Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#676 Petrol
Petrol
  • 967 posts
Posted 15 August 2014 - 09:30 PM
Thanks guys. Long way to go though, I need to build an engine and gearbox..... and everything else!
2K primer on the stone chip. This is just normal 2K not acid etch. Acid etch is best used on bare metal as the acid etches into the steel to provide better adhesion. Acid on a plastic based surface is not recommended.
Followed by a wet coat of 2K solid (not metallic) There's quite a composite of layers under here now which should offer some serious protection. This was then flatted to get rid of any high spots and leave an even finish. Ive seen cars painted over stone chip and the results can look a bit of a mess. Hopefully this method will provide the optimum base for the metallic paint and clear coat
You can't keep lashing paint on otherwise it will craze, I need to leave this for a good few days to allow the solvents to evaporate.
Pete
#677 Petrol
Petrol
  • 967 posts
Posted 18 August 2014 - 08:34 PM
Final paint underneath
Pete
#678 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 August 2014 - 08:45 PM
It really is looking fantastic Pete.
well done!
#679 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 18 August 2014 - 09:19 PM
Stunning!
#680 deepee71
deepee71
  • 101 posts
Posted 18 August 2014 - 09:22 PM
Looks good to me!!
Andy
#681 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 19 August 2014 - 05:43 AM
Nice work there, looks mint...
#682 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 19 August 2014 - 05:46 AM
this is my fave thread. love looking at your work!
#683 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 19 August 2014 - 08:48 AM
Amazing....... That is all.....
#684 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 19 August 2014 - 01:41 PM
Fantastic work!
#685 72clubman
72clubman
  • 443 posts
  • Local Club: Charnwood Minis
Posted 19 August 2014 - 10:20 PM
Beautiful job.
#686 Marco1972
Marco1972
  • 822 posts
Posted 21 August 2014 - 04:21 PM
Adding to the list of compliments .......
Superb job :-)
#687 rounders
rounders
  • 23 posts
Posted 21 August 2014 - 09:40 PM
When will you have time to do my mini shell should be soon as yours is nearing completion.
Superb job can't wait to see it finished?
#688 minishishi
minishishi
    Just On Tickover
  • 5 posts
Posted 21 August 2014 - 11:06 PM
you should write this up as a book, its the ultimate mini restoration,a definite best seller
thank you for taking the time to record and photo your work, absolutely amazing . . .
and still loads to come, can't wait, I love it.
#689 Petrol
Petrol
  • 967 posts
Posted 22 August 2014 - 09:56 PM
Thanks for the feedback, it’s very much appreciated.
I keep buying parts that will be used later down the line but I’m trying to post updates in a readable order. Funny how things change  :D  I noticed a house around the corner being shot blasted so I took the front subby round. Cost me £20, its not perfect but 99% there
Then seam welded the turret tops
Working a bit back to front here, normally I would have welded up the turrets before shot blasting
I don’t think its worth going mad seam welding the front subby on a road car (correct me if I’m wrong)  The only other welding I intend to do is on the tie rod mounts.
I really need to get this cleaned up and primed pronto as it’s not a good idea to leave bright steel without any protection for long.
This lot has kept me busy whilst the paint is hardening ready for the next stage on the shell ;D
Pete
#690 rally515
rally515
  • 3,848 posts
Posted 22 August 2014 - 10:36 PM
Ahh how convenient having a local blaster to do it! :lol: There aren't any people who blast stone around here, might see about giving someone a call though who does ;)
I agree, the loss in time and effort grinding down welds isn't worth it for a road car, maybe so on a rally stage car that gets a bit of abuse every now and again, but having said that you'd do a lot of other modifications to it if you were rallying too.
Enjoying your updates Pete, still can not believe the finish you're getting.
