Water Leaking Into Passenger Footwell
25 replies to this topic
#1 Nathan86Mayfair
Nathan86Mayfair
  • 49 posts
Posted 23 October 2012 - 02:04 PM
Hi all
Yesterday I noticed a lot of water in the passenger footwell. I pulled up all the carpets and dried it all out and found what seems to be the leak has been bodged with some sort of tape (see pic). I was just wondering how to repair it.
#2 Mini_Alex
Mini_Alex
  • 175 posts
  • Local Club: East Devon Mini Club
Posted 23 October 2012 - 02:18 PM
What's under the tape a hole?
#3 maccers
maccers
  • 1,867 posts
  • Local Club: LSMOC
Posted 23 October 2012 - 02:57 PM
I have that tape on mine, under it is the studs that hold the subframe on. The tape is used in a few places, looks very standard Rover tape. I doubt much water would come past the studs and into the footwell.
Must be dripping maybe the windscreen seal, door check seal, air vent or somewhere. Its good to remove all carpet and have someone hose the car down while you are inside it with a torch to check where its dripping in.
#4 james94
james94
  • 337 posts
  • Local Club: eastbourne mini club
Posted 23 October 2012 - 03:03 PM
windscreen seal in my opinion, wont come in when driving but will when parked as the water sits on the corner off the seals and comes through if they are old or persished
james
#5 conlad
conlad
    Previously known as ct16mini.
  • 2,054 posts
  • Local Club: Hilltop Minis
Posted 23 October 2012 - 03:44 PM
Tape is definately something standard, my old one had it, here's a pic of its stripped out interior, so you can see where water may come from
a) Windscreen
b) Air vent holes - are they covered?
Doors are a pain in the ass too, I'd get someone to take a hose to your car while the carpets are out and you inside to see where it is coming from, then get new seals etc as needed :D
#6 conlad
conlad
  • 2,054 posts
Posted 23 October 2012 - 03:45 PM
****** i never saw your reply! And I've literally gone and said the same thing ahahaha :shy:
#7 maccers
maccers
  • 1,867 posts
  • Local Club: LSMOC
Posted 23 October 2012 - 03:56 PM
Good to confirm at least 3 minis have that tape then..!!!
#8 Nathan86Mayfair
Nathan86Mayfair
  • 49 posts
Posted 24 October 2012 - 01:00 PM
Ah so that tapes meant to be there. My car was bodged by the last owner to get it to pass the MOT and I thought that he attempted to cover up the leaks with tape. I''ll hose it down and try to find the hole, It seems to leak while driving
Thanks for your help so far
#9 conlad
conlad
  • 2,054 posts
Posted 24 October 2012 - 02:00 PM
My money is on the air vent holes! (if you have any? :shifty: )
#10 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 24 October 2012 - 02:34 PM
+1
#11 conlad
conlad
  • 2,054 posts
Posted 24 October 2012 - 02:52 PM
+1
Good man Alex :D
I only say because if its when moving along then water will get 'flicked' up to that area
#12 Nathan86Mayfair
Nathan86Mayfair
  • 49 posts
Posted 25 October 2012 - 02:20 PM
Found it. It was the heater element. water was dripping off that and soaking the carpets. Thank god it wasn't the dreaded rust :proud:
#13 conlad
conlad
  • 2,054 posts
Posted 25 October 2012 - 04:53 PM
That was my second guess ;)
Glad its all sorted mate
#14 Darryl
Darryl
  • 31 posts
Posted 06 December 2012 - 10:05 PM
Hi...I'm having the same problem, but having real problems tracing where it comes in. I'm getting a lake in the passenger footwell when it rains and the car is stood. After investigating even more it appears to come in from under the crossmember...but how the bloomin' blinkin' 'eck can that be?
Any advice will be very much appreciated
It's a 97 mpi...tahiti blue cooper...just in case that starts any alarm bells ringing :-)
Edited by Darryl, 06 December 2012 - 10:07 PM.
#15 andy159
andy159
    Speedy fingers.
  • 837 posts
Posted 06 December 2012 - 10:12 PM
no but this does
Edited by andy159, 06 December 2012 - 10:13 PM.
