Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#1681 Mini Waco
Mini Waco
  • 438 posts
Posted 01 November 2021 - 12:35 PM
I thank you, because I for one, am able to learn from this thread before the work on my mini is actually performed and parts ordered. I will stay in tune with great interest…
#1682 Petrol
Petrol
  • 967 posts
Posted 04 November 2021 - 05:24 PM
There's a lot more epic fails to come I'm afraid.
What do you guys think of the head gasket. I'd appreciate some thoughts.
Pete
#1683 sonscar
sonscar
  • 2,993 posts
Posted 04 November 2021 - 05:43 PM
Looks like it has leaked between cylinders and waterways to my unschooled eye.I hate copper gaskets(lots of others love them)Steve..
PS looks like block will need decking,looks burned between three and four.
Edited by sonscar, 04 November 2021 - 05:44 PM.
#1684 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 04 November 2021 - 05:47 PM
Pete
Hi Pete, nothing shouting out, however go with a composite gasket next time. Copper gaskets are terrible :(
#1685 GraemeC
GraemeC
  • 7,437 posts
Posted 04 November 2021 - 06:12 PM
Looks like it may not have sealed well between 1&2 and 3&4.
Copper gaskets need very flat surfaces with the right surface finish - composite are much more forgiving, the Victor Reinz ones seem to perform particularly well.
Waterways also look to have a lot of gunk in them?
#1686 Petrol
Petrol
  • 967 posts
Posted 04 November 2021 - 09:29 PM
I paid Minisport to have the block acid dipped to remove any rust in the waterways. There was a lot of rust deposit in the radiator and heater matrix both of which were new.
The block was decked and the cylinder head was skimmed before assembly.
It's done 1200 miles since it was built
I'll post some more pics up later but see if anyone else has any comments.
Pete
Edited by Petrol, 04 November 2021 - 11:02 PM.
#1687 samforsey12345
samforsey12345
  • 22 posts
Posted 05 November 2021 - 06:00 PM
Doesn't look much wrong with head gasket. Quite a lot of carbon deposits for low mileage, running rich?
Edited by samforsey12345, 05 November 2021 - 06:04 PM.
#1688 ads7
ads7
  • 351 posts
Posted 06 November 2021 - 10:10 PM
Yes Victor Reinz gaskets are absolutely the ones to use in my experience
#1689 Mini Manannán
Mini Manannán
  • 2,856 posts
  • Local Club: man Estate
Posted 08 November 2021 - 02:01 PM
Have you fellas a link to Victor Reinz HGs in the UK?
#1690 GraemeC
GraemeC
  • 7,437 posts
Posted 08 November 2021 - 02:13 PM
Never bought one personally, but:
https://www.ebay.co....msAAOSwutZeYPej
https://www.amazon.c...d/dp/B00H8VJAZK
https://www.diycarse...ctor-reinz.html
Edited by GraemeC, 08 November 2021 - 02:14 PM.
#1691 ads7
ads7
  • 351 posts
Posted 10 November 2021 - 09:53 PM
I paid £12.50 for a Reinz gasket on ebay. Still available now at this price.
https://www.ebay.co....0-127635-2958-0
#1692 Blake71
Blake71
  • Just Joined
  • 82 posts
Posted 12 November 2021 - 12:44 PM
What a cracking thread and build. Stick in fella, you'll crack it.
#1693 Petrol
Petrol
  • 967 posts
Posted 12 November 2021 - 05:43 PM
Thanks guys.
I've bought a Reinz head gasket. I agree that copper is antequated technology and have my doubts about the gasket supplied by Retro Minis. Both the block and cylinder head are undamaged and it looks to me like the head gasket de laminated. They can't make things like they used to and maybe the quality of the copper is not what it should be. Things move on though and a composite gasket is the way to go.
I have stripped the gearbox which again was assembled by Retro Minis. The mainshaft had no shim in it and the baulk rings are hitting the gears.
This could be due to the baulk rings failing or being oval. There is a possibility however that the seat the baulk ring mates to on the gears, has been cut at the wrong angle.
Quite a bit of the moly from the pot joints ended up in the bottom of the gearbox
I've cleaning the top of the pistons and block up with WD 40 to dissolve the carbon.
Got the head soaking in oil
Progress is slow but I want to be 100% sure everything is spot on.
Pete
Edited by Petrol, 12 November 2021 - 05:44 PM.
#1694 GraemeC
GraemeC
  • 7,437 posts
Posted 12 November 2021 - 05:57 PM
If the baulk rings were oval they’d not close the gap up, just have insufficient contact (not 360 degrees) and hence would slip.
It’s unlikely the gears are cut wrong (although not impossible), more likely that either the baulk rings have worn heavily or there’s no friction coating left on the gear.
#1695 Petrol
Petrol
  • 967 posts
Posted 12 November 2021 - 06:45 PM
The gear kit was brand new old stock. Allegedly a Jack Knight set. I've been told however that the last of the jack Knight gear kits were poorly made.
I'll get a set of baulk rings and see how they fit on the gears
Pete
Edited by Petrol, 12 November 2021 - 06:45 PM.
