Which Turbo
37 replies to this topic
#16 mini13
mini13
  • 3,810 posts
Posted 08 November 2012 - 06:20 PM
do you have access to the compressor maps for these?
hi im a turbo remanufacturer. the gt17 and the t2 are both very good. giving very similar results. i wouldnt bother with the cheaper turbos as the bearings in the CHRA and the thrust bearing are made from cheap brass and wear very easily. the t2 or gt17 are a much safer option.
#17 TURBO-TOM
TURBO-TOM
  • 50 posts
Posted 08 November 2012 - 06:40 PM
what do you mean by compressor maps? at work we set the actuator up to a standard factory setting. it can be adjusted to keep the wastegate shut longer to preduce more boost.
#18 t@z
t@z
  • 1,712 posts
  • Local Club: www.turbominis.co.uk
Posted 08 November 2012 - 07:58 PM
compressor maps are operating maps of the turbos; efficiency's/flow etc. i think that is the right terminology anyway.
http://www.turbobyga...compressor_maps
#19 supermotolee
supermotolee
  • 1,120 posts
Posted 08 November 2012 - 08:55 PM
where do you work?
#20 Wil_h
Wil_h
  • 3,244 posts
Posted 08 November 2012 - 09:19 PM
This says a lot!!!!!!!!!
#21 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 08 November 2012 - 09:46 PM
Indeed !
#22 mini13
mini13
  • 3,810 posts
Posted 08 November 2012 - 09:58 PM
doesn't it just.
#23 TURBO-TOM
TURBO-TOM
  • 50 posts
Posted 10 November 2012 - 12:55 PM
where do you work?
Ivor searle in soham Cambridgeshire
#24 TURBO-TOM
TURBO-TOM
  • 50 posts
Posted 10 November 2012 - 01:03 PM
I don't do turbo mapping at work, we just remanufacturing them and set them to a factory setting. Mapping a turbo and remanufacturing them are 2 different things
#25 t@z
t@z
  • 1,712 posts
Posted 10 November 2012 - 01:12 PM
you cant remap a turbo, well make a hybrid i guess but a turbo is set to a defined map by its a/r and turbine fins etc at a guess. These graphs just give you the effective ranges of there operation.
ie you dont want to stick a massive turbo on a mini as it wont produce enough air flow to even charge the air to make it effective; it will be inefficient.
Maybe best of reading the garrett site mate before start giving advice thats all im no pro but even i know what a compressor map is and i work in an office not even with turbos.
#26 Wil_h
Wil_h
  • 3,244 posts
Posted 10 November 2012 - 04:12 PM
Yeah, re-manufacturing exists, re-mapping doesn't.
#27 kappa
kappa
  • 1,301 posts
Posted 13 November 2012 - 05:28 PM
Would a GT15 hybrid with a T2 and 360 thrust bearing be a good turbo for this type of set up?
#28 Wil_h
Wil_h
  • 3,244 posts
Posted 14 November 2012 - 12:51 PM
GT15 and a T2 are one in the same thing, but the GT range of turbos have more efficient turbines. So better to just use a GT15.
#29 t@z
t@z
  • 1,712 posts
Posted 15 November 2012 - 12:57 PM
unless you want to use the mirage kit, as doesnt the GT range use a difference exhaust downpipe flange; like the GT17?
Edited by t@z, 15 November 2012 - 12:57 PM.
#30 mad mk1
mad mk1
  • 746 posts
  • Local Club: TurboMinis.co.uk
Posted 15 November 2012 - 01:23 PM
do you have access to the compressor maps for these?.
HaHaHa
