Bonnet Alignment
Posted 20 October 2012 - 09:32 AM
just got a mini project in to complete. its had all its welding done and a new front end, ie wings front panel the bonnet is original. its all painted now.
went to close the bonnet on it and as you look at it from the front there is no gap between the wing and the bonnet. but on the passenger side there is a gap of 18mm. the bonnet is adjusted as far as it can go. so my question is
has the front end been welded on incorrectly is this possible, i have i any options now.
Posted 20 October 2012 - 12:01 PM
I had to add metal to the bonnet of Project Erm as i had made a boob fitting the wings. Have a look at the Project erm thread and you will see what i did. For the gap you have got when its evened up i would not do that.
Posted 20 October 2012 - 12:40 PM
Posted 20 October 2012 - 12:53 PM
The way to do it is to trial fit wings and front panel, then trial fit the bonnet, adjusting gently (with a mallet!) as necessary. Once the shut lines are acceptable, you'll never get them absolutely right, complete the welding with the confidence that it will be acceptable when all finished.
For the O.P. that is scant help, but when there is a bit of misalignment you just have to nfiddle with the brackets and bonnet until it's as good as you can get it. It's an idea to remove the bonnet from the hinges and see how well you can get it and note the gaps at back and front on each side. Then fit it to the hinges knowing what you need to replicate those gaps when bolted up. Finally fit the lock mechanism.
Posted 20 October 2012 - 02:20 PM
the cure, file the hole across on the slam panel so you can move the catch across and readjust the bonnet peg.
Posted 20 October 2012 - 05:07 PM
looking at the car from the front.
the gap along the back of the bonnet is correct. close but even
the bonnet is pulled down towards the front of the car so is fully adjusted on the brackets.
the gap along the drivers side is close wing to bonnet same all the way up to the scuttle.a bit too close .
passenger side the gap at the top at the scuttle is correct but at the bottom at the front panel end, the gap is 18 mm.
the bonnet needs to come round at the bottem to close the gap
but as the bonnet is fully adjusted i cannot do this.
i hope this helps
Posted 20 October 2012 - 09:20 PM
Posted 20 October 2012 - 11:36 PM
Posted 21 October 2012 - 12:40 AM
Posted 21 October 2012 - 12:05 PM
It sounds as though the wings have not been welded on symetrically each side. I've seen this before and there was no easy solution. The guy doing it got a 'Porta-Power' out and pushed the wing across a few mm. It seemed like a bit of a 'bodge' to me, but then I don't do bodywork every day. It seemed to work though. Not something I would want to try, which is why, with hindsight, trial builds are good at all stages of body re-building.
ive thought about portapower, im pretty sure it would come across but wits were to fix it to.
also i dont want to disturb the seams as it painted.
going to take a look at project erm now.
the man i bought it from is a c ck
Posted 21 October 2012 - 12:47 PM
Posted 21 October 2012 - 03:10 PM
On the Project Erm thread go from page 30 onwards.
cannot find it
Posted 21 October 2012 - 05:05 PM
Posted 21 October 2012 - 05:12 PM
It takes time and patience but in the end the final result when painted was spot on
Posted 21 October 2012 - 05:59 PM
