For sale at $25,000. My loss is your gain. Health forces the sale.
All work was done by the best shop for Mini Coopers on the west coast. Please do not call the shop tire kicking, email me first and I will be happy to answer all your questions. Contact me regarding any questions.
Contact Dane at: [email protected]
Thanks.
A brief tour of the car. Click for HD:
Highway cruising in 6th at 70mph
Conversion subframe info on this swap:
http://pro-motive.co.uk/
This has been a long project for me. I started with a clean 1970 Austin mini 1275 that was purple at one point and someone painted black. So it has a black/plum color that only shows at certain angles in the sun. I have all the paperwork on hours/labor, parts. I also have videos and over 289 photos documenting the build/transformation. This thing was NOT an easy car to build. But it draws crowds more than a live real elvis come back to life on hollywood blvd.
This is Kit 36 out of 40 in the world and the only one in the US that I am aware of that has this fit and finish. I built the car with the intention of daily driving it, but once I got it all together I realized it was a bit too wild as a daily driver. It is much like riding a R1 sport-bike with a mini shell around you. Think loud, fast and lots of adrenaline. The shop owner took one ride in the vehicle and stated that it is the wildest/fastest mini he has ever driven in.
The shop that did the conversion, fabrication, R&D, and getting from a sub-frame to a running vehicle. They continue to service it whenever I need something.
http://www.heritagegarage.com/.
It is the first and only pro-motive I know of running and driveable in the United States that I am aware of. Another Pro-Motive that was built as a race car sold for $36k and was shipped to the Phillipines a year or two ago.
It is complete, was built to be comfortable with a nice clean interior, Corbeau GTS 2 seats and full stereo complete with subwoofer in the rear deck. Top of the line parts, full documentation on fabrication and more man hours than I'd like to admit. I have every receipt on this car and all documentation.
It'd be a great toy for the guy that has it all. The car is located in Socal and will be at every Supercar Sunday at the end of every month if you want to hear it run and see it run in person. I have too many projects and am unable to drive the mini as much as I'd like.
Over 3 years gathering parts from the UK and the time change never helped. They seem to work on a different schedule when it comes to business in the UK.The swap is based on a company in the UK called promotive. Typical power is 170bhp. It has been tuned for the new air fuel and exhaust using the dynojet tuner.
The swap involved the following:
Yamaha R1 5PW 2002-2003 Fuel Injected
Yamaha R1 wiring Loom
Pro-motive R1 Kit #35
Quaife ATB limited slip differential
Wiring looms converted
Negative Camber/Toe Adjustable Suspension Set
Pro-Motive Reverse Gearbox
K&N Air Filter and Carbon Fiber Box
2003 R1 Voltage Regulator
2003 R1 Ecu/CDI box
Barnett Carbon Fiber Clutch
Barnett Clutch Conversion Kit
Koso RX-1N GP Speedometer
Dynojet Power Commander 405-411EX
Scottoiler Automatic Chain Luber
Dual Radiator Setup
Custom Radiator shrouds
Custom Fabricated Rally Style Sump Guard
Suspension was gone through completely and replaced with all aluminum adjustable equipment.
3" Exhaust with extra resonator to quiet the engine down further.
AP Racing MG OEM disk brakes
Misc Items include:
WHITE INTERIOR DOME LAMP
Nardi 330mm Drift Steering Wheel
VTO Performance 13x7 Superlite Wheels
Nardi Steering Wheel
Mountney Steering wheel hub
Hella E Code Headlamps
Corbeau GTS II Seats
Fresh Carpet,vinyl wrapped dash, Rear Leather Wrapped seat to match the Corbeaus.
Leather boots for the shifter and the ebrake.
Kenwood Head unit with Aux input and micro usb at head unit. I use my droid 2 to stream pandora.
Image Dynamics Speakers 6" in the doors
Image Dynamics Freeair 10" Subwoofer
Arc Audio KS Series Amplifier
CDT Audio Pillar tweeters
Sound Dampening
Keyless Entry with 2 keyfobs
New Lenses for rear tail lights and blinkers
New Grille
Mini Lite Gold 13x7 wheels
Continental 195/45-13 Wheels. These are nearly impossible to find.
Elf Racing Engine Oil
Ice Coolant
This car is loud, comparable to a street legal go-cart, and a real attention getter. The butt pucker factor is HIGH once you get above 7000 rpms and it will stretch its legs all the way to 12,500rpm sounding just like an F1 car. This is not a quarter mile drag vehicle, it would be more suited to an occasional track toy, a mini enthusiast, or for the guy that has it all and loves something that no one else has!
Shifting is sequential like a motor cycle. Mechanical reverse knob is mounted just below the shifter. You can go through all 6 speeds in reverse if you were crazy enough. I got the center column dropped for the driver so its less like a schoolbus, and had the interior gone through. New carpet, dash vinyl, rear seat, rear deck, new leather boots for the shifter and ebrake.
There are around 40 Pro-Motive kits in the world.
Its number #36
Current Changes from the pictures: The hood has been debadged, R1 emblem added to trunklid, black plate CA plates. New interior, carpet, custom rear seat and interor work. Dual Radiators, Fresh sprockets and chain, Fresh clutch and throwout bearing. Train horn, badging, and Pro-Motive logo removed from airbox. Original "Austin" decal on carbon fiber airbox just to throw off the uninformed ;)
The pictures are located at:
https://picasaweb.go...COvDurOf3tu7hwE
![Posted Image](https://lh3.googleusercontent.com/-ipFQvYWj8g0/TkLk2zFNkuI/AAAAAAAAFhw/R_ZIrQPfUGE/s1024/2011-07-29_16-57-39_326.jpg)
Please feel free to contact me.
Edited by rogue, 28 October 2012 - 02:55 AM.
