Mini Cooper 998 Screamer Nut And Bolt Rebuild
#721
Posted 28 September 2014 - 07:52 AM
#722
Posted 28 September 2014 - 11:31 AM
That is utterly amazing! Once the shell is fully painted and cured, do you think it will take you long to rebuild the car?
#723
Posted 29 September 2014 - 10:01 PM
Thats superb. Ive seen worse come out of a booth, professionally painted and flat and polished. Looking forward to the final paint.
Thanks but pics can often hide a multitude of sins. The main reason I sprayed it flat blue (not metallic) is to check for panel straightness / ripples and on that front, I'm happy with it. I mentioned a pressing mark in the front scuttle. I noticed this as soon as the first coat went on so I sprayed quite a bit of paint on that area. I have now flatted it back and got rid of it :)
I don't know Steve220, whilst the shell is by far the biggest job, I have an engine and gearbox to rebuild. There's also quite a bit of custom fabrication which can take a lot of time. To be honest I'm enjoying the build and don't really care how long it takes. If I had every part ready to go on, it would take about a week to assemble though.
#724
Posted 30 September 2014 - 07:24 AM
Holy crap..... Thats superb !!!
#725
Posted 30 September 2014 - 12:25 PM
Hi Petrol,
Could Iask if you are using 2-pack or water based paint?
Paul.
#726
Posted 30 September 2014 - 07:32 PM
Hi Paul,
It's 2 pack
Pete
#727
Posted 01 October 2014 - 12:46 PM
Ah, I see. Can you still get a supply of it? My supplier only suppiles aerosols of 2 pack now.
#728
Posted 01 October 2014 - 08:35 PM
2 Pack paint is a 2 part system which comprises of the colour and a hardener. Once mixed it will go hard even if stored in an airtight container. As a result, it's not available in aerosols as it would go hard in the tin. Any bodyshop supplier will be able to mix 2 pack paint to the colour you require. It's worth pointing out that 2 pack paint is hazardous and needs the right PPE.
Pete
#729
Posted 02 October 2014 - 12:19 PM
Thank you.
#730
Posted 02 October 2014 - 10:30 PM
You're Welcome, it's really confusing with all paint combinations available these days -
Zinc primer, weld through primer, 2K primer, POR primer, etch primer, high build primer (in 1 and 2K versions of course)
Colour - Solvent based , water based, 2k solid, 1K colour, clear over base in both metallic and solids, synthetic and acrylic, oh and then there's celly, hammerite original, hammerite smooth engine lacquer. Caliper paint, VHT paint
Clearcoat - (lacquer) 1K & 2K, Then there's hardener for the 2K (also known as activator) available in fast and slow drying versions.
Also, Epoxy paint, epoxy mastic... the list goes on.
It's very confusing but if you are spraying with a gun, it's best to take advice from your local bodyshop supplier
Pete.
Just to add, I'm on a flatting back mission at the moment which is taking some time. I won't bore you with the details but will update the thread when it's ready for the final paint job
#731
Posted 02 October 2014 - 10:31 PM
You forgot poster paint ;)
#733
Posted 03 October 2014 - 06:01 PM
I'm just about to start welding and need to get some paints. With so many brands and types available I (and everyone I'm sure) be really interested to know what you're using and where. So we can copy you.
#734
Posted 04 October 2014 - 09:19 PM
Electrox zinc primer
Original body panels cleaned up & de rusted – Floor pan inner wings etc.
Inside of seams
Inside of door skins
Inside of rear ¼ panels
Subframes
2K Primer ( MaxMeyer CFE etch primer 7050)
New panels both sides, for example wings, front panel.
Bare metal on the top of the shell - roof, bonnet, door steps, A posts etc
2K high build primer
Used on top of the electrox / 2K etch where required, to fill any imperfections or panel warping
Weld through primer
Used before welding in areas that are difficult to get to once welded.
Plastic primer
What it says on the tin
Colour coats
Whole shell was then sprayed with 2K solid blue (solid is non metallic) to check and repair any imperfections. Final paint is a 1K Tahiti blue metallic base coat followed by MaxMeyer HS Clear 0200.
Other parts – brackets/, suspension arms etc. Includes new and zinc coated parts. (Zinc coated parts have a yellow appearance)
Electrox zinc primer followed by 2K black solid. (No clearcoat)
Couple of notes on primers.
Zinc needs to be applied to good clean metal. It requires a good electrical contact to the steel. It’s useless if applied over paint. Similarly, whilst etch primer can be applied over paint, it works by the acid in the paint, etching into the steel to improve adhesion. That’s why I have used it on the top of the shell to reduce the chance of stonechips.
Hope that’s useful
Pete
#735
Posted 08 October 2014 - 12:53 PM
i need to see more of this!
it would be good if the boys doing project binky commissioned you to paint their beast. the best engineering accompanied by the best paint preparation I've ever seen.
