Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#691 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 August 2014 - 10:36 PM
That was a bit of luck with the shot blasting Pete!
What's the next stage on the shell?
Ben
#692 Steve220
Steve220
  • 5,143 posts
  • Local Club: BMC
Posted 23 August 2014 - 11:52 AM
Just spent the good part of a day reading this thread. I take my hat off to anyone that goes to the length of doing a job properly first time. Yours will definitely still be rust free in years to come!
#693 Petrol
Petrol
  • 967 posts
Posted 23 August 2014 - 08:38 PM
Having the subby blasted saved me hours of work. It just needed a quick wire brush in places. I think your right Rally 515, I'm going to leave the strengthening at just the turret tops
Thanks Steve220 but the proof of the pudding will be in the eating. I might end up using this car as a daily drive so it won't take long to find out.
Next job on the shell whilst it's still upside down, is to sort the spot welds underneath the gutter.
First I masked up the interior and underneath
Then sprayed a good few heavy coats on, I don't want to totally get rid of them, just make them less visible
Also primed the front subframe with Electrox
Pete
#694 Petrol
Petrol
  • 967 posts
Posted 31 August 2014 - 10:16 PM
Change of plan with the spot welds on the gutter - Decided to get rid of them completely.
The plan is to get the gutter good enough so I don't have to use the plastic trim. Next I have to fill the spot welds on the top side
I'm filling with paint but it's worth a mention you can't keep spraying paint on. You have to allow enough time for the solvents to evaporate. Spraying over soft paint can lead to all sorts of problems like crazing. The rule of thumb here is respect the solvents ;D
Pete.
#695 exuptoy
exuptoy
  • 674 posts
Posted 31 August 2014 - 10:31 PM
I look forward to your updates Pete. Best thread on here by a long chalk!
#696 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 August 2014 - 10:32 PM
Wise choice Pete
#697 jpw1275
jpw1275
  • 2,803 posts
Posted 01 September 2014 - 06:38 AM
Superb Pete..... I'm glad your bringing your car to the same standard of the carbs....:0)
Cheers james
#698 evansisgreat
evansisgreat
  • 1,137 posts
  • Local Club: Not yet
Posted 01 September 2014 - 08:34 PM
I'm glad you're paying such detailed attention to the gutters. I also want to ditch the gutter trim. I think this is a great detail on early minis; well worth the extra effort.
I'll pay extra attention to this lesson Mr teacher.
#699 FAZ
FAZ
  • 284 posts
Posted 03 September 2014 - 11:33 AM
what paint are you using? cellulose?
#700 Petrol
Petrol
  • 967 posts
Posted 04 September 2014 - 10:10 PM
Thanks guys,
I'm not using celly on this build at all, in fact I haven't used it for years.  I don't think it would be wise to attempt to fill spot welds & imperfections with a 1K type air drying product due to shrinkage / cracking problems.
First job is to mask up. This rolling technique with the masking tape avoids steps in paint. I also don't want any more paint on the underside of the gutter as that's now sorted and not fully cured.
Then sprayed some 2K high build on the roof spot welds & gutter
To flat the paint down inside of the gutter, I made these sanding blocks
First one is a piece of foam glued to a filler spreader. I used this one for the sides
Like this
Then this one for the front and back as the profile is different
Bit awkward to sand in here
After quite a bit of wet sanding, I got rid of the spot weld indentations
Now it's time to move on to the gutter itself. Not done much on this but flatted it back ready for more work
Sorry for the poor pic. I will try to take some better ones as I sort the gutters out. This kind of work needs a lot of patience and like I mentioned earlier, it's important to make sure you allow the solvents to fully evaporate before applying more paint. I have a feeling this gutter fettling is going to take some time :ohno:
Pete
#701 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 04 September 2014 - 10:58 PM
You have the patients of a saint Pete.
This is why this is going to be the most sorted mini on the road
Edited by Ben_O, 04 September 2014 - 10:58 PM.
#702 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 05 September 2014 - 06:02 AM
^^^^ I cant wait to see it finished !!
#703 exuptoy
exuptoy
  • 674 posts
Posted 05 September 2014 - 07:21 AM
Pete, amazing as usual, but can you give some idea as to how long the paint does take to cure? I mean how long did you leave between laying it on and starting sanding and how long before you can lay more paint on now it's sanded?
Also say you were happy with what you've just done and the gutter was now ready, what does the final coat of primer before paint require? Would it now just be a case of gunning on one more coat of primer, a quick flat with say 1200 then the top coat?
#704 Petrol
Petrol
  • 967 posts
Posted 06 September 2014 - 09:54 PM
Drying times depend on lots of things - Temp, airflow, paint thickness and how much thinners is mixed with the paint. As a general rule of thumb though you can wet sand primer after a couple of hours. High build primer needs longer though as it goes on thicker. 2K colour can be wet sanded after about 48 hours.
You only need to prime bare metal, in the case of the gutter it will be sprayed like this
Bare metal - etch primed
2K high build primer sprayed over the etch whilst tacky
Left 48 hours then flatted back - this allows the solvents to evaporate
Left another 48 hours before a colour coat
It's 24C in my garage and I have a couple of fans going to circulate the air, if it's cold you need to increase the drying times.
Pics of the gutter after high build primer and flatted back
Pete
#705 simonwestoll
simonwestoll
  • 19 posts
  • Local Club: LSMOC
Posted 07 September 2014 - 08:12 AM
Nice gutter work, wanting no cracks in mine now...
The gutter being at eye level and a character feature of mini is well worth making the fine job of it that you are.
What product would you use to seal/fill the cracks in 2K paint?
The excellent tip of masking tape rolling technique you show could perhaps be employed on the inner (roof side) of the gutter also to avoid me having to respray the roof.
Edited by simonwestoll, 07 September 2014 - 10:12 AM.
    Bing (1)
