Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#946 Petrol
Petrol
  • 967 posts
Posted 20 March 2015 - 10:18 PM
Hi Ross, this sounds so simple but runs are caused by too much paint applied too quickly. Oh and yes I have the T shirt and cap on this one! Wheels can be a right pain to paint and it’s just a case of taking your time to try to get even coverage. This is how I sprayed the Minifins –
First coat (always very thin) went on at this angle. This covered only one side of the fins (red arrow) The blue arrow shows where no paint went on
Second coat went on from the other angle painting the other fins. The problem is that the middle section indicated by the red arrow now has 2 coats on it
The only way to prevent runs is to allow enough time for the paint to tack off before the next coat. The more coats you apply, the longer it takes for the last coat to tack off. It's tempting to move the gun in close to get some paint on a localised area but doing this, increases the risk of runs. I put a total of 4 coats on the drums - so that's 8 coats between the fins! It's not easy and I hope that helps.
I want the car to look pretty much stock so spraying the drums black will hopefully hide the upgrade.
I have no concerns about the stainless bolts holding the rear subframe on Gr4h4m, Minisport sell a complete kit for this and whilst stainless has only 80% the tensile strength of high tensile steel, I think it's more likely that the captive nuts in the heel board would let go first. Either that or the brittle cast steel trunnion brackets would fail.
Since most of the load and forces are on the front end on a Mini, everything on the front has been built up with HT steel stuff.
YW fwdracer, I know what you mean about late model shells, I cant believe how bad this was for a 1998. There's nothing left of what I bought! I didn't mention it but the rear radius arms were beyond repair and have been replaced. The bolts holding the front lower arms to the tie bars were seized solid so I binned the lot. The front upper arms were beyond repair. I have replaced just about everything.
This mod / upgrade / downgrade was a bit pointless really and took hours to fabricate. It's a MK3 steering column with early Mk3 indicators / wash wipe. Ignition barrel / cowling is MK5
Pete
#947 slidehammer
slidehammer
  • 1,206 posts
  • Local Club: LSMOC
Posted 20 March 2015 - 10:47 PM
great looking paint finish, is that 2k paint? also what brand of gun is that you were using to get such a great finish?
#948 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 21 March 2015 - 09:58 AM
Hi Pete
Look on page 35 of the latest MiniWorld mag to see some bulkhead, floor strengthener plates. Might be worth considering opposed to the bonding idea you are thinking of...
#949 Petrol
Petrol
  • 967 posts
Posted 21 March 2015 - 09:03 PM
I used 1K caliper and drum paint. The gun I used was a "fast mover" and cost only £12. It's not the gun that gives the finish though it's the amount applied and time between coats ;D
http://www.ebay.co.u...=p2054897.l4275
Hi Pete
Cool, thanks. Is it this issue?
http://www.pocketmag...d#5243f9bb35788
Pete
#950 slidehammer
slidehammer
  • 1,206 posts
  • Local Club: LSMOC
Posted 21 March 2015 - 10:11 PM
Cheers Pete
Great gloss straight from the gun. Also a great price on the gun, I would have thought for that money it would have been hopeless. Which obviously is not the case.
#951 Petrol
Petrol
  • 967 posts
Posted 21 March 2015 - 10:29 PM
Cheers Pete
NP. Have a look at this - post #1290 on how to apply paint to small parts
http://www.sxoc.com/...a-refurb/page65
Pete
#952 domdee
domdee
  • 1,183 posts
Posted 22 March 2015 - 11:14 AM
Number 278 Pete. It's only a small picture so I could send you a snap rather than you buying it.
#953 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 22 March 2015 - 11:03 PM
Thankyou very much for taking the time to explain Pete, I'll also order one of those guns, looks much easier to manoeuvre around small objects compared to my 600ml one, I was staying away from the really cheap guns, but the results you're getting from it alone is solid enough evidence.
#954 Petrol
Petrol
  • 967 posts
Posted 23 March 2015 - 11:15 PM
Got the pic. Thanks very much for that. I have some stainless plates on the way so will have a think about my plan when they arrive  :D
No prob. These small guns are great for getting round those hard to reach places. Sometimes budget stuff is OK though I have probably gone through 4 or 5 of those guns in the last 5 or 6 years. Talking of tools I've been frustrated with poor storage and my ageing tool kit. Some if goes back to the early 80's. Decided to have a major overhaul and get it sorted. This was my tool box
Not easy to find anything in there so I have bought this
Had some foam cut for the drawers. This should make things easy to find
Sockets are going in here
It came with a load of tools but the plastic containers waste space and will probably break
The foam is a better arrangement
More stuff to go in
Hopefully I will be spending less time looking for stuff and more time working ;D
Pete
#955 RossKnight
RossKnight
  • 2,539 posts
Posted 23 March 2015 - 11:48 PM
Very organized! Although, I think most of my tools would end up just being thrown on the top of it after a while haha.
Well for that price, even if I only get a few uses out of it, it'll be worth it. I've ordered one :)
#956 zeemax89
zeemax89
  • 129 posts
Posted 24 March 2015 - 12:10 PM
Bit more info in case it's useful to anyone
This is the original setup. The X member brace finishes very close to the inner wing stiffener
Any force from the X member will be concentrated on this area and since there's only about an 8mm distance to the stiffener, the whole load will end up on the single skin inner wing. Not ideal.
This is the new stiffener
By extending it further forwards it will spread the load over a greater distance rather than concentrating it one place. It will also reduce the leverage on the inner wing from the X member
Hoped that made sense and was helpful
Pete
Thanks for the images Super mini mad.  this is exactly where I an right now.  can you remember is the stiffener is welded to the bulkhead edge or just meets it?  Hard to explain what I mean.  Behind the crossmember, there is a right angle on the edge of the bulkhead wall.  I suspect the inner wing spot welds to that and the stiffener just meets the flange
thanks for the pics, very helpfull
#957 alchall
alchall
  • Just Joined
  • 604 posts
Posted 24 March 2015 - 03:55 PM
 Hi, any chance I could also get a copy of the picture, I'm almost onto new toe board fitting so would be good to see this....
#958 domdee
domdee
  • 1,183 posts
Posted 24 March 2015 - 04:01 PM
7823C34D-787C-481E-BC2B-E33EC56FEB06_zps
F593A04F-46E9-40A3-931B-4B8D92705DBB_zps
#959 alchall
alchall
  • Just Joined
  • 604 posts
Posted 24 March 2015 - 04:20 PM
Fabulous, thanks!
#960 Petrol
Petrol
  • 967 posts
Posted 24 March 2015 - 10:26 PM
Ross, one of those guns should do a whole Mini - shell included. Just a reminder to always clean out a new gun, there can be cutting fluid inside after the machining ;D
I have dug some more pics out of the inner wing / shock mount arrangement zeemax89.
With the inner wing cut out, you can see the flanges on the X member
These are what I welded in. Left to right-
Inner wing stiffener, this was the extended plate
Inner wing repair plate - to repair the hole in the inner wing
Inner wing to X member brace
First job was to weld the repair plate into the inner wing. At this point it wasn't welded to the X member flanges
The inner wing stiffener goes between the inner wing and the X member flanges so that's 4 layers
Inner wing
X member flange
X member brace
I spot welded the lot all in one go
I can post a pic up of the finished job but it's easier to see without seam sealer and paint.
Hope that helps and thanks domdee for the pics :thumbsup: I should have both the plates and the adhesive soon. Iv'e got a great idea :D
Pete
    Bing (2)
