Mini City 1000, Madness!
75 replies to this topic
#1 chabmk
chabmk
  • Just Joined
  • 89 posts
  • Local Club: Looking for a club
Posted 18 October 2012 - 08:07 AM
I have a mini city 1000, its in a very bad way and needs lots of work.
Here is a photo before anything has been started.
First Photo doesn't look that bad. But its when I looked closer and took things apart I realised how bad it actually was.
#2 chabmk
chabmk
  • Just Joined
  • 89 posts
Posted 18 October 2012 - 08:17 AM
So here is some of the rot after removing the dash rail this is what I found.......Attached File  IMG_0719.JPG   25.69K   32 downloadsAttached File  IMG_0719.JPG   25.69K   32 downloads
#3 chabmk
chabmk
  • Just Joined
  • 89 posts
Posted 18 October 2012 - 08:25 AM
I discovered some really shoddy welding and bodge jobs all over the car.Attached File  IMG_0744.JPG   58.77K   42 downloads the boot floorAttached File  IMG_0745.JPG   62.19K   45 downloads oooh look at the nice patches........ NOT! Attached File  IMG_1202.JPG   51.92K   42 downloads I removed the arches as I could see the nasties underneath. They were put on terriblyAttached File  IMG_1201.JPG   72.41K   47 downloads Not quite sure how the bumper stayed on.....
#4 chabmk
chabmk
  • Just Joined
  • 89 posts
Posted 18 October 2012 - 08:26 AM
BLEURGHH!!!!!!!!!! Get that baby fixed up please, it's making me ill
I am on it, I do have some progress photos coming, just getting through the rough first ha!
#5 chabmk
chabmk
  • Just Joined
  • 89 posts
Posted 18 October 2012 - 08:35 AM
Attached File  IMG_1204.JPG   62.73K   41 downloads This is just awful...... I actually didn't know what to say when I saw itAttached File  IMG_1206.JPG   57.85K   28 downloads Here come's a new front end then.....Attached File  IMG_1211.JPG   31.32K   19 downloads The drivers door, underneath......Attached File  IMG_1214.JPG   80.07K   32 downloads Drivers floor pan, sadly also has over sills on the drivers side. Thats coming right off!
#6 chabmk
chabmk
  • Just Joined
  • 89 posts
Posted 18 October 2012 - 08:55 AM
Attached File  IMG_0750.JPG   61.36K   16 downloads This is the start of getting the front end off and engine out!Attached File  IMG_0753.JPG   40.35K   21 downloads Drivers wing off, its awful under there.Attached File  IMG_0755.JPG   74.49K   13 downloads The inner wing...Attached File  IMG_0757.JPG   51.4K   39 downloads Some plonker actually welded this damper mount on and on the passenger side.....
#7 chabmk
chabmk
  • Just Joined
  • 89 posts
Posted 18 October 2012 - 09:09 AM
Attached File  IMG_0749.JPG   49.11K   10 downloads Passenger floorAttached File  IMG_0755.JPG   74.49K   5 downloadsPassenger side wing removedAttached File  IMG_0759.JPG   64.28K   12 downloads wing to be removedAttached File  IMG_0767.JPG   91.79K   14 downloads front end off, getting ready to wheel out the engine on the subframe.
#8 Nathan94
Nathan94
  • 165 posts
Posted 18 October 2012 - 09:14 AM
Good luck! I imagine mine will look something like this once I get going. You doing all the work yourself?
Edited by Nathan94, 18 October 2012 - 09:14 AM.
#9 chabmk
chabmk
  • Just Joined
  • 89 posts
Posted 18 October 2012 - 09:25 AM
Attached File  IMG_0769.JPG   66.33K   17 downloads Passenger flitchAttached File  IMG_0772.JPG   51.54K   35 downloads This may be awkward....Attached File  IMG_0776.JPG   89.6K   23 downloads Nearly ready for engine to come outAttached File  IMG_0777.JPG   60.91K   35 downloads engine out, but plenty of repairs....
#10 chabmk
chabmk
  • Just Joined
  • 89 posts
Posted 18 October 2012 - 09:27 AM
No I am not doing it all on my own lol. I have a guy from this forum working with me on it. I am not an expert, but with two lots of hands and brains, it will get there.
#11 chabmk
chabmk
  • Just Joined
  • 89 posts
Posted 18 October 2012 - 09:42 AM
Attached File  IMG_0791.JPG   49.36K   19 downloads lots of cleaning & painting to do!Attached File  IMG_0819.JPG   48.09K   26 downloads new pieces of metal welded in!Attached File  IMG_0823.JPG   29.21K   44 downloads flitch panel welded in, door post cleaned up and primed.Attached File  IMG_0804.JPG   79.84K   25 downloadsstill more cleaning, but progress showing!
#12 olds_kool_lews
olds_kool_lews
  • 3,601 posts
Posted 18 October 2012 - 06:58 PM
Looking very crusty there! But looks like your getting well and truely stuck in! Good on ya!
#13 1984mini25
1984mini25
  • 8,784 posts
Posted 19 October 2012 - 11:07 PM
The crustyness I can deal with it's the previous owners bodge jobs that are frustrating the hell out of me.
Like the patches over patches, with rust and filler.
Or those fibreglassed sportspack arched and the sliced arch mods.
Also because the 12x4.5 minilights didn't fill the arches, someone then chose to fit 1, 1/4" spacers (witch are for sale) but left the extender studs only hand tight.
It's also things like the missing thermostat and the housing glued on with sealant and a single bolt. Or the engine steady brackets that have both been badly rewelded.
The one that realy gets me is the new clutch master cylinder. Ok, so the studs have snapped, but instead of drilling them out and using nuts/bolts. What the have chosen to do is dill new ones, meaning the master cylinder is offset to the pedal. And there was no sign of the pin in the pedal, witch might explain why the clutch didn't return.
Also there's things like the cracked front trumpet that's no longer sitting in the cone, etc, etc. Don't even get me started on the wiring, I'll deal with that laters when it comes to it.
At the end of the day everything is fixable, it just takes longer to undo the bodged bits than it does to do the repair properly.
#14 JimminyBob
JimminyBob
  • 384 posts
Posted 20 October 2012 - 07:36 AM
Did you buy this off eBay back in January? I'm sure it's the one I went to look at. If it's the same one then it looked alright in the small photos on eBay but in person it really was a shed. Left it well alone! Good luck.
#15 minimo
minimo
  • 86 posts
Posted 20 October 2012 - 08:36 AM
Nice to see some one getting their hands dirty.
Keep up the good work!
