Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#256 MiNi'D
MiNi'D
  • 42 posts
Posted 25 June 2013 - 07:25 AM
I guess you have a few too many pictures in your photbucket library hu? :)
I can't see any of your pictures but I would love to ;)
#257 Petrol
Petrol
  • 967 posts
Posted 25 June 2013 - 07:07 PM
I ran out of bandwidth so have upgraded the account
Got the engine bay in primer
#258 zony
zony
  • 165 posts
  • Local Club: Welsh Rarebit Mini Club
Posted 25 June 2013 - 10:29 PM
Can't wait to see the front end go on. Good work man.
#259 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 26 June 2013 - 12:17 AM
Mine is gone at the top of the bulkhead where yours had Pete, but I can't manage to find anything here that I can cut one off of.
Did you get your bit from a breakers yard?
Might have to have a ring round of breakers on the mainland and see if I can o get one when i'm over next time.
Hmmm, wonder if anyone on here has a shell that they would be willing to cut that bit off and sell me. I'll have to put a request in on wanted section.
Good luck mate
Ben
#260 Petrol
Petrol
  • 967 posts
Posted 26 June 2013 - 06:16 PM
That could be some time off ;D
Good luck mate
Ben
I got mine off a local guy. Try sending HarrysMini a PM.  This is his thread
http://www.theminifo...982-city-shell/
Edited by Petrol, 26 June 2013 - 06:16 PM.
#261 Petrol
Petrol
  • 967 posts
Posted 26 June 2013 - 09:54 PM
Seam sealed around the engine bay. I used Sikaflex straight on top of the Electrox zinc primer. There's no need to go mad, Rover might have skimped on paint but the seam sealer was slapped on big time.
I don't like the idea of dressing seam welds back for the "invisible look" on structural areas. Doing this can result in sanding the sheet metal thinner and obviously weaker.  I'm sanding back with a flap wheel as close as I can, then shot blasting, priming and seam sealing. The reason for the seam sealer is two fold. It looks neater and significantly reduces the risk of rust - edges are difficult to get any paint thickness on. Think of trying to spray a razor blade edge. Seam sealing the repaired areas overcomes this problem.
Talking of looking neater, the bottom of the bulkhead has some hammer rash where I split and treated the seams
This won't be seen when the car is finished, I'm going to fill it though as a friend of mine who owns a bodyshop is going to spray the shell. He would give me some real stick for that wack_zpsdcea4137.gif
Pete
#262 Petrol
Petrol
  • 967 posts
Posted 27 June 2013 - 10:45 PM
Hi my name is Kelt and i owned this Mini for about 6 years . I sold it about 7 years to a guy in Cearphilly its good to see it is still soon to be back on the road i bought it from Bristol minis when it was a year old
if there is anything you need to know you can get hold of me on my email KELT11@SKY.COM
Kelt very kindly sent me a pic of the car when it was about a year old
Interesting to see the sunroof. I guess these shrink with UV.
Have to say it's great to talk to a previous owner, it just adds to the interest :D
#263 shough
shough
  • 196 posts
  • Local Club: N/A
Posted 29 June 2013 - 01:47 PM
Pete,
Any chance you can restore my MPI when I finally buy it???
#264 Petrol
Petrol
  • 967 posts
Posted 29 June 2013 - 06:36 PM
Pete,
This is my last refurb. Iv'e had enough ;D
Sprayed the engine bay
#265 Archived4
Archived4
  • Archived
  • 822 posts
Posted 29 June 2013 - 07:11 PM
WOW. Beautiful. What's the colour? Is it solid or metallic?
#266 Petrol
Petrol
  • 967 posts
Posted 29 June 2013 - 09:06 PM
The paint I'm using at the moment is Tahiti blue but a solid.  The plan is to get the whole of the shell done in the solid, then flat it back for a final full paint job in mettalic Tahiti blue.
Pete
#267 zony
zony
  • 165 posts
Posted 29 June 2013 - 11:26 PM
Pete, I love you.
#268 chrisj
chrisj
  • 283 posts
Posted 30 June 2013 - 07:46 PM
Great job on the engine bay pete!
What's your technique for spraying?, do you do the edges/corners first then the straighter areas?
Chris
#269 Petrol
Petrol
  • 967 posts
Posted 30 June 2013 - 09:01 PM
Hi Chris,
I often spray 2 - 3 coats on the edges first, then leave it to go tacky. I then do the edges again followed by the flat areas. It's difficult to get a decent paint thickness on edges / corners and I have found this to be about the best. On areas that you can't see, like the subframe it's a good idea to remove any sharp edges or even sand a small radius along the edges. This improves the surface area and as a result, paint thickness. I have also brush painted edges before spraying the part. This is probably the best way to get a proper coating on.
Pete
#270 Petrol
Petrol
  • 967 posts
Posted 30 June 2013 - 09:24 PM
Went to a classic car show today and met a guy with a mint original condition MPI. Have to say it was great to see an unmolested example
