Budget Spray Guns
9 replies to this topic
#1 Mad Max
Mad Max
  • 306 posts
Posted 05 November 2012 - 04:22 PM
Hi
What are you guys using. Going to be doing a fair bit of spraying and have a half decent compressor just want to see what people recommend. Probably got £100 to spend tops so i know its not going to be a professional gun.
Dan
#2 Mad Max
Mad Max
  • 306 posts
Posted 07 November 2012 - 06:00 PM
Anyone????
#3 Andrew O
Andrew O
    Previously known as Andrewo330.
  • 1,425 posts
Posted 07 November 2012 - 06:03 PM
I work in a Spray Shop and all our guns there are top of the range Develbis guns which are superb
However im currently spraying my Mini in High Build primer at home ( Take a look at my thread )
and im using a £30 HVLP Seally gun which is doing the job perfectly.
Andrew.
#4 danny79
danny79
  • Just Joined
  • 111 posts
Posted 07 November 2012 - 07:11 PM
here is a good starting gun:
http://www.ebay.co.u...76675b0e&_uhb=1
#5 minidave1991-89
minidave1991-89
  • 406 posts
  • Local Club: Charnwood Minis
Posted 07 November 2012 - 07:30 PM
I got a clarke pro spraygun, very good quality, never failed me yet. Only cost me £30 aswell from machine mart. Very easy to take apart and clean
#6 cradley-heathen
cradley-heathen
    Metro-Man
  • 2,481 posts
  • Local Club: spearmint rhino
Posted 07 November 2012 - 08:04 PM
jesus, i used to do allot of paint work at a classic car restoration place and we only had cheap guns, certainly under £50, and our touchup gun was about £20!
we used to do all the things you arnt suposed to do and never had a problem.......
i tried to repaint my fuel filler flap on the 'tro last week and it went tits up...... typical!
but in response to your question, i dont think you need to go mad with gear to get a good result, a £100 gun is far better than anything i have ever used and i never had any complaints about my finish!
Edited by cradley-heathen, 07 November 2012 - 08:05 PM.
#7 R1minimagic
R1minimagic
  • 4,660 posts
Posted 07 November 2012 - 08:09 PM
I have a Binks spraygun which i bought about 20 years ago for £65ish, does a brilliant job and easy to adjust and set up
#8 camp freddy
camp freddy
  • 3,696 posts
Posted 25 November 2012 - 06:00 PM
as previous clarke hvlp gravity fed gun £30 ish
#9 JonnyBMX
JonnyBMX
  • 865 posts
  • Local Club: Rebels
Posted 25 November 2012 - 06:49 PM
are you going to be shooting primer and the paint through the gun? because primer is better through summin like a 1.6mm or 1.8 but paint better through summin like a 1.3, primer wont matter too much on qaulity i used a cheap 25 quid gun on my car but i did use a devilbliss sri pro to paint the base and laquer.
as already posted that devlibliss slg 610 is fairly good
#10 Sam Walters
Sam Walters
  • 2,765 posts
Posted 02 December 2012 - 02:44 PM
Avoid the DB SLG610. Its known to be a bag of arse. Look on the mig welding forum.
On a full on budget the sealey gold gun with a 1.4mm tip seems to produce acceptable results.
You should be able to pick up a DB GTI setup second hand for around £100. A bit pricey but unlike the SLG610 or the Sealey gold you'll be able to sell it on for close to the same price when you're finished
