Original Factory Paint Colour
Posted 03 November 2012 - 05:04 PM
can anyone tell me how to find out the original colour of paint that your/my car was when it left the factory.
is it stamped on the car and if so where.
Cheers.
Posted 04 November 2012 - 04:23 PM
Posted 04 November 2012 - 04:33 PM
Posted 04 November 2012 - 04:56 PM
and another one on the passenger side inner wing but none look like a paint code like BLVC etc.
Posted 04 November 2012 - 05:07 PM
I think it's the BLVC plus a number on the end. http://www.theminifo...opic=46823&st=0there are 3 plates on the bonnet slam panel - none of those three resemble paint codes.
Posted 04 November 2012 - 05:19 PM
or any of the 3 plates on the slam panel.
inner wing starts with code FE414.....and the slam panels code start with 20w then numbers. or XC2W2 then numbers.
if anyone has any ideas to track or find the original factory paint code be much appreciated.
austin 1979 clubman estate
Edited by MentalMini, 04 November 2012 - 05:21 PM.
Posted 04 November 2012 - 06:11 PM
Posted 04 November 2012 - 06:38 PM
does anyone have a 79 clubman estate and know where i can find the paint code location on the car.
i found this site below and everything seems to match up for original spec on the car.
http://www.love-mini...numbers/classic
Posted 05 November 2012 - 01:17 PM
the car has been resprayed not a mini blue so i'm trying to find the original colour code it left the factory as
any help much appreciated.
Posted 05 November 2012 - 03:08 PM
Found these stamped plates in the box of bits that came with the car. would any of these tell the paint code somehow?
If it has been that colour from new then the paint code will be on the vin plate!
If not then your best bet would be to go to your paint supplier and get them to match it!
VIN plates were only fitted from around 1984 - after van production had ceased so no vans have VIN plates. They do have chassis number plates but there is no paint code stamped on them or the large weight rating plate.
The top two pics show the weight rating plate and the chassis number plate and have matching numbers - this should also match the chassis number on the V5C. The third plate is also a chassis plate but doesn't belong to your van and the last pic is the commission number which seems to be an internal reference number used by the various companies that made up BL/Austin Rover/Whatever they were called that particular week. Very little documentation exists to relate commission numbers to anything useful as I understand it!
On the colour, it looks like it could be Pageant blue, but the best bet is to get it to a proper automotive paint factors (yell.com) and have them match the colour.
JR
Edited by tractor, 05 November 2012 - 03:09 PM.
Posted 05 November 2012 - 06:23 PM
I think the only chassis plates that have the paint and trim codes are the later one like this.
I'm not sure if a paper label was stuck in one of the door shuts, as is the case with other manufacturers.
Posted 05 November 2012 - 07:32 PM
i didnt think it would be this difficult to track the cars original colour.
Posted 07 November 2012 - 12:20 AM
Posted 07 November 2012 - 12:35 AM
If the car has had a colour change sometimes you can find some of the original colour under the top dash rail of above the headliner. You might be able to match that up with teh colour chart I posted.
theres no headliner on the car and all i can see is blue overspray on the rear door hinge i can see red white & blue
if i cant track the original colour i might just opt for the colour of the mini on this forum header above.
