Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#826 Petrol
Petrol
  • 967 posts
Posted 02 January 2015 - 11:09 PM
I agree Ben ;D
I've been holding back buying trim, fixtures and fittings as storing them is a right pain. Unfortunately, the time has come where I have no option but to buy em to trial fit - like the grill. The rivnuts I put in the front panel lined up OK
Low profile button head stainless bolts fasten it on
Hopefully (Yer right) this is the last time the shell will be on the spit. I'm using the injection system vent pipe for the fuel supply to a conventional mechanical fuel pump. The pipe and fixings look better to me than any other option like running a braided all the way.
Used a stainless P clip under the boot floor
For added protection, I used some shrink wrap where the clips fit
Also fitted the rubber blanking grommets to the floor. Rather than buying Mini specific parts, I bought some 20 & 25mm electrical blanking grommets
Progress is slow at the moment as I'm spending an awful lot of time on details, one of which is the steering column arrangement. The original plan was to use the MPI column & switchgear but for a number of reasons, mainly the rotary coupler,  that's not going to happen. I prefer simple so I'm now going to fit a MK3 column and switchgear
Pete
#827 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 January 2015 - 11:16 PM
Now that shrink sleeve idea is excellent!
#828 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,021 posts
Posted 02 January 2015 - 11:18 PM
Excellent work, I'm going to fit p clips to hold my fuel pipe and brake pipe on, Would there be a down side of using rivnuts and a bolt rather than what a nut and bolt?
+1 on the heat shrink idea
Edited by alex-95, 02 January 2015 - 11:19 PM.
#829 Mini Waco
Mini Waco
  • 438 posts
Posted 02 January 2015 - 11:22 PM
Pete, I see several different type of vent pipe fitting.  Are these different than the one you removed and if so, did you prep the holes prior to fitting and finishing the body?  Also, what kind of fittings are they.  I see the P-clips, but what are the others?
Looking really good
#830 Petrol
Petrol
  • 967 posts
Posted 04 January 2015 - 12:16 AM
Yes, rivnuts protrude a lot on the back side and it's not a good idea to have these sticking up inside of the floor. It could wear the carpet out and at worse, loosen the fixing. I used domed head, stainless allen bolts as these are low profile...
This one is under the back seat base, the last thing you want is a rivnut sticking in your backside yes_zps01e0e81b.gif
Looking really good
Hi Mate, (Happy New Year to you)
The plastic clips were a stock fitment on these late model Minis so don't worry about those. The best bet is to remove the metal tabs, drill holes and just use stainless P clips. If I had my time again, I would have got rid of those plastic clips and used P clips throughout.
Might be worth a mention that this build is not for the purist. Oh no! It's been called all sorts of names like "Frankenstein" and "Mini MK 3.4.5" I have no doubt that this will effect the ultimate value of it but I'm not building for that ;D
Fitted the vinyl trim across the back parcel shelf / C pillars. Used Evo stick to glue it on, excess can be removed with white spirit ;D
Then the carpet up the C pillars. This is MPI specific due to the rear parcel shelf to C post stiffening brackets. (Just to add, this is why I bought an MPI - the shell is a bit more rigid)
Pete
#831 mark-stranraer
mark-stranraer
  • 62 posts
Posted 04 January 2015 - 12:50 AM
Tidy work! Attention to detail :D
#832 scudracer
scudracer
  • 25 posts
Posted 04 January 2015 - 03:21 AM
Awesome. I've been thinking about fuel line installation as my floorboards are locally fabricated (hammered out from sheet steel) with no clips or provision for fuel lines. I believe original floorboards had some tabs that can be bent over to secure fuel lines. Your pictures are awesome and I'm going to copy what you've done. Thanks for posting!
#833 Petrol
Petrol
  • 967 posts
Posted 07 January 2015 - 11:25 PM
Your welcome scudracer. The original floors did have some tabs to secure the brake and fuel lines but if your not after originality, P clips are much better.
I have started to fit the loom and have run into complications specifically with the horn. Long story and I won't bore you all with it but I'm now going to fit a MK3 steering column and switchgear - wipers, indicators and horn on the stalk. This will also get rid of the unreliable slip ring fitted to the MPI.
The bottom line is I can now fit this classic Mini steering wheel
Building this "hybrid" is not as easy as I thought. It's amazing how Mini's have changed over the years :huh:
Pete
#834 evansisgreat
evansisgreat
  • 1,103 posts
  • Local Club: Not yet
Posted 08 January 2015 - 10:25 AM
That's an awfully nice wheel. Did you think about the wood and pickett MPI conversion? It's quite pricey mind you. I really like the MPI column switches as it combines and headlight and wiper switches and simplifies the dash.
I know all about the dodgy airbag slip ring, but you can get a new one for around £15. That was the cheapest fix I ever had to do for an MOT with my mini :lol:
#835 Petrol
Petrol
  • 967 posts
Posted 09 January 2015 - 11:33 PM
I did think about the Wood and Pickett boss with the Moto Lita fitment. I liked that particular wheel but it doesn't have a center push horn so that was that. Also, the way the slip ring fits into the wheel on the MPI looked like a poor setup and I don't want problems down the line. This car will be in the family for a very long time. I have took advice every step of the way on this build trying to get it right. For example, I bought the wheel from an old skool guy of ebay and his advice was to get rid of the slip ring. Not convinced, I took advice from other well recognised organisations - you know who I mean ;D
It's more complicated than that - The MPI has proper bearings within the steering column, earlier models had felt / nylon bushes. I wanted to keep the MPI column but have run into problems dismantling it - I can't get the centre shaft out..... I also want to extend the steering column. This lot is causing no end of problems at the moment.
It's funny how things change, the original plan was to rebuild this Mini to teach my lad how to re-furbish a car. He gave up on it long ago and now it's turned into a "Non originale, Copper mini build" The thread title is a tad out of date. Is it possible to change it?
Pete
#836 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 09 January 2015 - 11:49 PM
Pete
You can PM any of the TMF staff and ask. sonikk4 is a good bet
#837 Petrol
Petrol
  • 967 posts
Posted 10 January 2015 - 12:07 AM
Pete
It's probably not worth asking...
Pete
#838 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 10 January 2015 - 12:33 AM
Plenty of others do...
#839 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 10 January 2015 - 11:17 AM
Go to you're first post, full edit and should be able to edit it yourself.
#840 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 10 January 2015 - 12:02 PM
It's true, you can!
I just checked it on one of my threads. I never knew that!
