Replacing wiring loom!!!!!!
Posted 28 March 2006 - 01:18 PM
Im really not looking forward to this as wiring is not my stromng point (not that I have a strong point at all) but im pretty scared.
Anyone now of any guides or tips to help me along the way. My plan is loads of photos and masking tape to label stuff up.
Does anyone know of any suppliers of new looms and prices?
Cheers Simon
Posted 28 March 2006 - 02:30 PM
Posted 28 March 2006 - 02:41 PM
Oh yeah, Minispares or Auto Sparks are good for looms.
Edited by Dan, 28 March 2006 - 02:41 PM.
Posted 28 March 2006 - 02:43 PM
I actually found the Haynes book of lies to be useful when it comes to "lost" colours too. At least if you do get in trouble you can trace things, and if not, you always have us! (Big aaaaah please!
Can't help on suppliers I'm afraid. I'm building my own loom!
Posted 28 March 2006 - 06:34 PM
ive taken loads of photos of the engine bay and tommorow im going to start putting labels on all the wires.
Are the new looms available complete looms as they list all different models inc van/estate. The car from I can see only has a very small (2 fuses) fuse board does this come with the new stuff as mine is all corroded and green?
cheers again
Simon
I like the comment about monkeys being able to do it, it at least gives me a bit of confidence!!!
Posted 28 March 2006 - 08:53 PM
Posted 29 March 2006 - 09:01 AM
If it doesn't come with the two-fuse box they are still easily available from Mini specialitsts, a new one is a very good idea.
Posted 29 March 2006 - 07:01 PM
gave autosparks a ring and the woman was very helpful, with my car being an oddball im not sure what loom I need though. Its got an early fuse board with just two glass fuses, but ive got a front mounted radiator and I think an early pre inertia started motor as its quite small and just a round cylinder.
mmmmm need to try and identify what ive got. If I post some pics would anyone know if it was early or late?
cheers Simon
Posted 29 March 2006 - 08:17 PM
Posted 30 March 2006 - 05:35 PM
Heres some pics of the engine bay and rad connections. Apologies for the bad quality there of my phone (and ashamed to say before I cracked open some cans!!)
Fuse box is definately early and im going for a centre speedo dash and just going to get a shift light instead of later spec dials and rev counter, shift light will be just an extra light on teh dash somewhere so I know when im killing the engine.
Im going to get a new rad as the old one doesnt look to good just not sure what I need.
Any other comments about the engine bay would be great as ive no idea if its standard or not?
cheers Simon
Posted 30 March 2006 - 06:32 PM
I won't comment on the wiring identification as I don't know enough about early cars, but that switch on the rad is not used on early ones at all! It's normally used to switch the electric fan on Spi and Mpi cars, so I doubt if any early loom would have it on at all! Is there actually an electric fan fitted? (i'd assume so, but.....)
Posted 31 March 2006 - 12:20 PM
As im new to the mini scene I didnt realise it was non standard. Yes it does have an electric fan, it doesnt have a plug on the fan just two wires coming out that are connector blocked into the loom.
If I bin the front mounted rad and get a stanrdard rad and fan that should enable me to bin the expsansion tank and use standard wiring and hoses should it not.
I would rather use standard stuff and besides the water hoses are cut and joined all over.
Brake booster shouldnt be a problem should it as theres no wiring to it?
Cheers Simon
Posted 19 May 2006 - 09:36 PM
oh and what bits do you need to fit it?
Electrical tape.
Posted 19 May 2006 - 10:08 PM
Electrical tape is good. A pack of bullet connectors will probably be good too. those suckers have a habit of pulling off.
When you take it out, before you pull it through the A-pillar, tape a long piece of string to it. When you pull the loom though the roof, it'l leave the string in place, and you can reattach the new loom to the string and pull it back through!
You may find that you have to lower the roof lining on the passenger side too. In theory the loom runs in the channel "inside" the body, but there is a small gap that may come in handy. try it without first and see how it goes.
A pair of long nose pliers might come in handy for fishing the wires out of that channel to the interior light too.
Posted 19 May 2006 - 10:11 PM
Id read about the string idea, sounds good.
We shall see how it goes.
