Cost Of Getting New Wings Welded On?
Posted 31 October 2012 - 11:00 PM
Ben
Posted 01 November 2012 - 08:31 AM
If you were to cut the old stuff off and give them a Mini that's pretty much ready to accept the new panels then it'll be far less expensive. Assuming the new panels fit together with minimum hassle. It also means that you get to find any extra work and can make a decision as to whether to continue or whether you need to save more pennies for extra work to be done.
With a front end you should be relatively safe here as you should be able to check most of the bulkhead and inner wings that will be exposed before you start hacking the old panels off. Check the scuttle ends and closing panels though because they will be relatively easy to fix with the wings off but if you put new wings on and then need to work on the scuttle at a later date you'll be kicking yourself as you cut good wings away to get to the scuttle.
Iain
Posted 01 November 2012 - 08:39 AM
Posted 01 November 2012 - 08:45 AM
Posted 01 November 2012 - 09:13 AM
Posted 01 November 2012 - 11:18 AM
Do remember your car was welded together and was designed to be that way. I do know about bonding and its strength BUT AND ITS A BIG BUT if you were to have an accident and the engineer was to find your car was not welded together then potentially you could get nothing and be handed a very large bill.
What are the chances??? who can say but please think carefully about this. As an addednum to this we will be bonding on a carbon fibre roof to Project Erm. This will be added to the big lissst of things being declared to the insurance company. Also there will be a roll cage added to help replace any lost strength.
Posted 01 November 2012 - 01:25 PM
Posted 01 November 2012 - 01:57 PM
Posted 01 November 2012 - 03:14 PM
Posted 01 November 2012 - 03:38 PM
bonding adhesive has been proven to be stronger than 25mm spaced spot welds, also creats a 100% water tight seal along the joins so will improve the life of the panel and as no moisture can get in in the joins unlike it does in the gaps between the spot welds its less likely to rust. its used on most modern vehicles and i have been using it for years and never had any problem with insurace companies on cars.
MOST MODERN CARS. This is the critical statement here. Mini's were designed and signed off in the late 50's with a welded steel body. No bonding anywhere.
I agree modern bonding when applied correctly is as good as welding but the point i'm making here is that this process will have been part of the design sign off for the cars in question. They will have been crash tested to prove their structural strength using these processes.
On modern aircraft there are more and more bonded items rather than rivetted but these have gone through rigorous testing to prove their structural capability, a classic mini will not have had this process.
I am not trying to poo poo the idea i think its very good but there is a strict process to doing this and with the right materials etc. The same applys for welding.
If the car was built by using the bonding process then use it, if the car was built using the welding process then use it, you cannot go wrong there.
Posted 01 November 2012 - 04:00 PM
Posted 01 November 2012 - 04:33 PM
Its standard practice in bodyshops to bond panels on, not allways to panels that were originally bonded, if insurance companies do not approve this why do they allow it?
As stated in the original post about bonding when Shifty and i contacted VOSA about they were happy to allow bonding on non structual panels on minis. what is structual on a mini is down to the individual as we all have diffrent opinions on this.
Posted 01 November 2012 - 06:36 PM
Now its down to personal choice and to what you would like to do.
What would be nice to know with a definitive answer what is structural and what is non structural on a Mini shell. Suspension mounting points and areas around the seat belt mounts definitely.
Posted 01 November 2012 - 06:58 PM
Posted 01 November 2012 - 09:29 PM
no one will ever agree on this topic its just my views on the subject. niether is right and niether is wrong it personal preference but technology has moved forward and carrys on moving forward and all new cars have some element of structual bonding even the new aston martins and the audi tt are bonded, each to their own!
