Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#1111 Petrol
Petrol
  • 967 posts
Posted 30 October 2015 - 09:15 PM
 A good 998 is very nice, but a 4.33 diff in a road car?  I currently run a 3.9 in a 997 and also in a 1275.  I did think about using a 4.1 in the 997, I'm glad I didn't now.
The 1275 is heavily modified and is used as a hillclimber that can also be used occasionally on the road.  The 997 is an old rally car that I have just completed 1800 miles around Ireland in and it went well.  A 4.33 would be an absolute pain to drive on the road.  Indeed a friend of mine used one for a brief period and promptly took it out.
Your build looks very good otherwise, I like the forethought put into different things.
Thanks for the feedback. Me bad, it was a typo, the diff I'm intending using is a 3.44 - the same as fitted to a Mk3 1000. I assume this will be OK?
Masked the block up
Primed with Pro XL etch primer
Then a few coats of 2K red
Pete
#1112 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 30 October 2015 - 09:16 PM
Nice work that has come out great :)
#1113 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 30 October 2015 - 10:09 PM
I bet you can get it smoother :P
#1114 Petrol
Petrol
  • 967 posts
Posted 30 October 2015 - 10:20 PM
biggrin_zpsa0d34ba9.gif I have read that slapping loads of paint on a block insulates it and reduces heat loss. As far as this build goes, I don't think it's a problem ;D
Pete
#1115 ace01
ace01
  • 457 posts
Posted 31 October 2015 - 10:52 AM
A 3.44 will be ok.  A 3.76 might give you a bit more off the line, but uses a few more revs on the motorway.
Loving the finish on the block.
#1116 MrBounce
MrBounce
  • 2,641 posts
Posted 31 October 2015 - 01:46 PM
Fantastic work as always Pete - looking very good :thumbsup:
#1117 Petrol
Petrol
  • 967 posts
Posted 03 November 2015 - 11:03 PM
Thanks for the heads up.  With the cam, lightened flywheel and CR box I don't think it's going to be great off the line anyway
Thanks,
I'm just waiting for some big end shells and the cam to arrive then I can start the engine build. In the meantime, I'm sorting a few bits out -
Door seals cut to length
These have metal inserts in them
Left unprotected they will rust. The rust stains will then start penetrating the paint on the door step and it's the start of the end. To keep the seal aligned, I used a cut off
Then coated the lot including the metal insert with sikaflex before assembly
Hopefully it will seal providing some protection
Pete
#1118 Jase
Jase
  • 1,166 posts
Posted 04 November 2015 - 10:18 PM
Didn't fancy the furlex ones?
#1119 Petrol
Petrol
  • 967 posts
Posted 05 November 2015 - 08:09 PM
Not heard of those. Do you have a linky?
Pete
#1120 Jase
Jase
  • 1,166 posts
Posted 05 November 2015 - 10:06 PM
It would help if I had spelt it correctly :
https://www.google.c...CFUGfFAodsr4HeQ
I had a set on my Spitfire when I bought it many years ago. Apparently it was standard on some of the Triumphs.
#1121 Petrol
Petrol
  • 967 posts
Posted 05 November 2015 - 11:12 PM
Think I will go for the stock ones. Just for the record, later MPi Mini's had an extra lip on the door seals that went over the inner sill carpet to give a neater finish.
At the moment, door seals are the least of my problems. I'm having major problems with the oil temp gauge/sender I bought. Thought it might be a good idea to test it first and it's about 50% out of calibration  I've also lost count of how many big end / main bearing sets I've picked up that have been wrong wall_zps4on8wb20.gif wall_zps4on8wb20.gif wall_zps4on8wb20.gif
It's pretty simple, Later A+ Block and crank uses main shells with different tangs (these are the cutouts to locate the shells)
This is the tang in the block which is offset
The Tang in the cap is more or less central
So, these shells with all offset tangs won't fit and are for pre A+ engines and A+ up to 1984
I have a lot of patience but this lot is very annoying smash_zps1vfegfkx.gifsmash_zps1vfegfkx.gif
Pete
Edited by Petrol, 06 November 2015 - 08:02 PM.
#1122 CAU998
CAU998
  • 1,202 posts
  • Local Club: TMF South Central...
Posted 06 November 2015 - 08:29 AM
The arch seals are from Somerford Mini. GAW117FK - Fitting kit, standard arches
Thanks for that, don't want to go off topic but don't suppose you know what the four small silver rivets in the kit are for?
Hope you get your parts woes sorted, the engines looking fantastic.
#1123 GraemeC
GraemeC
  • 7,436 posts
Posted 06 November 2015 - 09:17 AM
I had exactly the same issue with ordering/getting the wrong main shells.
However as I was trying to get the engine built and couldn't get any others in a short timeframe, I simply slotted the caps to suit what I had.
#1124 Petrol
Petrol
  • 967 posts
Posted 06 November 2015 - 08:14 PM
The rivets are to fasten the arches to the shell but I used rivnuts.
I've now got the right shells
Marked 0.254 which is 10 thou in old money
Pete
#1125 pmplovesminis2006
pmplovesminis2006
  • 143 posts
  • Local Club: north west mini club
Posted 06 November 2015 - 08:47 PM
great stuff pete the right ones   ,did you give them a good telling off !!!
