Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#991 Petrol
Petrol
  • 967 posts
Posted 06 June 2015 - 10:25 PM
These are the shims for the radius arm shafts
If parts were manufactured to the right tolerances, you wouldn't need this kind of crap.
They fit behind the thrust washer to space it out.
Almost a rolling shell now :proud:
Big thanks to Phil who has helped me no end on this project ;D
Pete
#992 GraemeC
GraemeC
  • 7,437 posts
Posted 07 June 2015 - 06:21 AM
Where did you get the shims from? I could do with some myself!
Edited by GraemeC, 07 June 2015 - 06:21 AM.
#993 Petrol
Petrol
  • 967 posts
Posted 07 June 2015 - 09:50 PM
A friend of mine gave them to me. He told me they came with a radius arm service kit but I will ask him.
Guess this is a bit of a milestone, after 2 1/2 years, it's now a rolling shell
Pete
#994 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 07 June 2015 - 09:52 PM
Big step forward!
#995 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 08 June 2015 - 07:11 PM
Wow! What a treat this mini is to see. That paint finish is out of this world.
#996 Petrol
Petrol
  • 967 posts
Posted 14 June 2015 - 07:20 PM
Pete
#997 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 14 June 2015 - 07:26 PM
that looks incredible!
#998 johnR
johnR
  • 2,297 posts
Posted 14 June 2015 - 09:37 PM
Lovely looking head - what are you thinking of using to finish the bare metal surfaces that will still show once the rocker cover is on etc?
john
#999 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 15 June 2015 - 04:38 PM
john
The oil that will inevitably leak out from the crappy cork gaskets will protect that just fine :lol:
#1000 Jase
Jase
  • 1,166 posts
Posted 15 June 2015 - 06:26 PM
Stunning Pete, love the attention to detail!
#1001 Petrol
Petrol
  • 967 posts
Posted 15 June 2015 - 09:38 PM
Thanks guys. If Dynax UC would stand the heat, it would protect it. Engines don't get that hot and I sprayed the head with normal 2K car paint.
Next up is the gearbox
First job is to remove the NS diff output cover
Then the OS
There is a ball and spring behind this one that pops out
Lock tabs and diff housing bolts removed
Diff backplate removed
Diffy out
Speedo housing removed
Pete
#1002 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 June 2015 - 08:38 AM
Are you rebuilding the box yourself?
#1003 Petrol
Petrol
  • 967 posts
Posted 16 June 2015 - 08:40 PM
No, never done one before. A good friend is going to help me out :thumbsup:
Baulk rings / bearings / layshaft need checking. I also have a brand new 2nd gear if needed (£75 - Ouch)
It will also have a central oil pickup pipe and X pin Diff. FD will be a 3.44 so as the title says, it's gonna be screaming it's nuts off :lol:
Pete
Edited by Petrol, 16 June 2015 - 09:34 PM.
#1004 Petrol
Petrol
  • 967 posts
Posted 19 June 2015 - 09:26 PM
The rest of the box is being stripped tomorrow. I have a good idea of whats needed but you can't beat an expert eye on things ;D
I need a 3.44 diff and centeral oil pickup pipe if anyone has one.
Got this lot so far
X Pin Diff
New 2nd gear just in case. I have been told these are not easy to get hold of
Full bearing kit
Experience tells me that unbranded bearings are a nono so I won't be using those. Plastic cages on needle rollers? Epic fail in my book
Stripped the paint off the 5 1/2 gallon fuel tank with this poly strip wheel. These don't remove much in the way of metal
Came up like this
Just needs a quick blast to get rid of any pitting
Pete
Edited by Petrol, 19 June 2015 - 09:29 PM.
#1005 evansisgreat
evansisgreat
  • 1,103 posts
  • Local Club: Not yet
Posted 20 June 2015 - 06:35 AM
Those strip wheels are fantastic. I have some little 50mm roloc ones and I've found I can be very precise.
I like the switch to the 5 1/2 gallon tank, I've got hold of one too. Are you planning on twin tanks?
