Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#496 Petrol
Petrol
  • 967 posts
Posted 21 January 2014 - 11:47 PM
Hi Guy’s,
The hinges are difficult to machine - drilling the welds out of the studs was especially tricky and I ended up using a cobalt drill. Welding the new studs in also has its problems as the studs need to sit flush. I am going to see a pro welder about this as the penetration of the weld is critical. Get it wrong and the doors will fall off. I will post some pics up of when it’s done.
Andy, to answer your questions…
Always apply zinc primer direct to bare metal. Never over a rust killer / converter.
It keys well to bare metal especially if the metal is scuffed with 800’s wet and dry or green scotchbright
Zinc primer will not work on top of any kind of paint – gloss or etch primer.
Hope that helps and if you have any more Q’s, just ask or drop me a PM
Pete
#497 KELT11
KELT11
    Starting My Mini Up
  • 3 posts
Posted 23 January 2014 - 11:34 AM
Hi Pete. Just a word of warning. I've seen after market seat brackets like that damaged the rear floor over a period of time. Leaving the floor bowed. Especially on heavier seats. One of the reasons I try to avoid after market seats. Maybe worth welding a bar across the tunnel to the inner sill on both sides? And fabricate your seats to sit on them? Just an idea. Looking good though. Chris
HI Pete its Kelt just checking how your doing , just been reading through some of your latest posts and i would agree with this post i myself have tried before fitting aftermarket seat and recarro seats into some of my minis and chris is right there isnt enough support when you start to move the seat back into the rear floor pan. have a rover mini cabriolet and recarro seats are fitted as standard how rover overcame this was to fit in another crossmember like the front one where the back of the seats are fixed perhaps it might be worth looking into if you like i will try and send you a picture of my mini floor so you can have a better idea
keep the good work
Kelt
#498 pmplovesminis2006
pmplovesminis2006
  • 143 posts
  • Local Club: north west mini club
Posted 23 January 2014 - 08:37 PM
hi pete ,the studs on the hinges are threaded in the hinge then welded from the back so they dont unscrew ,so they are stronger than you think!
#499 Petrol
Petrol
  • 967 posts
Posted 23 January 2014 - 11:05 PM
Hi Kelt, glad to see you popping in to have a look at your old Min :proud:
Thanks for the advice, I managed to find a vid on You Tube of a cab floor and have seen the seat arrangement. At the mo I have two ideas; Make a sheet steel mini X member to weld across the rear floor, or what seems to be my best option at the moment, is to scrap the seat rear subframe mount and start again. The plan is to only use the runners and weld a support bracket from the inner sill to the tunnel. This would add strength to support the seats and improve shell rigidity with a minimum weight gain. I also have the carpet fit to consider so there’s a lot to think about.
Hi Phil,
I tapped the hinges for the studs using a 1st tap so they are pretty tight. They are off to be TIG welded which I’m told will be the best bet.
Thanks for your help and advice guy’s, It’s very much appreciated. These mods are proving to be a bit more of an engineering challenge than I first thought :ohno:
Pete
#500 Petrol
Petrol
  • 967 posts
Posted 26 January 2014 - 12:46 PM
New seat subframe
#501 palhegyi
palhegyi
    Starting My Mini Up
  • 2 posts
Posted 26 January 2014 - 01:37 PM
#502 jmac201
jmac201
  • 229 posts
  • Local Club: CCKT
Posted 28 January 2014 - 09:08 PM
Great build! Gonna use a lot of this on my next mini resto, too late for my current one
#503 Petrol
Petrol
  • 967 posts
Posted 07 February 2014 - 10:02 PM
Thanks, finally managed to get all the holes in floor for the brake pipe, battery cable, fuel injection pipes, new seat supports, center console brackets & sub.
Door hinge studs TIG welded
Bottom hinge went straight on
Top hinge pin re profiled
Bit tight in there, need to sand a bit more seam sealer off and make good
Fitting the doors is next :ohno:
Pete
#504 phil hill
phil hill
  • 616 posts
Posted 07 February 2014 - 10:38 PM
Forgive me for stating the obvious, accepting that it it's easy to be wise after the fact, bearing in mind that you are blazing a trail, and goes "against the grain" somewhat to do so, but couldn't you have fitted the screw in the top hinge from the bottom ??
Phil.
#505 Petrol
Petrol
  • 967 posts
Posted 07 February 2014 - 10:48 PM
Couldn't you have fitted the screw in the top hinge from the bottom ??
Phil.
Pete
#506 phil hill
phil hill
  • 616 posts
Posted 07 February 2014 - 10:55 PM
Hindsight eh ??  Sorry for being an arse and pointing it out !!
As I said the things you are doing on your resto are both inspiring and innovative, blazing a trail, so I was sure if you'd realised earlier you'd have done it the other way.  I didn't think of it till I saw the pics.
Phil.
#507 Petrol
Petrol
  • 967 posts
Posted 09 February 2014 - 12:16 AM
No problemo Phil, that's what forums are for :thumbsup:
I’ve dropped loads of ******** on this refurb but couldn’t understand why I put the pin in the hinge the way I did. I got home from work this morning, fitted the door, then it twigged –
The cap head would have been in the way of the hinge bolt.
With the door on, looks like I've a bit of fettling to do as some of the gaps are not good, more updates soon.
Thanks for looking
Pete
#508 Petrol
Petrol
  • 967 posts
Posted 09 February 2014 - 10:18 PM
2 brackets and a rivnut to hold the centre console in
Big studs in the hinges are great as you can tighten them up properly
Fitted the doors, OS needs a bit of sorting
Looks like I need to cut the frame and insert a piece. Anyone got a spare piece of door frame?
Got the NS door pretty close, gap is the thickness of a 20p piece
0777_zps2b1a007e.jpg]
Fit to rear 1/4
Frame gap looks OK
Don't know how much the door will drop when the glass and winder are fitted though.
Pete
Edited by Petrol, 09 February 2014 - 10:30 PM.
#509 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 09 February 2014 - 10:25 PM
with regards to that O/s door, can you not lift the front of the door on the hinges slightly? that will close up the gap at the top of the frame and open up the gap at the back where it sits with the bottom of the quarter.
That is of course if you have any movement there. If not perhaps you could enlarge the holes very slightly to give you the movement.
Looking good though!
Ben
#510 Petrol
Petrol
  • 967 posts
Posted 09 February 2014 - 10:54 PM
Hi Ben, hope you are well. Just had a quick look and if I lift the O/S door a few mm and add another shim to the top hinge, it will sort the gap at the back of the door :thumbsup: Rotary file in the drill will soon enlarge the holes. The frame seems to be quite a long way out though and might need something a bit more drastic.
Thanks for your advice,
Pete
5 user(s) are reading this topic
    Bing (2)
