Camshaft Identification?
17 replies to this topic
#1 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 18 October 2012 - 12:24 PM
I had a little look inside my engine a while ago, checked the condition of the bores etc and also pulled out the camshaft to see what breed it is. However I couldn't see any obvious markings. So I'm hoping someone on here could help I.D. it for me. I can measure the lobes with a vernier caliper to see what lift there is on the inlet and exhaust and take a few pics but what else do I need to measure and check for someone to work out what it is?
#2 racingenglishcars
racingenglishcars
  • 293 posts
  • Local Club: Donn's Backyard Garage
Posted 18 October 2012 - 02:19 PM
I tried to determine the duration by checking the start and finish of a lobe as in these pictures. Remember the cam turns half the speed of the crank and duration is measured in crank degrees.
Then I looked up the cams on this site for comparison.
http://www.mlmotorsp....php?topic=11.0
#3 skoughi
skoughi
  • 1,199 posts
Posted 18 October 2012 - 04:33 PM
I was thinking that I'd need to check the duration, I've a mate who works at an engineering firm who I'm sure would be able to put it on a lathe then check with a gauge for when the lobe will open to when it will close. Both inlet and exhaust lobes have a lift of 6mm, I would've thought they'd been different?
#4 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Is the cam in the picture slot drive?
AC
#5 skoughi
skoughi
  • 1,199 posts
Posted 18 October 2012 - 05:11 PM
Here's the drive end.
Attached File  009.JPG   206.6K   13 downloads
Edited by skoughi, 18 October 2012 - 07:34 PM.
#6 racingenglishcars
racingenglishcars
  • 293 posts
Posted 18 October 2012 - 05:20 PM
You need to measure lift with accuracy to 0.01mm
When measuring duration, commonly it's measured from the point where the rocker arm has 0.010 inch lift
#7 skoughi
skoughi
  • 1,199 posts
Posted 18 October 2012 - 05:36 PM
Ok, I just checked with the first set that came to hand, I'll look tomorrow to see if we have a more accurate set. You say that I should measure duration at the rockers, does this mean I can't measure it straight off the cam itself? Or is there a calculation I have to do if I measure direct from the lobes?
#8 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 18 October 2012 - 06:13 PM
If you measure at the lobe at 0.016" checking height you can compare tot he figures listed in the link above. See my miniworld article for how to measure cams.
AC
#9 skoughi
skoughi
  • 1,199 posts
Posted 21 October 2012 - 09:54 PM
If I buy a cam with a slot drive can I simply change my oil pump,A-series block, to suit?
#10 mailman
mailman
  • 222 posts
Posted 22 October 2012 - 06:14 AM
Is your Miniworld article online anywhere AC?
If not, could anyone elaborate on how to measure/confirm camshaft grinds?
Thanks.
#11 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 22 October 2012 - 05:59 PM
http://www.kelseysho...product_id=2049
Too much to type!!
AC
#12 mailman
mailman
  • 222 posts
Posted 23 October 2012 - 06:15 AM
Thanks.
Ordered! April 2012, correct? (I hope so..)
What tools do I need to acquire in the next 7-10days before it arrives?
Now to track down those tools and a DTI/ Timing Disc for timing the Cam in.
#13 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 23 October 2012 - 08:27 PM
You need a couple of dial gauges and magnetic bases. Some Dial gauge extensions are also very useful.
AC
#14 racingenglishcars
racingenglishcars
  • 293 posts
Posted 23 October 2012 - 09:09 PM
http://www.avs.spot-...DegreeWheel.png
http://www.hotrodder...degreewheel.jpg
I simply printed one of these and glued it to cardboard
#15 mailman
mailman
  • 222 posts
Posted 23 October 2012 - 11:09 PM
Awesome, thanks so much guys!
