Progress has been slow due to other commitments but I'm hoping to get lots of stuff fitted to the shell quite soon.
Inside the fuel tank only had slight traces of rust so I filled it with deox C and left it overnight. I then rinsed it out and dried it out with a hairdryer. With the sender and cap out it soon got hot and dried out. I then sprayed a load of WD 40 inside it to stop any further rust forming. After cleaning the outside with panel wipe to get rid of any WD 40, and a quick wire brush....
I sprayed on 2 coats of Electrox zinc primer. This will be followed by a couple of coats of epoxy 2K black.
Before I can fit the tank I need to fit the rear shocks which I don't have yet. The problem is, I don't know what shocks to buy. The main focus of this car is good road holding and handling - I appreciate there is a difference between the two.
Setup so far is -
Solid mounted front subframe
Hi Lows on new rubber cones
Adjustable tie rods
Adjustable lower arms
Rear camber / toe brackets
Wheels will be 5 X 10
Rubber will be Yoko A032R's
I want adjustable for obvious reasons but on the softest setting, I don't want them to be too stiff as this can lead to skipping on undulated road surfaces. At the end of the day, It's a road car not a track car.
All comments are welcome on which route I should take with the shocks.
Thanks for looking
Pete
