Flat top vs Dished pistons?
Posted 28 March 2006 - 09:25 PM
Are dished pistons any better than flat top pistons in a 998?
Rob
Posted 28 March 2006 - 09:34 PM
The dished ones were used in the low-compression 998 with - i guess - 36HP.
The flattop-pistons came from the A+ engines with 42HP.
A special-variant are the d-top pistons from cooper 998.
They are made for the usage of an 12G295 head.
If you want to use a 12G295 (ccoper-)head on your 998 you should at least use the flattop pistons because of the rquired compression (but even with flattops, the 12G295 must be - ohm - "lowered").
Grretz,
Jan
PS: Anybody please correkt me if i`m wrong
Posted 28 March 2006 - 10:03 PM
thanks for that
the reason i ask is that i have heard that the dished pistons swirl the mixture in giving a better fill
just that we run on such tight regs that any extra power is a plus
Rob
Posted 29 March 2006 - 07:05 AM
Posted 29 March 2006 - 07:24 PM
Basically this is because power seems to increase if you skim the head (therefore skimmed head and dished pistons with 10:1 ratio should give higher power than standard head with flat tops giving 10:1 ratio)
But as been said, opinions about this are divided
Posted 29 March 2006 - 08:32 PM
Posted 29 March 2006 - 09:38 PM
Simply because the head need`nt to be skimmed(?) that much than with dishes ones.
The advantage of dished pistons is - as far as i think - negligible (on an 998).
What are you going to build?
A street-engine for daily use, or a pedigreed race-machine?!?
On a pure race-engine you might benefit from the dished ones - if every little fragment of HP is needed
You see:
Opinions are realy divided.
So no it`s on you to choose the best setup for your engine with the informations / opinions given.
Greets,
Jan - fan of 998s
PS: I would use what i have... low-budget racing ;-D
Posted 30 March 2006 - 04:06 PM
we have a set of eachI[/i] would use what i have... low-budget racing ;-D
Posted 30 March 2006 - 05:28 PM
Posted 30 March 2006 - 05:53 PM
Posted 30 March 2006 - 06:26 PM
Posted 30 March 2006 - 08:36 PM
AE 1275cc High compression std piston set +20
or it will say under that +40.....
what do they mean by +20 or +40???
Posted 30 March 2006 - 08:49 PM
Posted 31 March 2006 - 02:12 PM
It has a ministort road/rally cam and a few other little bit like the light pressure plate and the lighter end pulley
jammy_basturd stop using all tose big words you're confusing me!
Posted 31 March 2006 - 02:28 PM
