Spi Ecu Swap
15 replies to this topic
#1 Paulryanmini
Paulryanmini
  • 51 posts
Posted 02 November 2012 - 10:37 PM
Hi all my 96 spi sprite rebuild is coming along nicely.
It's needs a new ecu (or the old one sent to ATP to have immobilser decoded)
It currently has a Mne101050
I have been offered a
Mne101070 that has had the immobilser function removed
The question is will this work in my mini ?
Paul
#2 cliche
cliche
  • 896 posts
Posted 03 November 2012 - 01:36 AM
if it is a genuine MNE101070 then yes as they were used on the Cooper Spi's. I've bought one for my 94 Spi Sprite from a forum member as it has slightly different mapping compared to the standard Spi ECU
#3 Paulryanmini
Paulryanmini
  • 51 posts
Posted 03 November 2012 - 09:10 AM
Hi Thanks thats what i was hoping to hear. :lol:
thanks again
#4 cliche
cliche
  • 896 posts
Posted 03 November 2012 - 09:23 AM
no problem ! It should also have a slightly richer mixture for acceleration purposes
More info on Sprockets post here http://www.theminifo...the-difference/
#5 Paulryanmini
Paulryanmini
  • 51 posts
Posted 03 November 2012 - 09:32 AM
Thanks, hopefully it should just be plug and play. i think its worth a try!!
#6 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 03 November 2012 - 03:20 PM
Well, I am not Sprocket and he is really the Guru on SPI injection. But what I have learned along the way is that the MNE101070 was used on Cooper engines with and without an immobiliser, like in the case of the my Japanese Cooper. The factory wiring diagram shows the (white with red tracer wire) crank position on the ignition switch going to the alarm/immobiliser and from there it goes (white with purple tracer wire) to the starter relay. So for that type of immobiliser only the cranking function is inhibited. You should be able to bump start the car. Apparently, if the car has no alarm there is a substitute box that basically connects the two wires together so the engine can be cranked. There is no connection between the alarm and the ECU.
Also per Sprocket, the ECU's with the "11" in the middle of the number are the ones coded and those are the ones that need the matched set of ECU, alarm and fobs.
I have not found in the wiring diagrams the electrical path used between the immobiliser and the ECU for the ECU to receive the its code from the alarm. I would not be surprised that the information was not made available due to security reasons.
#7 Paulryanmini
Paulryanmini
  • 51 posts
Posted 03 November 2012 - 09:09 PM
Thanks for the in depth reply.
The issue with the mini is it was stolen a few years ago with the keys and the recovery agent lost the keys (the only set). I've put a new barrelll and lock set in and it's starts with no fob
But before it was stolen the immobilser was faulty, it would not kick in for a few weeks and then would suddenly work.
So my problem is if I keep driving it as is one day it will immobilse I'll be stranded.
I'm torn between getting a new immobilser free ecu or sending mine to ATP for them to decode the immobilser function.
#8 wardyxxx
wardyxxx
  • 1,327 posts
  • Local Club: Leicester Mini Club
Posted 05 November 2012 - 02:25 PM
Then try getting a coded ecu, alarm ecu and the fobs.
I assume it'll just be plug and play?
#9 Paulryanmini
Paulryanmini
  • 51 posts
Posted 06 November 2012 - 01:15 PM
that was the original plan but im having trouble sourcing a complete set :shy:
#10 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 06 November 2012 - 06:10 PM
Is the MNE101050 the original ECU of the car? If it is, then it is unlocked. There is no connection between the ECU an the alarm. The alarm immboliser only disables the starter relay. There is no point on getting the MNE101070 unless you want it for better performance.
#11 Paulryanmini
Paulryanmini
  • 51 posts
Posted 06 November 2012 - 06:48 PM
I need to go to specsavers its a mne101150 which I believe is coded?
#12 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 06 November 2012 - 11:03 PM
If it is an MNE101150 then that makes a difference. It is coded. Then your back to your original options. If you decide to go with the MNE101070 make sure that it is in good shape before you buy it.
#13 Paulryanmini
Paulryanmini
  • 51 posts
Posted 07 November 2012 - 07:39 AM
Thanks will do. Any ideas who would have a complete set for sale?
#14 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 13 November 2012 - 10:48 AM
Try Mini And Metro Spares in Warrington. http://www.mini-metro.co.uk
#15 cliche
cliche
  • 896 posts
Posted 13 November 2012 - 11:15 AM
He's BACK !!!! :D
by the way - what do you think of them ?
Edited by cliche, 13 November 2012 - 11:16 AM.
