Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#1771 Petrol
Petrol
  • 967 posts
Posted 06 February 2022 - 10:01 AM
I'm about to fit the cylinder head using this head stud and nut kit
http://minispares.co...c/C-AHT280.aspx
I'm confused where these 2 small washers go
Instructions state...... The 5 larger washers go on the 5 short front studs and the 2 smaller washers go on the short studs at the ends of the rocker cover. No washers on the long head studs.
Can anyone help?
Thanks for looking
Pete
#1772 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 06 February 2022 - 10:10 AM
Are they for the extra 2 studs of the 11 stud heads?
Excellent work on the rebuild, a shame that it had to be done though!
#1773 Midas Mk1
Midas Mk1
  • 5,773 posts
  • Local Club: S.U.N.M.C
Posted 06 February 2022 - 10:41 AM
I’m sure there was bad press on those head bolts, surely if your going to effort it’s arp all the way?
#1774 Petrol
Petrol
  • 967 posts
Posted 06 February 2022 - 09:06 PM
I think your right. Yeah it's a shame all this happened but there was a lot wrong with it
I wasn't aware of that. I have also no idea why the head gasket went. The head was skimmed and the block was decked. Both surfaces were cleaned with panel wipe to degrease them and the head was torqued down in 3 stages.
I think ARP is a good shout. I've ordered some
This time I will run the engine for 30 seconds without coolant and re torque the head. I've got a Victor Reinx composite gasket.
Thanks for the feedback.
Pete
Edited by Petrol, 06 February 2022 - 09:07 PM.
#1775 Petrol
Petrol
  • 967 posts
Posted 11 February 2022 - 09:39 PM
ARP head studs
Block face cleaned
Head face cleaned
Composite gasket
Head and block will be degreased with panel wipe before assembly
Nuts will be torqued in many stages
I've read so many head gaskets failing after being fitted
What more can I do?
All suggestions / comments welcome
Thanks for looking
Pete
#1776 evoderby
evoderby
  • 92 posts
Posted 12 February 2022 - 08:30 AM
Keith Calver recommends Victor Reinz headgasket coated in Loctite 3020 on both sides as “the”and “the only” setup to use on small bore engines like yours.
https://www.facebook.com/calverstl
#1777 evoderby
evoderby
  • 92 posts
Posted 12 February 2022 - 10:26 AM
Nice job you’re doing on the rebuild by the way…..it is always shocking to see how little pride some so called professionals put into their work.
#1778 Petrol
Petrol
  • 967 posts
Posted 12 February 2022 - 04:16 PM
Thanks evoderby, I've ordered some Loctite 3020.
Your right . Some are not interested in doing a decent job. It's all about money.
I'm also convinced that some suppliers are selling classic car parts, knowing full well they will be out of warranty by the time the car hits the road.
Pete
#1779 timmy850
timmy850
  • 3,319 posts
  • Local Club: MITG
Posted 12 February 2022 - 08:12 PM
With the head gasket, don’t use coolant for the first few heat cycles. Just use water as it tends not to seep under the gasket (it’s also good for checking for leaks and not wasting coolant).
#1780 Petrol
Petrol
  • 967 posts
Posted 14 February 2022 - 11:44 PM
Thanks timmy850
Trying to think positive here and maybe all these engine / gearbox related problems were meant to be.
I'm doing a lot of modifications that will hopefully make this car much better when it's finished. All the niggles I had will hopefully be resolved.
I'm waiting for the Loctite 3020 to put the cylinder head on but in the meantime.......
This shell is an Mpi, there is no hole in the bulkhead and I need a bit more clearance for the carb.
I also want to move the engine forwards a bit to give more ground clearance for the exhaust so I'm using adjustable engine mounts.
The top NS one I had was from Minisport. It fouled the coolant hoses so I've bought this
New mount on the bulkhead but the downside is the tappet chest breather fouls. I've got a plan to sort this
Conventional engine mount will be replaced with this
I also need to sort the clutch breather. That one is work in progress....
Minisport stering rack is going in the bin to be replaced with this
Minispares one which is masked up ready for paint
Along with Minispares pot joints
I'll be using this paint
Pete
#1781 KTS
KTS
  • 2,420 posts
Posted 15 February 2022 - 08:26 AM
one thing to check before painting the pot joints is that they will fit the diff side covers - the shafts on mine were oversize and needed grinding to fit
#1782 GraemeC
GraemeC
  • 7,437 posts
Posted 15 February 2022 - 10:46 AM
I'd strongly recommend the evo tie-bar bushes:
http://www.minispare...20.aspx|Back to
#1783 alex-95
alex-95
  • 6,025 posts
Posted 15 February 2022 - 07:12 PM
+1 on this, I found this out the hard way with original bushed covers. I measure the pot joints and bore new bushes out to 1 thou clearance on a Lathe. Some of the pot joints aren't even concentric to the splines inside, so can bind up on the diff cover.
#1784 Petrol
Petrol
  • 967 posts
Posted 15 February 2022 - 11:57 PM
Thanks for the advice, I really appreciate it
Pot joints checked..... and checked for eccentricity
Small paint run, not easy in winter
I'll get some of those bushes GraemC, thanks.
Next up is to get the head on and check the cam timing at the valve
Again thanks for the heads up on everything. I really appreciate it
Pete
#1785 Petrol
Petrol
  • 967 posts
Posted 16 February 2022 - 08:29 PM
Head face degreased
Same with block
Head gasket sprayed with Loctite 3020
Left to dry for 10 mins
Head bolts and washers greased befor torquing up
Pete
