Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#1051 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 September 2015 - 11:35 PM
Just had a read through the 200sx thread.
excellent stuff, just as expected.
Ben
#1052 Petrol
Petrol
  • 967 posts
Posted 02 September 2015 - 10:01 PM
Thanks Ben, it's just more of the same really - get rid of the rust and paint.
Whilst I'm painting parts for the 200SX, I'm taking the opportunity to sort one or two bits out on the Mini. The fuel tank for example has a couple of slight dents in it. Rather than use use filler which tends to shrink behind paint causing problems later down the line (called mapping) I'm filling the dents with 2K paint. The drawback with this is it takes some time for the paint to fully cure. Time I have though so I lashed a load of paint on... big run included
Hung it up in the garage and by the time it's flatted back and resprayed, it should be OK
I'm doing the same with the battery box I made
Have to say, the Mini is a pleasure to work on now as everything is clean and rust free.
Pete
#1053 Petrol
Petrol
  • 967 posts
Posted 07 September 2015 - 08:40 PM
Degreased inside of the gearbox and washed it out in hot water
Selector pivot is mild steel so I masked it out using fine line tape
Then sprayed it black
Then cleaned the rest of it up
#1054 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 07 September 2015 - 09:26 PM
Pete,
What did you use to clean the gearbox casing? Did you paint it or is that bare, polished alloy? Great work as always!
#1055 Petrol
Petrol
  • 967 posts
Posted 08 September 2015 - 07:27 PM
Its bare alloy. I cleaned it up with this fine abrasive brush
Pete
#1056 minimaxie
minimaxie
  • 1,687 posts
Posted 09 September 2015 - 04:12 PM
Pete
ooo that might be just what I'm looking for to take the powder coating off my rocker cover! Do you have a weblink for that Abrasive brush Pete?
Max
#1057 Petrol
Petrol
  • 967 posts
Posted 09 September 2015 - 08:36 PM
Hi Max,
Might not be aggressive enough for powder coatings. They do two types, red is coarse and blue is fine
http://www.ebay.co.u...=item5404f1ca35
Pete
#1058 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 10 September 2015 - 08:53 PM
Hi Max,
Pete
It's not suitable for removing powder coat. it will just get hot and smudge it i would have thought
#1059 Petrol
Petrol
  • 967 posts
Posted 12 September 2015 - 04:03 PM
Hi Max,
Pete
I have a coarse wire brush coming, will give it a try on some powder coat
Fitted the rear  glass
I modded the shell to get these fixed rear 1/4 windows to fit properly
Pete
#1060 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 12 September 2015 - 04:10 PM
Looks great, what the difference in the shell for the 1/4 windows?  What adhesive did you use to bond your subframe/floor panels on? I need some for strengthening my bonnet but not sure what to use.
#1061 Petrol
Petrol
  • 967 posts
Posted 12 September 2015 - 05:11 PM
It's not the shell that's different, it's the glass. Fixed glass is not available tinted so I had to use the opening style glass as I wanted tints. I had to close the aperture slightly to get them to fit properly.
The best stuff for metal bonding is an epoxy adhesive
http://www.ebay.co.u...=item56556b4277
Pete
#1062 Petrol
Petrol
  • 967 posts
Posted 13 September 2015 - 05:45 PM
Radiator cowling shot blasted
Primed with Electrox
Arches sprayed
Centre console upright sprayed with clearcoat
Pete
#1063 bluemini17
bluemini17
  • 158 posts
Posted 13 September 2015 - 10:12 PM
very impressive work :proud:
#1064 Pauly
Pauly
  • 4,213 posts
Posted 14 September 2015 - 02:50 PM
Fantastic build!
What degreaser did you use to get the black oily stains off the inside of the gearbox case?
#1065 minimaxie
minimaxie
  • 1,687 posts
Posted 14 September 2015 - 07:59 PM
Hi Max, Might not be aggressive enough for powder coatings. They do two types, red is coarse and blue is fine http://www.ebay.co.u...=item5404f1ca35 Pete
Just seen this, cheers for the reply and for that link Pete!
