Mini Cooper 998 Screamer Nut And Bolt Rebuild
1844 replies to this topic
#766 Petrol
Petrol
  • 967 posts
Posted 21 November 2014 - 11:06 PM
Thanks for the pics. It's a bit late to mod the shell but I still have chance to work on the subframes.
The weather is closing in now and to spray anything in the garage, I need to get the shell outside. I'm also a bit fed up with bodywork so have decided to start on some other parts.
I'm making up all new brake pipes using the originals as templates
Might be worth a mention that some of the nuts on later models are a combination of metric and imperial, there's even brake pipes with metric at one end and imperial at the other!. Then there's short and long nuts so what you end up with is this lot
I couldn't source them all in the same colour which is a pity.  They are all zinc plated but the golden ones have been through a passification process which is a bit more durable than a straight zinc coating
I started making the center console some time ago, it needs more trimming to look a bit more elegant but this is how it stands at the moment
The most important button!
Apologies if the thread is a bit fragmented but you don't half get bored doing the same thing week in week out.
Pete
#767 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 November 2014 - 11:11 PM
Looking good Pete.
I know what you mean about getting fed up with one job. I alternate too, doing more bodywork at the moment and loving it but after another week or two, i shall go back to cleaning up other bits and pieces,
I really like the centre console. Much better than the ones on the market in my opinion
Ben
#768 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 22 November 2014 - 07:44 AM
That centre console will good when it's done. I like the start button as well.
#769 Petrol
Petrol
  • 967 posts
Posted 29 November 2014 - 08:07 PM
Thanks. Decent day today so I put it on the spit to spray the box sections with this wax
Upside down first
Then same again the right way up. This ensures complete coverage
Unlike waxoyl which I don't rate at all, Dynax penetrates right into the seams. 5 hours later and it's still searching.....
Pete
#770 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 29 November 2014 - 08:10 PM
Bet that was a brown trouser moment putting the car upside down on the spit!
cracking as always Pete
Ben
#771 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 29 November 2014 - 09:26 PM
Totally agree about waxoyl. I hate the stuff personally.
#772 Petrol
Petrol
  • 967 posts
Posted 07 December 2014 - 12:17 AM
Spit was no problemo really Ben, done it enough times. I'm fully aware however, there will be plenty of brown trouser moments on the build O_O
I keep buying stuff in advance like this Kad timing cover
Trouble is, I have stuff all over the place and when I need something, I can't find it wack_zps216954f4.gif
Dynamat light under the roof skin - I'm trying to save weight. Also fitted the roof aerial and part of the loom.
Fitting the head lining was never going to be easy. Heat helps so I used a hair drier. Hung it over the spit bar
You can't really stretch vinyl but it makes it much more pliable and easier to fit
Started stripping the chassis black paint of the rear subby
Fitted the front to rear brake pipe
Used stainless P clips, bolts, washers and nylock nuts for this. Also used a nylon spacer behind the P clip to prevent water ingress.
The spacer also makes the P clips sit flush to the floor pan.
Pete
#773 Mini Waco
Mini Waco
  • 438 posts
Posted 07 December 2014 - 12:41 AM
Wow..  looks like it is really coming together beautifully.  Are you putting in the headliner for final at this point?  I"m guessing that is a new liner since you removed the sun roof for a solid top panel.  I'm getting excited for you!
#774 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 07 December 2014 - 10:57 AM
Excellent work Pete. I love to see the updates of this project. Quick question - does the cable for the roof ariel run down the drivers side A pillar?
#775 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 07 December 2014 - 02:06 PM
Thy subframe looks clean! How did you get all the paint off?
How are you going to paint it?
#776 Mini-Mad-Craig
Posted 07 December 2014 - 09:31 PM
Just re-read this project from the start and can't believe how far it's come. Has to be one of the most thorough restorations I've seen in recent years, definitely one of the best! And some great references for people going through the same processes. I love that you always have time to take photos with measurements and references to help people out.
Well done, a stunning build.
#777 Petrol
Petrol
  • 967 posts
Posted 09 December 2014 - 11:28 PM
Yes it's in for good. I bought a genuine 2nd hand one as after market ones can be difficult to fit without creases. I have still a bit of finishing off to do but I'm happy with it so far.
Yes it does and it's a good idea to use some good quality tape to fasten it to the roof. This ensures it doesn't foul the headlining. It's also important to have a good earth at the back of it to reduce ignition noise. The cable comes out here
The large round hole is for the door check strap and it's not a good idea to route it through there.
I used thinners on kitchen paper towels to remove the bulk of the paint (took ages) Then used a plastic brush in a leccy drill to do the rest. It needs a quick shot blast and a few burrs removing before it's primed with Electrox. Then it will be seam sealed and sprayed with 2K paint. I'm not a fan of powder coating as it has some major downsides.
Thanks for the kind words. Every car build has it's challenges and sometimes a pic makes all the difference. Believe me, I have searched high and low for the simplest of things so hopefully, some of the pics I've posted will help.
it's also fair to say that I've had a huge amount of help from this forum and in particular, a local guy who pops on this forum from time to time.
Pete
#778 Mini-Mad-Craig
Posted 09 December 2014 - 11:30 PM
If there is a project of the year award I think it should be this. Let's see what voting we can get underway.
#779 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 10 December 2014 - 05:13 PM
Looking awesome!
Quick question though. May I ask what you're concerns are with powdercoating?
#780 Petrol
Petrol
  • 967 posts
Posted 11 December 2014 - 11:21 PM
It may be a bit OTT this project Mini-Mad-Craig, but I’m just trying to pass on what I know about fabrication and rust prevention ;D
Sure myredmini , rust always starts on edges as it can be difficult to apply sufficient thickness for best protection. When spraying paint, you can give any edges a few extra coats. For maximum protection it can be brushed on prior to spraying though the end result can look a bit messy. You don’t have this luxury with powder coating as several coats can’t be applied. Furthermore, as the heat is applied to “melt” the coating, it tends to reduce the thickness on sharp edges.
Whilst the edges have little coating, most of the component will have a thick coat. This is not ideal where suspension parts are bolted on and can lead to flexture between the subframe and the suspension component – not ideal. Another problem is if the powder coating chips, water gets behind and rust starts. The first you will know is a rust stain and more often than not, the coating can be pulled off as a sheet revealing no end of problems. Water trapped behind a coating will never dry out so it’s worse than a chip on conventional paint.
Another thing to consider is the state of the part prior to coating. When I stripped the paint off the new rear subframe, it was rusty. When I bought it, I was offered a powder coated one but refused. I can only assume the powder coating would have been applied straight over the rust.
Just one other thing….. With powder coating there’s no protection inside of the seams and on a subframe, there’s lots of them. You can’t spray zinc paint inside prior to powder coating either, as the heat will burn it off. So IMO on powder coating – Upsides nil, downsides lots
HTH
Pete
