Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#961 zeemax89
zeemax89
  • 129 posts
Posted 25 March 2015 - 01:14 AM
Ross, one of those guns should do a whole Mini - shell included. Just a reminder to always clean out a new gun, there can be cutting fluid inside after the machining ;D
I have dug some more pics out of the inner wing / shock mount arrangement zeemax89.
With the inner wing cut out, you can see the flanges on the X member
These are what I welded in. Left to right-
Inner wing stiffener, this was the extended plate
Inner wing repair plate - to repair the hole in the inner wing
Inner wing to X member brace
First job was to weld the repair plate into the inner wing. At this point it wasn't welded to the X member flanges
The inner wing stiffener goes between the inner wing and the X member flanges so that's 4 layers
Inner wing
X member flange
X member brace
I spot welded the lot all in one go
I can post a pic up of the finished job but it's easier to see without seam sealer and paint.
Hope that helps and thanks domdee for the pics :thumbsup: I should have both the plates and the adhesive soon. Iv'e got a great idea :D
Pete
Many thanks for the pictures.  I was more asking about the rearwards edge of the spreader.  looking at your last image you can see it nearly but not quite meets the vertical flange of the firewall / bulkhead panel.
That's given me all i need for now.  Hope you don't mind if i pop in from time to time with more questions.  Loved your thread and all the detailed descriptions and pictures, I found it very informative.
Regards
George
#962 Petrol
Petrol
  • 967 posts
Posted 26 March 2015 - 10:57 PM
Hi George,
The rear edge of the spreader isn't welded to the the bulkhead. These pics might help. Ignore the primer, these were taken before I stripped this section down.
As always, any Q's just fire away ;D
Pete
#963 Petrol
Petrol
  • 967 posts
Posted 30 March 2015 - 10:10 PM
I went over to Minisport at the weekend to have a look at some cars with solid mounted front subframes. I couldn't see any difference in the shell construction to mine. There was even an original BMC works rally car there which I paid particular attention to. Maybe the steel thickness of older shells was the key
Belt and braces approach is often best in this situation so these are the stainless plates I bought - 3mm thick
They need trimming but will be fitted here
A 2K adhesive is required for such a large surface area bond. 1K products are air drying and would take forever to cure. This stuff is ideal
http://www.ebay.co.u...=item56556b4277
Should be strong enough when done
Pete
#964 vsl_london
vsl_london
    Just On Tickover
  • 9 posts
Posted 30 March 2015 - 10:57 PM
Project keeps looking better every day, so much I've learnt reading from this already. Thanks for taking the time to document all this! :)
Out of curiosity, when you painted the vents and the mating surface on the brake discs did you need to take any special precautions (like applying too much paint)? Also, that's just standard caliper paint, right? Really tempted to do this myself since I have the set ready to be fitted soon :)
Nice touch with the foam in the drawers, will definitely need to do that for mine as it's currently looking like the inside of my girlfriends purse  >_<
Keep up the amazing work!
Victor
#965 GraemeC
GraemeC
  • 7,437 posts
Posted 31 March 2015 - 07:18 PM
No difference in shell construction, the difference is where the subframes are mounted.
Edited by GraemeC, 01 April 2015 - 07:22 AM.
#966 Frank the Tank
Frank the Tank
  • 530 posts
  • Local Club: Yet to find one local - ish
Posted 01 April 2015 - 07:52 PM
Your attention to detail makes me sad, I really hope I move up the waiting list for a garge so I can get a project and apply even half of your commitment.
Epic build thread.
#967 Petrol
Petrol
  • 967 posts
Posted 02 April 2015 - 10:01 PM
Victor
Hi Victor,
It's just standard caliper paint. I have done this on many cars and not had any problem painting the drive flange. It's best not to go mad on paint thickness though, I sprayed a light dust coat on first, then put just enough on to cover. The drawers are great, it makes it so much easier to find stuff and will save time in the long run.
Thanks, looked more into this and have decided to do the mods as below.
Epic build thread.
I have refurbed a couple of cars outside but it's hard work. I started this project on the drive but a change in personal circumstances enabled me to use the space in the garage again. The best advice I can offer on any rebuild is don't be in too much of a hurry to get it done. It takes time and rushing, often leads to mistakes.
Thanks for the kind words guys, this is where I am up to with the front subframe-
As GraemeC pointed out, there is no difference in the shell. The solid mounted subframes are totally different to the rubber mounted ones-
Rubber mounted subframes bolt only to the toe board. Early solid mounted ones also bolt through the floor like this
The proper way to solid mount a late model car is to buy an early subframe and weld the rear "arms" onto the later subframe. This will give the correct mounting arrangement. This project is a bit beyond doing that so this is the plan.....
3mm stainless plates I made to reinforce the toe board ready to be bolted and bonded on
I can't mod the subframe now but by welding an additional plate that runs under the floor like this
Will replicate the original setup.
Pete
#968 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 03 April 2015 - 06:50 AM
Hi, I might have missed something in this project thread but why don't you use a Polly bush kit to mount the subframes?, So you get a good compromise between rigidity and ride comfort. I intend to use one on my next project as they get good reviews. They should help cut down on noise as well.
#969 Petrol
Petrol
  • 967 posts
Posted 03 April 2015 - 09:02 PM
That was the original plan. I bought a full poly kit but after some research, I won't be using any, not even on the suspension bushes. Instead I'm locking the front subby and using stock type rubber bushes on everything else. Have a look on page 63 post #937 for more info on locking the front subby
Pete
#970 gadget555
gadget555
  • 152 posts
Posted 03 April 2015 - 10:38 PM
Stunning! :-)
#971 Petrol
Petrol
  • 967 posts
Posted 16 April 2015 - 10:14 PM
Thanks gadget555. I've paid a lot of attention to detail on this build but at the end of the day, it's all about the drive. I hope it lives up to my expectations.
I haven't updated this thread for a while but whilst waiting for the front subby plates to be welded, Ive been sorting lots of stuff.....
Steering column cleaned up ready for paint
It's a MK3 innards with a MK5 welded over the top to increase rigidity.
Made a new battery cover out of plastic covered foam, light and a bit more durable than the stock item
Started building up the carbs, only the bodies are left of what I bought, everything else is new
Also started cleaning engine parts up
Pete
#972 vsl_london
vsl_london
    Just On Tickover
  • 9 posts
Posted 20 April 2015 - 10:54 PM
Hi Pete. Don't suppose you might have a guide for making the battery cover? My old cardboard one is on it's last legs and I'd really like to try my hand at making something more sturdy. The replacement you've made look top notch (very much like the rest of the project...) Thanks in advance!
Victor
#973 Petrol
Petrol
  • 967 posts
Posted 22 April 2015 - 09:57 PM
Hi Victor, All I did was mark out the shape of the old one on some foamalux then cut it out. I used a 2 part superglue to bond it all together. The plan is to paint / cover / wrap it so it looks a bit better. I will post up the details when I do some more work on it.
Back to the subby mounts, this is what I have ended up with
These plates not only stiffen the toe board, but now run under the floor like this - OS
NS
I have drilled the shell (EEK!) to bolt them on. The pics are a dry fit but by the time these plates are both bolted and bonded on, it will be stronger than an early solid mount arrangement.
Pete
#974 Petrol
Petrol
  • 967 posts
Posted 24 April 2015 - 08:09 PM
Masked the body up for a neat finish with the panel adhesive
Adhesive is best applied to both the shell
And the plate
Bolted on
That should be strong enough to bolt the subby straight on ;D
Pete
#975 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 24 April 2015 - 10:00 PM
I don't think that's moving in a hurry!
