Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#391 Petrol
Petrol
  • 967 posts
Posted 12 October 2013 - 10:18 PM
Don't mean to answer this question for Pete but i think i remember him saying that he expects it to burn off in places but any remaining paint is a sight better than nothing, also i think he masked and zinc primed all the edges for welding.
Correct me if i got this wrong though.
Ben
Spot on
All of the paint wont burn off, almost all of the paint near the welded seams will stay intact. Painting the panels off the car like that allows ultimate paint coverage and protection to areas which cannot be painted when the panel is in place.
Exactly, not easy to paint behind here when it's fitted
This is behind the original scuttle, not much protection at the ends
Pete there is a rubber seal that fits between the sportspack arch and the panel, DFP100400, that would take up some of the room.
Noah, they didn't look up to much when I took them off so am trying to think of an alternative method. Thanks though
OS arch fits perfectly
Welded the panel on
Just need to get the NS to fit as good
Thanks for looking
Pete
#392 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 13 October 2013 - 09:14 AM
really taking shape there  :-) I really enjoy this build, it's one of the ones I always look for when I log in. Just a pity that guys this side throw a shell away with 90% less rust than this . . .
#393 Petrol
Petrol
  • 967 posts
Posted 14 October 2013 - 10:02 PM
Glad you are enjoying the build Jared Mk3. British weather plays havoc on cars here, which is why I’m going the extra mile to try to make it last with all the work inside of the seams. Once the shell is sprayed, the second line of defence will be a good dose of Dynax box section wax but that’s another story.
Managed to get the NS arch to fit properly - Slotted the holes in the rear 1/4, filed the lip on the arch itself, used a heat gun to re-shape the arch a bit and rolled the rear ¼ ever so slightly
I now have the scaffold pole to get the car on the spit, this will be done when the NS rear ¼ is on. It’s gonna be a bit of a tight do as it's pretty close to the scuttle….
As I mentioned earlier I want to fit it through the existing hole in the bulkhead but it’s pretty close to the scuttle. Just to make things a bit more tricky, the fit of the scaffold pole in the support is a bit sloppy
Progress is slow at the mo but that’s how these builds go yes_zps01e0e81b.gif
Pete
Edited by Petrol, 30 September 2014 - 07:03 PM.
#394 pothole
pothole
  • 317 posts
Posted 15 October 2013 - 06:05 AM
Just started to read this thread (on P11 at the moment) as I am repairing the rear rusty boot of an Italian Job and I have to say Pete this is a great read, not only for the photos, equipment, consumables but for the knowledge and tips you have given too.
And all done outside on the front drive, even during the winter months, this will be a great mini when finished.
#395 Petrol
Petrol
  • 967 posts
Posted 15 October 2013 - 10:29 PM
Thanks pothole, if you continue reading the thread, it's now inside the garage. It makes life a whole lot easier.
Sprayed the underside of the scuttle
Same with the dash top rail. These areas would be really difficult to get some paint on when fitted
Back of NS ¼ panel sprayed and flatted. You can see the masked areas for welding
This is how I am going to mod the spit
Adding the box section underneath and offsetting the support is easier and means the spit can be later used on a pre MPI Mini.
Pete
Edited by Petrol, 15 October 2013 - 10:48 PM.
#396 Petrol
Petrol
  • 967 posts
Posted 16 October 2013 - 10:03 PM
Modded the spit like this
To reduce the clearance between the scaffold pole and support I made this sleeve
Cut some box section in half to spread the load under the front X member. Might be worth a mention, the threaded bar I am using is stainless steel which has a higher tensile strength than mild steel.
Cut the minimum out of the back seat upright to get the pole through
Progress will be slow for the next few days as I'm working double shifts. Should be an extra few quid to spend on the Min though thumbsup_zps8cfc91ce.gif
Pete
#397 Petrol
Petrol
  • 967 posts
Posted 17 October 2013 - 10:19 PM
Got it on the spit
Mods worked OK and it's not fouling the hole in the bulkhead
Sleeve was the answer to be honest, it removed the bulk of the play
Also got the NS rear ¼ panel on
Pete
#398 Petrol
Petrol
  • 967 posts
Posted 23 October 2013 - 10:57 PM
Decided to fit fixed rear windows for a number of reasons, one of which being the hinges can sag and chip the paint on the rear ¼…..
First job was to remove the frame
After a trial fit with fixed window seals there was a problem
It turns out that the fixed window glass is every so slightly larger than the opening type. Since you can’t get fixed windows with the green tint I had to mod the shell.
I applied a wedge of filler to the rear ¼ and up the B post
This tightened the seal where it runs along the glass
Next job was to close the aperture around the curves with filler.
The seal now fits tight to both the glass and the shell though it was a bewildering amount of work to get them to fit. By the time the shell is painted and the glass is filled with sealant, it should be waterproof.
Then I cut the roof off
#399 Jase
Jase
  • 1,166 posts
Posted 24 October 2013 - 05:53 AM
Love it, "then I cut the roof off" :) Just like that.
Fantastic build, I enjoy every update.
#400 Marco1972
Marco1972
  • 822 posts
Posted 24 October 2013 - 07:23 AM
Hi Pete
This is one of my favourite builds on here excellent descriptions and details
Your braver than me chopping the roof off :-)
Watching closely..
#401 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 24 October 2013 - 07:32 AM
I had the same thought  :-)
#402 Petrol
Petrol
  • 967 posts
Posted 28 October 2013 - 12:22 AM
Thanks guys, to be honest chopping the roof off is no big deal. The shell is strong enough without it....
It's only a case of spot welding the replacement on.
I got fed up of cutting, grinding and welding so decided to start on bodywork prep.
Seam sealer on the rear ¼ to back panel seam
A bit off topic but Mika has bought this
Not a bad upgrade from an 8V Clio. I'm a big fan of the S2K and having joined their forum some time ago, have been on a few meets over the years. Vtec and redline at 9 is oh so cool thumbsup_zps8cfc91ce.gif
Pete
#403 Petrol
Petrol
  • 967 posts
Posted 04 November 2013 - 09:22 PM
Seams sorted and a skim of filler over the welds, then primed
Flatted back and sprayed blue.
Liking the blue tips
Pete
#404 Archived4
Archived4
  • Archived
  • 822 posts
Posted 05 November 2013 - 06:12 PM
Haha, love the exhaust ;)
Incredible work as usual :P
#405 Petrol
Petrol
  • 967 posts
Posted 07 November 2013 - 12:12 AM
Thanks, the exhaust is for the S2K, bit OTT for the Mini but thought it would be fun to try if for size. The strange thing is, I bet it would fit with a few mods. It’s an Invidia and they are mental loud, not something I am really looking for on this car.
It needs 2 people to spin the car on the spit but it’s great to be able to get Zinc inside of the seams
I went a bit mad and filled every seam
Also decided to get rid of all these pipe supports. Most of them are not needed on an MPI
Only the front to rear brake pipe needs fastening to the floor pan so I bought these stainless clips
These will be bolted through the floor with button head hex bolts. Button head bolts have a lower profile than conventional allen bolts so won’t protrude much.
I have also decided not to fit the original 13” wheels. Having spoke to a couple of owners, such a big rim / low profile tyre makes for a tramlining / bumpsteer drive. At the end of the day, a car is all about the driving experience. The last thing I want is tramlining / bumpsteer so maybe it’s 12” or even 10” wheels.
I would welcome any comments on this.
Thanks for looking and I look forwards to your feedback
Pete
    Bing (3)
