Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#1741 Petrol
Petrol
  • 967 posts
Posted 14 December 2021 - 11:18 PM
Short block is almost done
I've fitted a EVOLUTION001 cam from Minispares. The Kent VP3 was insane for a road car especially on a 998 with low torque at the bottom end.
New cam plate fitted, every clearance checked and within spec
Windage tray fitted to gearbox. I'm not sure how effective they are but every little helps I guess
I'm checking everything goes together spot on. I've fitted the clutch housing dry in this pic.
Next up is to check the idler gear end float with the gasket fitted and bolt the gearbox to the short block.
Pete
#1742 Petrol
Petrol
  • 967 posts
Posted 14 December 2021 - 11:20 PM
Edited by Petrol, 14 December 2021 - 11:22 PM.
#1743 70K1100
70K1100
    Formally Known as NOT850
  • 223 posts
Posted 15 December 2021 - 04:46 AM
What benefit does fitting a windage tray give? Sorry for my ignorance.
#1744 Petrol
Petrol
  • 967 posts
Posted 15 December 2021 - 06:46 PM
The main purpose is to prevent oil splash back onto the crankshaft which reduces BHP
#1745 Petrol
Petrol
  • 967 posts
Posted 16 December 2021 - 11:36 PM
Checking the idler gear end float. Different gaskets have different thicknesses so it's important to check even though it's only done 1200 miles
Gearbox on
This is an "ISKY" cam follower........ Yeah right. Taking a file to it for a few seconds did this
These are soft.... look at the wear
As a comparison, I tried to file an old genuine gerbox main shaft. The file wouldn't touch it. You can also hear a difference in sound.
I filed one of the old baulk rings too and that was the same.
Moving forwards, I'm using these lifters along with the new Evolution1 camshaft from Mini spares
Setting up to check the cam timing
Pete
#1746 pmplovesminis2006
pmplovesminis2006
  • 143 posts
  • Local Club: north west mini club
Posted 18 December 2021 - 09:45 AM
Hi Pete glad to see the mini is getting sorted , and when you have finished with the mag mount ,timing disc and dial gauge  could i have them back please  thanks phil
#1747 Petrol
Petrol
  • 967 posts
Posted 18 December 2021 - 10:49 AM
Sure, When you return the cash I gave you to build my gearbox.
When I collected it completely unassembled, you told me you hadn't spent the money.
Edited by Petrol, 18 December 2021 - 11:04 AM.
#1748 Tones61
Tones61
  • 428 posts
Posted 18 December 2021 - 02:24 PM
Lols,guess someone's buying a new dti set :-)
#1749 Petrol
Petrol
  • 967 posts
Posted 23 December 2021 - 08:41 AM
The cam timing was 8 degrees out so I bought an 8 degree woodruff key
Can't say I'm thrilled with this arrangement. The other thing is you really need to preload the pushrod onto the lifter.....
The best way to do it with the head though on and since they talk about 1 degree of timing error losing 1BHP things can soon add up.
The only problem is finding exact TDC because you can't put the dti on the piston.
I've bought a vernier from MED.
The plan is to time is up with the head off and re check it with the head on.
I just need to find a way of finding exact TDC with the head on.
Pete
#1750 GraemeC
GraemeC
  • 7,437 posts
Posted 23 December 2021 - 08:46 AM
Use a stop down the spark plug hole.
Or find TDC on the piston as usual and make an accurate pointer on the flywheel (or even rig up a timing disc and pointer on that end too).
Edited by GraemeC, 24 December 2021 - 07:50 AM.
#1751 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 24 December 2021 - 03:32 AM
I put the flywheel on and make a pointer for that end. Set it accurately with the head off then go ahead and put it together and set it.
Edited by Magneto, 24 December 2021 - 03:32 AM.
#1752 Tones61
Tones61
  • 428 posts
Posted 24 December 2021 - 03:40 PM
My spare 1293 timed on the split in/ex
And rechecked on no 1 and 4 cyls,
#1753 Petrol
Petrol
  • 967 posts
Posted 24 December 2021 - 04:08 PM
Sometimes the solution is staring you in the face but you can't see it!
Thanks very much for your help.
Pete
Edited by Petrol, 24 December 2021 - 10:37 PM.
#1754 Petrol
Petrol
  • 967 posts
Posted 25 December 2021 - 09:05 AM
The MED timing gears are a much better fit than the Minispares ones
I'm also changing things around in the engine bay to make more room
Some wiring mods so I've re wrapped the loom
I'm moving the air horns from the engine bay to make it easier to get to the oil filter. The fastenings on them are poor so I've bonded the bolts in with firberglass resin
Fitted behind number plate
Pete
#1755 Tones61
Tones61
  • 428 posts
Posted 25 December 2021 - 10:01 AM
Hi mr petrol,
You may find the MED Vernia 180deg out on the timing for the dots to cam timing,
Mine was,I disassembled and turned around via vernia,
Only a 5 min job,
With dots lined up mine was rocking/firing on no4 :-)
