Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#451 Petrol
Petrol
  • 967 posts
Posted 12 December 2013 - 10:54 PM
I want to make some better brackets to achieve the best possible fit of the dashboard. I might end up welding them to the bulkhead so this has to be done before the scuttle is fitted. I would also like to replace the heater control –
I’m hoping to use something small so I can fit it in the dash. The heat controller from a Honda S2000 looks like it would fit the bill but I assume it’s electrically controlled so I would need the associated heater valve. I'm reasonably proficient wiring this lot up and if anyone has any suggestions as to what might fit the bill, I would appreciate your help.
Pete
Edited by Petrol, 17 December 2013 - 11:42 PM.
#452 Petrol
Petrol
  • 967 posts
Posted 15 December 2013 - 10:27 PM
New brackets for the dash, just need to tidy them up
Bolted through the bulkhead
Stainless cap screws through the front. I’ve made the dash a tight fit against the top and lower rails, I can shim it out with washers if required during the final build
Found this for the heater control, need to know the dimensions of it though
Pete
#453 evansisgreat
evansisgreat
  • 1,139 posts
  • Local Club: Not yet
Posted 17 December 2013 - 12:54 AM
Maybe one of these will work?
http://www.carbuilde...eater-valve-kit
http://www.carbuilde...alve-controller
Wildcard?
#454 Petrol
Petrol
  • 967 posts
Posted 17 December 2013 - 11:34 PM
I like the look of the wildcard slider jobbie. This would fit very nicely in the center console just below the heater diverter lever. Thanks very much for the linkys :D
Started on the scuttle which is taking some time to get the shut line tight along the bonnet. It also looks like the profile on the MPI A pillar is slightly different to the replacement Heritage panel which will take some fettling. This is where I'm up to
Decided to de badge it
I also want the bonnet to be removable and am thinking of fitting some Aero Catch bonnet pins to the back, looks like I will have to chop the bonnet frame to fit them. I guess this build is going the whole 9 yards now wack_zps216954f4.gif
#455 Petrol
Petrol
  • 967 posts
Posted 20 December 2013 - 12:21 AM
Had to tweak the scuttle like this to improve the fit against the bonnet
Gap is much better now, sorry pic isn't too good
NS door trial fit
Shut line is pretty tight considering it's not had a welding rod down it
Ran into a problem with the hinges though. After removing the rust, there's not much left on the threads and you can see how loose the nut is
I only nipped em up and the threads sheared :ohno: Gonna get some new ones thumbsup_zps8cfc91ce.gif
#456 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 20 December 2013 - 06:48 AM
nice bit of 'tweaking' there haha. improvisation at its best!
are you going to leave the door gap?
#457 hennasxi
hennasxi
  • 117 posts
  • Local Club: LSMOC
Posted 20 December 2013 - 07:38 AM
This thread is totally inspiring for us MPi owners (and all!!).   On the hinges front, I have just bought some W&P aftermarket ones, and they seem very loose on the pin, unlike the originals which you can hardly bend.   Not sure about them yet - intend to fit them over the next couple of weeks.  Can you still get OEM hinges anywhere new?
#458 Archived4
Archived4
  • Archived
  • 822 posts
Posted 20 December 2013 - 09:00 AM
This thread went the whole 9 yards when it started. Now it's walking the whole 500 miles!
Edited by Smiler258, 20 December 2013 - 09:00 AM.
#459 Marco1972
Marco1972
  • 822 posts
Posted 20 December 2013 - 09:10 AM
Hi Pete
You can get the replacement bolts from smithys bits in stainless steel save you replacing the whole hinge
Keep up the excellent work.
#460 Petrol
Petrol
  • 967 posts
Posted 20 December 2013 - 11:45 PM
No, I really need to even it up but need to sort the hinges out first
Minisport sell OEM hinges but at £160 a set it's rip off money. I looked at a set of non genuine ones but the quality was more like something from a garden gate! I've decided to re-manufacture the hinges I have...
There are 2 problems with the hinges, the studs that go through the flitch panel aren't big enough and the roll / cellock pins  cause the hinge itself to corrode, probably due lack of lubrication. To address these problem's, I'm planning on replacing the roll pins with 8mm stainless bolts. The hinge will be reamed out to suit the bolt and also tapped to stop it falling out.
I have ordered some HT bolts to replace the studs, the plan is to tap the hinges to ensure correct location then weld them in. I need to find someone to do the welding though. I have 2 sets of hinges and am planning to do both sets.
Hi Pete
Hi Marco,
The bolts are the ones that fit into the door. Smiffy's stuff is top notch, I've bought a few bit's from him and will be buying a lot more.
With the doors on the back burner for now, it's back to the scuttle. 20mm hole drilled in the bulkhead
This will make it easier to get some paint / box section wax inside of the closing panel
It's possible to gain access over the top of the inner wing but this will make things a whole lot easier. The hole will be plugged with a blind grommet.
Pete
#461 Archived1
Archived1
  • Archived
  • 619 posts
Posted 24 December 2013 - 04:17 PM
Great Idea with the hinges!
Dont mind if I steal "borrow" that Idea so you?
Edited by Elf is a mini, 24 December 2013 - 04:17 PM.
#462 Petrol
Petrol
  • 967 posts
Posted 24 December 2013 - 11:38 PM
Not at all, that's what forums are for, sharing info :D
These are the bolts for the hinge pins
http://www.ebay.co.uk/itm/300943418375
These for the studs
http://www.ebay.co.u...984.m1439.l2649
Just waiting for this reamer to arrive
A neighbor who has a lot of experience at this kind of work has offered to give me lift. I was thinking of using a pedestal drill to align everything but he reckons he can do it with a pistol drill :unsure: I'll get some pics up of the progress.
Merry Xmas everyone
All the best
Pete
#463 Archived1
Archived1
  • Archived
  • 619 posts
Posted 25 December 2013 - 03:44 PM
thanks pete  :D
#464 dfraser
dfraser
  • 121 posts
  • Local Club: Minis in Inverness
Posted 25 December 2013 - 10:55 PM
Hi Pete, I feel compelled to respond to your thread. Just read most of it over the last couple of days... Awesome level of detail and a kick up the backside to those who might be tempted to settle for 'that'll do'!  I've just restarted working on my Brother's 1998 MPi after stalling it due to work priorities, and your detail and advice will undoubtedly influence my project.  I have a minted 99 MPi which has only seen water for washing!  An excellent reference point and inspiration.
Thanks for your openness and sharing of your knowledge - none of us who consider ourselves experienced should be closed to learning from others.
Will follow your progress with added interest!
David
#465 Petrol
Petrol
  • 967 posts
Posted 02 January 2014 - 12:04 AM
Hi David, thanks for your response. I'm trying to do it once and do it right. I would love to see some some pics of your MPI so post em up :mrcool: I like things that are minted thumbsup_zps8cfc91ce.gif
I've not been sat on my arse over Xmas, got the floor more or less finished and have welded in the scuttle closing panels
Also done quite a few trial fits just to make sure everything is right. This is one example... The MPI boot floor has a stud to support the injection pipes. Since this was missing on the replacement I bought, I drilled the floor to add a bolt
I took advantage of the sales and have spent quite a bit on new stuff including Minifins, New radiator, all new panel seals, chrome outer door finishers, complete bearing kit for the gearbox, Centre bearing strap etc etc. Long way to go but progress is good
Happy New Year everyone!
Pete
Edited by Petrol, 02 January 2014 - 12:06 AM.
5 user(s) are reading this topic
    Bing (4)
