Do The Brake Caliper To Hub Bolts Need Spring Washers?
9 replies to this topic
#1 antcole
antcole
  • 307 posts
Posted 08 November 2012 - 12:03 PM
Hello folks,
Im building up my front brakes and cant remember if here was a spring washer under the retaining bolts....
Do the caliper bolts need a spring washer under them?
Im fitting the splash guards for originality and putting a spring washer on the bolts looks wrong against the bracket of the splash guard.
Thanks in advance.
#2 BritishRacingGreen
BritishRacingGreen
  • 433 posts
Posted 08 November 2012 - 12:06 PM
There weren't any on mine when I removed them, that doesn't mean there isn't supposed to be though, as the car was hardly well put together when i got it.
#3 jaydee
jaydee
  • 8,565 posts
Yes and torque them using a proper torque wrench at 40lbs-ft
#4 petehuws
petehuws
  • 329 posts
Posted 08 November 2012 - 12:09 PM
They do! a 3/8 locking washer sits under the caliper to swivel hub bolt.
Have a look here, you should find it useful:
http://www.somerford...page=page&id=59
Edited by petehuws, 08 November 2012 - 12:10 PM.
#5 kcchan
kcchan
  • 874 posts
Posted 08 November 2012 - 12:39 PM
All suspension ad brake components should be secured with a locking mechanism be it a spring washer, a nyloc/lock nut or thread lock. I'm sure you understand why.
#6 Cooperman
  • 23,276 posts
Posted 08 November 2012 - 03:45 PM
I've always used a flat washer and Loctite - never had any problems. Not a lover of split spring washers as we never used them on aircraft.
#7 mike.
mike.
  • 6,176 posts
Posted 08 November 2012 - 03:58 PM
Got loctite on mine with no spring washers
#8 antcole
antcole
  • 307 posts
Posted 08 November 2012 - 05:03 PM
Thanks chaps, excellent info.
Ive gone for washers and a touch of loctite on your replies.
#9 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 08 November 2012 - 05:04 PM
spring/split washers don't really work anyway, there was a big piece about them knocking round a few years ago.
#10 Cooperman
  • 23,276 posts
Posted 08 November 2012 - 05:23 PM
Aircraft always have flat washers and, where applicable, a thread locking fluid. I almost never use a spring washer as I can't see the point. As 'ANON' says, they don't actually do anything and I've even seen them 'open-up' when tightened.
