Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#301 Petrol
Petrol
  • 967 posts
Posted 10 August 2013 - 11:01 PM
Sprayed the heelboard / OS floor and flitch panel blue. It needs a bit more work but it's best to protect the primer with gloss.
Next job is to cut the whole of the boot floor out
Pete
#302 rally515
rally515
  • 3,848 posts
Posted 10 August 2013 - 11:11 PM
Looking as good as ever Pete, the finish is superb!, if the underside is anything to go by the top side paint finish should be class (no pressure :P)
Look forward to seeing the boot being replaed, nice big sheet of new metal :proud:
Cliff
#303 Petrol
Petrol
  • 967 posts
Posted 11 August 2013 - 09:11 PM
Thanks Cliff, quite a bit of prepping to do before the final coats go on. Like you say, nice big sheet of metal so hopefully it will be easy to fit.
Cutting out the old
Trial fit
Have to say I'm mucho impressed. It's not going to need much work to get it to fit
#304 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 11 August 2013 - 09:40 PM
Top work. Looking good. :-)
#305 Petrol
Petrol
  • 967 posts
Posted 14 August 2013 - 10:17 PM
Thanks, Got the rear floor in 2K primer and seam sealed
Was hoping to get the front done as well but it needs more work :ohno:
#306 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 15 August 2013 - 07:04 AM
Almost whole and not so holey. :lol:
#307 Swiftes
Swiftes
    Just On Tickover
  • 7 posts
Posted 15 August 2013 - 11:33 AM
just read through all this Pete, fantastic work! My 96 SPI is at a similar stage atm, good to see I wasn't the only one struggling with the rust :P
#308 Zeemax Adventure
Zeemax Adventure
  • 301 posts
Posted 15 August 2013 - 05:50 PM
I reckon when you pull the trigger on that beast, the rest of the street plunges into darkness..... ;D
Haha this is what happens when i use mine
#309 Petrol
Petrol
  • 967 posts
Posted 16 August 2013 - 10:56 PM
Thanks for the replies. These late model Minis sure have rust issues. The more I look, the more I find. The reason I didn't prime the front floor pan is that the steering rack stiffeners have rust behind them so they need to come off, I will post some pics up.
Spot welders use low voltage but mega current and yep, the lights dim when it's in use  :D
Got the rear floor in gloss.  It might be worth pointing out at this stage of the game, it's impossible to get a good finish and to be honest it's pretty pointless. It's full of bits and by the time the boot floor is welded in it will look a mess. Once the whole shell is re fabricated and painted blue, I can start on prepping it for a proper paint job.
I converted my garage into an office some time ago and am now in the process of converting it back. It's quite a big job but I don't want to leave the shell outside over winter. It will be stored in an insulated, centrally heated space. I just wish it was big enough to get my other car in :strongsad:
Thanks for looking
Pete
Edited by Petrol, 16 August 2013 - 10:58 PM.
#310 rally515
rally515
  • 3,848 posts
Posted 16 August 2013 - 11:05 PM
You must be joking Pete!!! haha thats a fab finish you,ve got there, id be proud of that on the outer surface of the car
Cliff
Edited by rally515, 16 August 2013 - 11:05 PM.
#311 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 August 2013 - 11:09 PM
perfection as always Pete!
Ben
#312 ZEBERDEE
ZEBERDEE
  • 110 posts
  • Local Club: Box Hill Mini Club
Posted 17 August 2013 - 08:11 PM
Looking amazing, keep up the good work
#313 Petrol
Petrol
  • 967 posts
Posted 21 August 2013 - 09:58 PM
Thanks for the feedback.
I converted my garage into an office some time ago but haven't got the heart to leave the shell outside all winter. Time for some major surgery...
Plasterboard and insulation removed from behind the door
Studding removed
Walls modded to enable the door to open. It was a bit tricky to get the insulation right.
It's more of a storage space than a garage but at least it's bone dry.
Pete
#314 Zeemax Adventure
Zeemax Adventure
  • 301 posts
Posted 21 August 2013 - 10:16 PM
Good thinking, the nights are drawing in and the weather will be getting colder, wetter and miserable.  Ive just kicked my pristine vectra vxr outside under a cover for my little mini to be all dry.  I didnt fancy getting soaked half way through body panel replacement
#315 Petrol
Petrol
  • 967 posts
Posted 27 August 2013 - 08:19 PM
Got the car in, like you say it will make things so much easier
Some drive pics
The boot floor has a stiffener than runs under the seat. Ground the welds out of the old one
Spot welded to the new boot floor
Front subby stiffeners split from bulkhead
Progress should resume again now the garage is sorted
Pete
