Bonnet Alignment
20 replies to this topic
#16 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 21 October 2012 - 09:09 PM
No probs :D :D
#17 chrscmbs
chrscmbs
  • Validating
  • 138 posts
Posted 25 August 2013 - 10:12 AM
Great thread from 2012, having issues with my own bonnet.
Chris.
#18 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 26 August 2013 - 11:20 AM
i ended up putting the bonnet on pins
#19 Rogers1967
Rogers1967
  • 52 posts
Posted 19 September 2016 - 07:18 PM
I've got 2 broken studs on the bonnet hinges, I can either drill them out and put a couple of bolts through or change the hinges themselves but can't see where the hinges attach to the body, any ideas guys ?
#20 Scousemouse
Scousemouse
  • 358 posts
Posted 19 September 2016 - 08:27 PM
Once you put the bonnet seal in the gutter on the panel where the wipers are (don't know the name of it) as long as the seal is the self adhesive 1" strip type you'll be ok (the bonnet will sit closed properly,if you put door seal instead along the lip the bonnet will warp and not sit closed correctly.
Just sussed this out on mine,previous owner had fitted door seal and warped and kinked the bonnet.
Edited by Scousemouse, 19 September 2016 - 08:28 PM.
#21 tiger99
tiger99
  • 8,584 posts
Posted 20 September 2016 - 06:51 PM
The hinges are a permanent part of the body, just a pair of brackets each side up under the scuttle. They just hold a bolt with nylon nut which is the actual pivot. The part attached to the bonnet, which you wish to repair or replace, simply slots between the two hinge brackets before inserting the bolt.
