Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#1726 Steve220
Steve220
  • 5,013 posts
  • Local Club: BMC
Posted 03 December 2021 - 09:32 AM
The only pump I fit is the AC Dodd 'Zero Tollerance' pump. Thomas Classic and Modern stock them.
It still doesn't stop them getting smashed by detritis in the gearbox, sadly.
#1727 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 03 December 2021 - 09:42 AM
I know that, just mentioning one of the best available A series oil pumps incase it helps.
#1728 I hate Brian
I hate Brian
  • 782 posts
Posted 06 December 2021 - 08:40 PM
Just picked up on this thread again all I can say is wow on the failures, hope you get it sorted
#1729 Petrol
Petrol
  • 967 posts
Posted 06 December 2021 - 09:50 PM
Thanks for the replies. The engine is a 998 and some of the better pumps are out of stock. I also don't want to drill the block. I'm still thinking about it.
Yeah the failiures are epic to say the least I hate Brian
This is the camshaft that came out. it's suppost to be a Kent VP3 ground from a blank.
I've never seen wear on the lobes like this before
Any comments would be appreciated
Pete
#1730 samforsey12345
samforsey12345
  • 22 posts
Posted 06 December 2021 - 10:26 PM
https://russellengin...haft-followers/
#1731 Petrol
Petrol
  • 967 posts
Posted 06 December 2021 - 10:59 PM
Interesting
The followers were allegedly genuine ISKY but to be honest, I have my doubts about many of the parts I was supplied with.
Pete
#1732 Petrol
Petrol
  • 967 posts
Posted 07 December 2021 - 11:10 PM
The gearbox is sorted. A few thou has been taken off the 4th gear baulk ring. This has stopped the first motion shaft tightening against the main shaft gear assembly.
It looks like the MED baulk rings stand off from the gears slightly more than the original Rover ones.
4th gear synchro doesn't work too hard because you never change down.
It's not been easy but it's sorted
This time it's been shimmed properly
I'll get there!
Thanks for looking
Pete
Edited by Petrol, 07 December 2021 - 11:11 PM.
#1733 Petrol
Petrol
  • 967 posts
Posted 09 December 2021 - 03:13 PM
Cylinder head was a bit of a mess due to it running rich. It's not easy to clean the carbon off, especially on the exhaust valves where it gets hotter.
I soaked it in thin oil.....
Then kept scrubbing it with a brass brush
I'm going to measure the head volume myself this time
It's a 12g295 with flat top pistons. I reckon I need 23cc for a 10:1 compression
#1734 Petrol
Petrol
  • 967 posts
Posted 09 December 2021 - 03:15 PM
Interesting
The followers were allegedly genuine ISKY.......
Pete
I believe these have not been available for many many years :ohno:
#1735 70K1100
70K1100
    Formally Known as NOT850
  • Just Joined
  • 218 posts
Posted 09 December 2021 - 06:20 PM
Are they rimflo valves?
#1736 Petrol
Petrol
  • 967 posts
Posted 10 December 2021 - 09:31 AM
Yes
The head is ported and the valves are a bit bigger than stock
Pete
Edited by Petrol, 10 December 2021 - 09:32 AM.
#1737 Tones61
Tones61
  • 427 posts
Posted 10 December 2021 - 04:07 PM
Vizard recommends not to fit rimflows on exhaust due to inhibiting flow out of the chamber?
Welcome any thoughts/info on this :-)
#1738 Petrol
Petrol
  • 967 posts
Posted 12 December 2021 - 08:47 PM
Never heard that, I'd also welcome any thoughts
It took me ages to clean the engine bay up
Then I saw this
It's not the pot joints, engine or gear box :lol:
It's one of the very few parts left on the car I bought from guess where........... Yup Minisport
I think I'll remove the front subframe and replace the steering rack. I cannot trust anything from there
Pete
#1739 colinf1
colinf1
  • 1,002 posts
Posted 12 December 2021 - 09:25 PM
Not really having much luck with anything from there are you?
At least you spotted it now before it breaking while driving!
#1740 Petrol
Petrol
  • 967 posts
Posted 12 December 2021 - 11:04 PM
It's not really a question of luck. It's a case of parts not being fit for purpose, which is why I'm highlighting the problems.
I've built / restored quite a few cars over the years and never had major problems like this before.
The problem is poor quality parts that have a knock on effect..... Knackered engine...
Lack of skills by people who have done work for me.... tapered crankshaft.... gearbox not assembled properly
You are right though, the rack will be going in the bin, along with many other parts!
I've spent about a grand so far replacing parts from suppliers who you would think you should be able to trust
I'll see how it goes but I will sort it.  It's hassle I could do without though
Pete
