Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#1186 Petrol
Petrol
  • 967 posts
Posted 30 June 2016 - 08:20 PM
Don't know if it's worth posting this up but I masked the back of the bonnet up and sprayed the top -
Base
Clear
Pete
#1187 Wild
Wild
  • 15 posts
Posted 30 June 2016 - 09:26 PM
Looks really good  :thumbsup: Did you spray it outside? If so did you get much dust/insects in it?
#1188 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 01 July 2016 - 12:44 PM
Bonnet looks fantastic. Great finish you have achieved - well doen
#1189 ac427
ac427
  • 676 posts
Posted 01 July 2016 - 05:51 PM
That's a beautiful spray job on the bonnet.
What setup do you use ?
Please don't tell me it is rattle cans, if so you are a god amongst men
#1190 Petrol
Petrol
  • 967 posts
Posted 01 July 2016 - 08:17 PM
Yes but I picked my day. There's a few bits landed on top of the clear coat which will hopefully come out when I wet sand and polish it with the rotary. The main thing is not to have dust/insects between the base and clear coats as these will be visible. By spraying the base coat on in the sun, it soon flashed off so I could get the clear on pretty soon. I guess time will tell if it's OK
Finish is OK but these things always look better in the pics. I'm going to spray the doors (and a load of other panels from another car) in the garage but I need to get the Mini out first
I don't have an expensive gun, it's a Devilbiss Finishline and you can see it on the floor in the second pic. Painting is all about timing and getting enough paint on so it flows out without running in my opinion. Ive read quite a bit about it, especially with metallic's - drop coats and fancy tips for guns but it's a load of nonsense in my book.
For the techie minded they say that a metallic basecoat has to be sprayed on with the gun at the right angle to get the colour / reflection right, especially with pearlescent paints. The reason for this is to get the metal particles to sit at the right angle for reflection purposes. My point is, as soon as you spray the clearcoat on, it melts into the basecoat allowing the metal particles to re-settle with gravity. If you spray the panel the way it sits on the car, there wont be a problem. That's why I sprayed the bonnet flat and the doors will be sprayed upright.
This build has gone a bit OTT now :lol: I'm really looking forwards to getting it on the road though :thumbsup:
Pete
#1191 Wild
Wild
  • 15 posts
Posted 01 July 2016 - 08:22 PM
Aye I'm sure they have, I've only ever done a few sprays jobs never outside though thats why i was curious :) . Done a wing at work for my girlfriends MK6 fiesta and it got a few bits of dust in it in the clear but polished out ok :)
#1192 Petrol
Petrol
  • 967 posts
Posted 02 July 2016 - 07:37 PM
MK3 dizzy splash shield, took me ages to find one of these
Don't know what the rubber seal is for, can't remember my 1973 1000 having one
Pete
#1193 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 02 July 2016 - 07:43 PM
Does the rubber seal not go on the bonnet lip? I could be wrong, can't really go by the size of it in that picture.
#1194 Petrol
Petrol
  • 967 posts
Posted 02 July 2016 - 07:53 PM
Legend :thumbsup:
#1195 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 02 July 2016 - 08:06 PM
Great!  :proud:
#1196 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 July 2016 - 09:10 PM
or does it go along the scuttle lip?
#1197 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 03 July 2016 - 08:44 AM
That too maybe.
#1198 Petrol
Petrol
  • 967 posts
Posted 05 July 2016 - 09:23 PM
Either way, it's another part less to source, thanks guys :thumbsup:
I started flatting the bonnet with some 2000 wet and dry. You can see the bits that are in the clear coat and also the orange peel.
If these don't come out I'll spray it again. I've quite a bit of stuff to paint which I want to do in the garage so I need to get the rolling shell out. The plan is to get the Mini doors done at the same time ;D
Pete
#1199 MacGyver
MacGyver
  • 1,027 posts
Posted 06 July 2016 - 12:44 PM
Nice bonnet! ...Had to say it...
Ps: the seal goes on the scuttle by the way, but it tends to catch leaves and grit so clean regularly. 😀
#1200 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 06 July 2016 - 11:32 PM
I'm not sure that piece is long enough for the scuttle. Plus I'm not sure why a seam trim for the scuttle would come with a distributor shield.
Goes along the rear of the front edge of the bonnet I would say.
    Bing (1)
