Radiator fan cowling has a bracket spot welded to the bottom of it
Seam sealed it to prevent moisture getting in
This could possibly be the biggest change of direction since I started building this car....
It's brand new but a 30 year old close ratio straight cut 4 syncro gear kit. One of the problems with some modern parts is they are made to a tight budget often using poor quality steel and built with poor tolerances - as I found out with the radius arms. Some of these parts are made in China. This however is an old skool Ripspeed gear kit with Jack Knight baulk rings so it should be made of decent materials, the gears should be properly case hardened and hopefully it will last.
I know it's going to whine but on the plus side, straight cut gears transfer more power to the wheels (helical gears loose a bit of energy due to the lateral force) The close ratio gears will open a whole new avenue of cam choices. With a higher lift cam, the CR is less at tickover so I can use quite a lightweight flywheel. With a 3.44 diff, 10" wheels and "half race" cam it might not be such a sloutch despite the 998 engine. The engine is currently being rebored and the crank ground. I am having new cam bearings fitted and everything balanced. I may need a bit of help working out how much to skim off the head but until the block is back, I have no idea of volumes.
I have been at this for so long now but have to say, I'm excited at the direction it's now going
Pete
Edited by Petrol, 27 September 2015 - 09:02 PM.
