January 2018 - 06:36 AM
Some serious detail going into this, nice work :)
#1392 1330RG
1330RG
  • 224 posts
Posted 17 January 2018 - 09:53 PM
I fell abit behind with the reading. But im glad iv caught up. Has to be one of the cleanest builds of any car iv seen! Excellent work as always mate 🙂
#1393 Petrol
Petrol
  • 967 posts
Posted 26 January 2018 - 10:25 PM
Thanks for the encouraging replies. I'm trying to get the shell sealed to water test it for leaks though I'm having issues getting the screen in. The screen is the right size (checked it against an original) and so is the shell. The Minisport rubber was too big so I bought a "smaller" one. It's now too sloppy. It's hard to imagine how many screens were fitted to Mini's over the years but I can't seem to get one in.
Rivnuts bonded to front lip on bonnet for the trim
Bonnet more or less sorted
Not many parts to paint now. Took advantage of some good weather today
These is the second set of headlight bulbs I have bought, the first ones were from UK but these were from China. Exactly the same part but half the price
I'm still working on it every day but not much to post.
Thanks for looking
Pete
#1394 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 27 January 2018 - 07:43 AM
Have you got a screen rubber from Phoenix trim? I've only heard good things about them and their communication is top notch. I'm waiting on delivery of a couple of items from them myself.
#1395 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 27 January 2018 - 09:10 AM
Nice bulb
