Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#886 Petrol
Petrol
  • 967 posts
Posted 31 January 2015 - 12:21 AM
Whilst the weather is bad, I'm trying to get through a snagging list as long as your arm. These things seem to swallow vast amounts of time and this is one of them.
These are the rear door cards I bought
Staples are not the best way to fasten a covering on so I took it off
At this stage I also fitted some new wheel arch covers, mucho impressed with these
Glued on with spray adhesive
Companion bin plastic liners have lugs on them
Which fit into slots on the rear hardboard cards - these are the original's
Decided to go for a better fastening option
Marked out where the bin liner goes with masking tape. It's often easier to use tape than a pencil ;D Then made this wood support
Re fitted the vinyl covering using spray adhesive. The rear cards are convex when fitted, this should prevent the covering looking baggy
Then sprayed adhesive on the back to prevent the vinyl from peeling back
Cut the lugs off the bin liners, the wood will now support the liner
Hopefully the finished job will be posted this weekend
Pete
#887 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 January 2015 - 12:38 AM
lovely stuff
#888 Mini Waco
Mini Waco
  • 438 posts
Posted 31 January 2015 - 12:40 AM
Pete, how vast is your creative mindset?  Body work, electrics, upholstery... simply a hard act to follow.  Brilliant!
#889 seancv1
seancv1
  • 187 posts
Posted 31 January 2015 - 04:48 AM
very much enjoyed reading through this :-)
#890 Petrol
Petrol
  • 967 posts
Posted 31 January 2015 - 10:51 PM
Thanks, however rather than getting up to mischief, I was the kid with the science and chemistry kits :geek:
Sealed the hardboard to stop it getting damp in, than taped around the edges of the vinyl
Fitted
Funny you should mention electrics Mini Waco, the plan was to keep everything very simple like a MK3. Not many fuses (IIRC they had 3) no relays and that was that!
Yer right, "av a load of this lot" I really didn't want to have to install
Relays
Not 4........
But 8. Not too pleased about this lot really. Savage switches won't take the current so it goes like this
1 Heated rear screen
2 Sidelights
3 Headlights
4 Headlight inhibit - this switches the dipped lights off when the beam is switched on
5 Hazards - Stock switch is a 3 pole, Savage switch is only 2
6 Hazards (2) Needs this to enable the hazards to work with the key out. Otherwise the indicators will work without the key. The flasher unit would also drain a small amount of current
7 Air horns :P
8 Spare
There's also 2 in the bay for the spotlights.
Then there's the switch illumination. Bit bright when on and no dim illumination when the side lights are on.
The solution is this lot :ohno:
Resistors and diodes.
Pete
#891 Jase
Jase
  • 1,166 posts
Posted 01 February 2015 - 08:29 AM
Any pictures of the savage switches Pete. Love the attention to detail. It would never have occured to me to seal the back of the boards.
#892 Petrol
Petrol
  • 967 posts
Posted 01 February 2015 - 07:34 PM
Pete
#893 Petrol
Petrol
  • 967 posts
Posted 07 February 2015 - 12:08 AM
Still working on the loom and also more importantly the driving position.
Don't know if this is worth posting up but it may be of use to someone... Since I'm quite tall, the original plan was to extend the steering inner column but aligning the extension would have been a hassle. I found an easier way -
This is a Moto-Lita extension tube
It adds an inch. This is the boss that fits the the wheel, note the marking "top" which is important
The reason for this is are the rawl pins that fit into the boss.
Which cancel the indicators like this
Looks like this now
The downside to extending is it puts more leverage on the column
The current plan is to beef up the outer column
Pete
#894 Petrol
Petrol
  • 967 posts
Posted 14 February 2015 - 12:35 AM
Bit more work on the wiring done. These are diodes and resistors to enable the savage switches to be illuminated with the side lights, and brighter when switched on
To prevent a short circuit, one side is insulated first with shrink wrap
Then the other
All the relays are wired now, to the left of them is the power supply for the sub. I had to make a bracket to support that
Fitted some sound insulation behind the bulkhead - still work in progress
Testing the radio which seems to be working OK
Pete
#895 montyc
montyc
  • 308 posts
Posted 14 February 2015 - 11:49 PM
Hi there,
Sorry if ive missed the answer but where are your rear bin liners from?
#896 Langers#56
Langers#56
  • 39 posts
  • Local Club: London and Surrey
Posted 15 February 2015 - 12:49 AM
Mika is a bit concerned with the standard of welding that I have done. I know the theory but putting it into practice is a different story....
I would welcome your comments as welding is something I have little experience in
Butt weld on a boot floor piece
Other side to show penetration (or lack of it)
I am looking for some help please
Pete
Too Cold get the Juice up best thing is try on scrap first
#897 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 15 February 2015 - 03:18 AM
Youre 54 pages behind pal ;)
#898 Petrol
Petrol
  • 967 posts
Posted 18 February 2015 - 10:38 PM
Hi there,
The plastic bin liners were ftted as standard to late model Minis
Thanks, I got the hang of it after some practice.
Butyl sealant around the dashboard vents
Fitted with plastic washers and stainless self tappers
Seam sealed the front subby
Rear subby is finished
This rolled up today. A 2001 Cooper Sport - A project for later down the line ;D
Pete
#899 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 February 2015 - 10:41 PM
You bought another one??
Yikes!
Edited by Ben_O, 18 February 2015 - 10:41 PM.
#900 pmplovesminis2006
pmplovesminis2006
  • 143 posts
  • Local Club: north west mini club
Posted 19 February 2015 - 07:20 AM
another mini peter !
i thought that would be your worst nightmare!!
